Question about ASUS MW221U LCD Monitor
I have 3 out of 4 Asus VK222H LCD Monitor Menu/Brightness Appearing w/o Button Press, stays onscreens for varying amount of time, then dissapears for a while to return again. Monitors bought August 2008. Aside from this, monitor behaves as new.
  • 3 Answers
Mine did the same. I don't know what caused it, but removing the menu button solved it. Crude but effective.
I took a knife, pried out the Menu button, then took a pliers and removed the little black plastic button and problem solved.
Now I can't change the settings, but switching between VGA, HDMI, and DVI works just fine. No more annoying brightness pop-ups that don't go away!!!
Posted on May 09, 2012
  • 23 Answers
SOURCE: driver problam
what video card are you using? normally you will not need a driver for a monitor.
does your video card support the lowest resolution the monitor you brought?
Posted on Jan 30, 2009
SOURCE: change settings and hold them on vw 192 T asus monitor
can pl i get asus vw192t monitor drivers
Posted on Feb 17, 2009
  • 152 Answers
SOURCE: LCD monitor shuts down every after 2-3 seconds
dustcore025, Need a little more info here. Do you know age of monitor? Was it or did it display a "perfect' image on it the day before? Is it under warranty? How far are you willing to go to try and repair this thing? Do you know how to "part" the snap together plastic back cover from the bezel, after removing the pedestal? This sounds to me like a Switch-mode-power-supply or Inverter problem that occurs when some Electrolytic Filter Capacitors get a little bit TIRED of being constantly subjected to high temperatures near heatsinks that are used to keep semiconductors within operating limits. You can determine how bad this may be if you can do a test and remember what happens. Here is what to do. Make sure PC is fully booted displaying WIN desktop or some other screen. Next, with someone to keep hitting the CTRL or SP bar key every 20-40 seconds while you reconnect both cables of your MM17 back to the PC video port and ac outlet. Now try to turn on the monitor and note exactly what you see and for how long. Did it have a sharp clear image, even for 1-2 seconds? did the screen go black? OK! Next thing is to shine a bright flashlight onto the screen 2 inches away from where you know there was something a few seconds ago. Try it at different angles and not if you see anything. get back to me with results of test. I'm louie12fix on fixya or lmistyrel @ aol.com BYE for now.
Posted on Apr 06, 2009
md_ehsan_1
  • 255 Answers
SOURCE: cant find drivers for ASUS VW193T LCD Monitor
download from this link
www.lostmydrivers.com/
Posted on Jun 28, 2009
FoxSysTech
  • 23 Answers
SOURCE: input select button to switch between hdmi/dvi/vga
Unless there is simply some dirt or dust caught in it, I would imagine that the button has lost its 'spring' or bounce-back ability which means that either you can take the big risk of attempting to fix it or come up with some other clever way to give it bounce.
Posted on Jul 03, 2009
My monitor's brightness menu stays always popped up
check the button which get stuck up, clean it with electronic contact cleaner.you will need to remove the back cover to access the button panel.
Oct 15, 2012 | Philips 170S6FS 17" LCD Monitor
I don't know what the problem is here. I installed new windows updates. The problem started afterward. However, I am not sure if they are connected. My ASUS VK222H monitor has begun to pull up its...
Have U tried to install the latest videodriver ( from the vendor, not Microsoft).
How did U connect your screen? VGA? DVI? try and change these
Try to factory reset the screen and see what happens, i would do this in this sequence
Jun 16, 2011 | ASUS VK222H Monitor
How do I brighten the screen. It is very dark.
Okay on you monitor there is a button there you press its labeled with a little picture of a monitor with a arrow on it or in to that regard you push that button and there should be onscreen menu you use the + and - to scroll to the correct function you want once you done that you should be able to save your settings. This is all done on the monitor!
Please do click the accept button if this helps , Thanks
Nov 05, 2009 | Acer Veriton M410-UD4000C Athlon 64 X2...
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Hello how to adjust brightness on an ACER 19" LCD monitor? thank you Kurt
1. Press the MENU key.
2. Press the < or > key to select the BRIGHTNESS icon from the menu (looks like a little sun).
3. Press the MENU button again to enter the BRIGHTNESS menu.
4. Use < or > to select appropriate brightness.
5. Press MENU button to exit.
5. To exit - select the EXIT function from the menu and press MENU button again.
Apr 01, 2009 | Acer X193W LCD Monitor
Lenovo monitor
I fund that way how to unlock monitor menu... Press Enter Button and Hold it 1 minute. After that is appearing "Monitor is unlocked" Msg......
Have a nice day... good bye.........
Buddika Chathuranga
Sri Lanka
Mar 02, 2009 | Lenovo Thinkvision 19" LCD Monitor
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Hp pavilian f1703 monitor
Press the menu button again (or when done adjusting) and it will go away.
May 09, 2008 | CTX S762A 17" LCD Monitor
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
Tips:
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Al 1916 problem
really? here's the thing..try to check the display settings manually.press the menu button of your monitor then try adjust the contrast, brightness and colors as well to your desired level..if your'e using LCD monitors, these are very sensitive and can be easily damaged if don't handle it very well..don't press the auto button always because it will automatically adjust the settings every now and then..
Jan 27, 2008 | Acer AL1916W 19" LCD Monitor
ASUS MW221U LCD Monitor Logo
470 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
