Whydo i have pink dots on my screen - Computers & Internet
    Guru:
  • 868 Answers
Hi gailandst632,
I saw you post stating that you have pink spots/dots on your Screen.
to determine what the problem is we weill need to turn your computer off and boot into the BIOS screen.
1. Turn your Computer Off, then as soon as you power the machine On keep on tapping F1 on the keyboard to get the BIOS screen it will be a Blue screen with white fonts on it, in that screen see if the pinks dots are present or not.
2. If the pink dots are present in BIO then that means that the LCD screen of your Laptop needs to be replaced.
3. You will need to call your manufacturer regarding this concern check if your system is still in warranty, because this will be very expensive if you are out of warranty.
4. All manufacturers will cover a pixelated LCD screen if the dots or pixelated area has at-least 5 or more dots/pixelated areas on the LCD screen.
I hope that his will help you with the concern that you have posted.
Have a nice day.
Posted on Apr 06, 2011
Green & pink dots screen
This is most likely hardware issues. Take in to replace or reconnect. gl
May 09, 2013 | HP Pavilion dv6000z Notebook
Everything working fine, then home screen no longer displays on TV. On startup, pink dots go across TV screen, then TV goes black. Signal from most recent input is not coming trhough the audio or TV.
I have the same problem. I have an LG lcd tv as well. I have my cable box connected to via hdmi into the reciever then from reciever to the tv via another hdmi cable. I can watch tv and like the problem above see the pink dots on boot-up but I can't get the home screen to display.
Jan 08, 2013 | LG LHB975 Theater System
Blue and pink dots displayed on screen
Looks like the display has developed some problem. Try changing the input device to some other like a DVD player, VCR etc. If the problem persists, this might require attention by a qualified service technician.
Jul 13, 2012 | Sanyo DP26648-R 26 in. LCD TV
Pink dots on screen
Could be try connecting to an external monitor using the vga port. If the same problem appears on the external display the problem is most likely the video card. You may wan to update the display drivers.
Jul 27, 2010 | Toshiba Satellite X205-SLI1 Notebook
Samsung 46" pink dots
I had a problem with the TV going on and off several times before "warming up" and then having pink dots. I would have to reboot to get rid of the dots. I called 1-800-SAMSUNG and reported that I had problems with the capacitors. That is what was causing the problems - cheap capacitors and Samsung is aware that this has caused many TV's to malfunction. My set was not under warranty but Samsung sent a technician across two state lines to fix my TV. As long as the problem is the capacitors Samsung will cover this service call 100%. My TV is fine now. BTW - capacitors which are sold in Radio Shack are not expensive. Why Samsung chose to put the cheapest Korean capacitors in their expensive TVs is a mystery.
So if your TV need warming up and has pink dots on the screen - call 1-800 -SAMSUNG and tell them your capacitors are malfunctioning.
Nov 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
Pink and Red Dots
try removing and reseating the LVDS cable connected to the LCD panel
Jun 07, 2009 | Samsung LN-T4665F 46 in. LCD Television
Self- reboots at start-up, then shows picture but with pink dots.
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts. It is the board to the left and you notice that the four cap tops are swollen.
It is easy to replace get a stanard solder pencil and you are in business.
Thanks for using FIXA, BIG IRISH.
May 24, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Tv problems need help
I had same problem
Apr 16, 2008 | Televison & Video
Pink Dot in center of screen.
Well, You have a bad engine, so what other's called lcd projector motor.
This will cost you, the engine states at about $500. I've seen this problem and right after I've change the engine for some
F#$% reson the bulb when, twice on me, that's another $400.
Good Luck
What About Bob
Timmins, Ontario
Home of Shania Twain
Sep 24, 2006 | Hitachi 50SBX78B 50" Rear Projection...
Computers & Internet Logo
218 people viewed this question
David Payne
David Payne
