Question about Siemens Washing Machines
Washing machine: Total textile management E14-14 Problem: During cycle, the machine stopped on 'rinse' and the start button didn't restart it. So I turned it off hoping that turning it back on and selecting rinse would start the washing machine again, but it didn't 3 lights are flashing on it when I turn it on and the start button isn't flashing therefore will not wash . Help would be very grateful please!!
SOURCE: Washing Machine stopped through cycle and now will not turn on
Unplug!!! NOW! I drained the water using a common garden hose, fill the hose with water and have some device turning it off like a trigger nozzle on the low end. Detach from the supply and put the supply end in the center of the tub under the softener dispenser. take the trigger nozzle off and watch the water drain without cups and buckets. Then wring out the clothes and put them aside, use the hose trick again for remaining water. Now get under the washer and detach and reattach the brown and white lead input to the rinse cycle motor. She is made in France so be gentle. Plug the machine in and set the machine down and turn it on. Push the >> button until you reach the spin cycle if it starts you have fixed it!! Put the clothes back in open a bottle of wine and try again.
Posted on Nov 05, 2007
  • 228 Answers
SOURCE: Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Posted on Aug 12, 2009
steverib
  • 15 Answers
SOURCE: will not complete cycle
Your "cycle selection switch" is probably the timer motor. If tapping it lightlly gets it going again it will probably need replaced. It could be a loose connection but I would need to know the model number to tell how to get into the inside of the control panel to look. If you do get adventurous, be sure to unplug the washer before taking the panel apart.
Posted on Aug 26, 2009
Mark Harmer
  • 8 Answers
SOURCE: Washing machine problem
Same - there's a company in Denmark which does brushes - you have to hunt them down on the web. The brushes come in a brass slider and spring, and sit in a rubber cage. Make sure you don't throw away any bits of the old brushes as you might need to reuse the old rubber cage.
Another solution (if you have the rubber cage) is to move the brushes along a bit and bend the metal tabs on the brass slider. That will give you a contact again - the machine will work for a few weeks or so, which gives you time to order the new brushes.
Posted on Sep 21, 2009
  • 3 Answers
SOURCE: GE washing macine stops during the wash cycle
This is exactly what my machine was doing, as well. I fixed it by cleaning out the filter in front of the water pump.
Searching here, I found that you can remove the lower front panel (three screws along the bottom edge is all it takes) to get to the filter. With the panel removed, you'll see a round white plastic cover (about 3-4 inches diameter) that screws out. Get a bucket under the cover to catch the water that's in it (could be 2 quarts or more) and unscrew the cover.
The cover pulls out, revealing that is actually a screw-in plastic strainer. I found tons of coins, broken pens, paper clips, etc. in mine when I did this. A lot will be deep inside the black rubber hose that connects this filter housing to the washer drum. You can rake the stuff out with a bent wire clothes hanger. Shaking the black hose will help hurry the junk along and out of your machine. Screw the cover back on after the clean out and your machine should go back to normal.
Thinking about it, front loaders will have lots of small items flushed into the pump compared to top loaders. Coins you alway found in the bottom of the drum in a top loader, they all wind up in the filter of a front loader. And once it slow the drainage to a crawl the machine will shut down multiple times when it can't drain the water out completely, and it will never step up to it's max spin speed with all that water still in the drum.
Posted on Nov 30, 2009
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
    Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
    Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
    Kenmore 90 tub spins excessively clockwise during wash cycle.
    there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
    Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
    Stops during rinse cycles. i have to press start button for each rinse cycle because it keeps stopping
    It sounds like the timer has a bad spot in the tiny gears. May be able to find a cheap timer on ebay.
    Oct 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
    DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
    HI, this is a Door Open Error.
    Possible Causes are..-
    * Door not all the way closed
    * Loose electrical connections at door switch and pwb assembly(Control Board)
    * Door switch assembly is out of order(Miss aligned)
    * Gasket on door may be creased in
    Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
    Jul 11, 2009 | LG Washing Machines
    During rinse cycle, washer just stopped, and won't continue rinsing/drain/finish
    Have you tried restarting the cycle? If so, does it stop at the same exact place in the rinse cycle? If so, the issue is most likely the timer mechanism (cycle control) that needs replacing.
    If it doesn't stop at the same place, it may be a flaky lid switch.
    Jul 09, 2009 | Washing Machines
    Nec nw-891 washing machine will not complete the programmed cycle
    Apparent malfunction in the timer circuits. Specific Component replacement not available.
    Jun 30, 2009 | Washing Machines
    Washer stops during rinse cycle and isn't easily restartable....
    Sounds like the contacts in the timer has a problem. Unplug washer. Remove the back of the washer and spray WD40 in the timer. Put towels around and under to to collect excess runoff.
    Rrotate washer dial 25 times and spray some more wd40. Rotate 25 times again. Do a wash load. If it works put everting back together.
    May 04, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Washer stops with an F1 Code during rinse cycles.
    Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
    Dec 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    Fisher and Paykal GWL 10 US - Stops before rinse
    52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
    Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
    Washing Machines Logo
    70 people viewed this question
    Top Siemens Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
