Question about AOC LM729 17" LCD Monitor
When I boot up my PC the monitor will blink the windows logo and sign on for a second then go black....if I turn off the power button on the monitor and pust it back in the monitor will again blink the windows sign on for a slpit second then turn black again. Any ideas ?
    Habit-Forming:
  • 64 Answers
Could be the resolution too high for the monitor.
Try to press "F8" during the "Starting Windows" message, then select the safe mode or VGA mode.
After logging in check the resolution and if needed reduce it.
Could be also a video driver problem.
Use the same "F8" trick to get to the safe mode and reinstall the video driver.
I hope this will give you some ideas
Posted on Apr 05, 2011
  • rookie1st Apr 05, 2011
    sorry...I can;t get to safe mode because the monitor is black,
  • krava
    krava Apr 06, 2011
    You stated that you could see a windows logo. That means you already passed the point when you could press the "F8" key. This should be done before you can see the GUI. If don't see anything at all, try your monitor on another PC. If it's working the problem is in your video adapter.
    If it's not working the problem is in your monitor.
Green power light comes on but disk drive lights keep blinking and my screen is black on my dell dimension 4700
Remove ALL media from the machine DVD, CD, USB, etc. Check/reseat all Monitor cables. Reboot. If that fails, unplug , plug back in in 30 seconds or so. reboot, if you get a Dell Logo, Open the boot Menu and select Boot from HDD first.
Dec 23, 2012 | Dell Dimension 4700 PC Desktop
My monitor does't display anything excepy the windows logo but after the windows appear it turns black and keeps on blinking
The common problem indicated by this is, a corrupt operating system and very occaisionally it is the Hard drive. but if it is the hard drive you would be unlikely to see the windows logo. Try and do a restore by using the facilities available under the F8 button on boot up. You can do a system repair or a system restore- I would try the system Repair first. Good luck.
Feb 01, 2012 | Computers & Internet
Does not boot up, fans start, internet plugs light, clicks on and off.....seems this is a common problem for these machines, what is the fix?
Instructions
  1. When you press the Power button to start the boot process, the LED lights glow while the computer verifies that there is sufficient electrical power to activate the hardware.
    Effect & Solution: When you press the power button, the LED lights on the computer do not glow or the LEDs blink briefly and then stop. There is no sound of the fan or hard drive spinning, and the screen remains blank. The computer will not start if there is insufficient battery or AC adapter power.
  2. The BIOS queries various hardware components used for the startup boot process.
    Effect & Solution: When you press the power button, the LEDs glow but there is no fan or hard drive sound. The LEDs may glow briefly and then go out.
    Or
    The LED lights blink, stop, and then blink a second or third time, but there is no sound from the computer and the screen remains blank. The sequence of the blinking lights indicates a specific error code.
    Or
    A series of beeping tones is heard. The sequence of beeping tones indicate a specific error code.
    If a hardware component has recently been replaced, or if the PC has been jarred or shaken, there may be a loose connection to the memory chips or hard drive which prevents the computer from starting.
  3. The BIOS loads the basic input (keyboard) and output (advanced LEDs / display screen / boot drives) devices into memory.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, but then the boot process stops and a black screen - with an error message - displays.
    The boot check has detected a communication error or conflict with a hardware component that must be corrected.
  4. The BIOS loads the Windows operating system and starts the services that allow low-level control of all of the background operations.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, the HP or Compaq Logo displays on a black screen, but then the boot process stops and a blue screen - with an error message - displays.
    The boot check has detected a hardware driver error or a software conflict that must be corrected.
  5. Control is transferred to the Windows loader to initiate the display of the advanced settings in the Windows environment.
    The Windows logo displays during this step.
    Effect & Solution: When you press the power button, the computer performs all the steps in the boot process, but after the Windows Logo displays, the moving Windows progress bar or the rotating cursor stops moving and the boot process stops.
    An error message may display on a screen with the Windows logo. In some instances, there is no specific error message.
    Or
    A black screen appears and the computer attempts to restart.
    The Windows self-check has detected a software conflict that must be corrected.
Jan 09, 2011 | Gateway GT4016 Desktop PC
Screen is blank (white) when turned on.
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Turn off the system. Unplug the power cord from the mains. Keep the power button of the cpu (not the monitor) pressed for 5-6 seconds. turn the unit bcak on and check.
Please reseat the monitor cable that connects to the desktop ensuring a secure connection.
Further, if you are able to see the Lenovo Logo on startup try booting to safe mode by tapping F8 key on the lenovo logo itself.
Howevre, in case you are not even able to view the lenovo logo on startup, then it could be a fault with the lcd monitor itself requiring a repair.
Nov 17, 2010 | Lenovo L191 (Black) LCD Monitor
Get acer logo then windows for a second then
If it was dropped in all probability it is broken. Perhaps your friend would share the cost of replacing it. sorry for your loss
Jan 01, 2010 | Computers & Internet
I have a Microtek 710S which suddenly will not show anything other than a black, blank screen. When I turn on the button in the bottom center of the frame, it alternately changes color every second or...
Does it show any sign of life when you poweron the PC? With the PC powered on, remove the data cable of the monitor (yes the D plug) from the PC and insert it back. See if there are any signs of life. If there are any signs of life, reboot in safe mode by pressing F8 at bootup. If it boots in Safe Mode, then go to Control panel->Display->Settings->Advanced. Remove the Monitor and let windows detect the monitor. Same thing can also be done from Control Panel->System->Hardware->Device Manager-. Monitor. Remove the monitor and from Actions select Scan for New HW.
Oct 02, 2009 | Microtek C783GM 17" Flat Panel LCD Monitor
Screen on laptop keeps going black
please explain further. keeps going black from where? after turning on the laptop? of after windows logo? if after windows logo screen turns black if a no boot issue where laptop cannot load system files. if screen is black after turning on no manufacturer logo and windows logo or anything then it might be the LCD or video card / motherboard. to isolate try connecting your laptop to an external monitor and check if you will be getting the same problem. if no display from the external monitor then its a video card issue, if video card is integrated needs to replace motherboard.
Oct 01, 2009 | Computers & Internet
Dell Monitor comes on but no picture
The monitor isn't getting a signal from the computer, which is why the power indicator goes orange. There are two possibilities:
1) The computer isn't operating correctly. It may not be starting up at all when you turn it on, and you have a "no boot" problem to solve, or
2) The computer is working properly, shows all the signs of normal startup (hard drive activity, Windows startup sound from speakers, etc.). but video isn't reaching the monitor. There may be a problem with the video card (or on the system board if it's integrated video). Or the monitor itself is bad and not detecting the video. You can test this by connectng a known good monitor.
Jan 16, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
AOC LM729 17" LCD Monitor Logo
109 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
