Question about Milwaukee Tool 10 Amp Sawzall Plus with Quick - Lok Cord
Tool all of a sudden stopped working. Have power through cord, but squeeze the trigger and nothing.
  • 4,234 Answers
Two things to check: Some of the newer models have a speed control on the side. Be sure that you have not set this to the lowest (off) setting. Also, verify that the cord is all the way in and locked. Next I would replace the trigger. Over the years, I have had to replace the trigger a number of times.
Dan
Posted on Apr 05, 2011
Why does my screw gun work an then stop and work again ?
The trigger is probably going bad. A replacement trigger is around $30.00
Mar 31, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Squeeze trigger wont run
could be anything from the cord, switch to the other electrical parts. If you have a volt-ohms meter start by UNPLUGGING the tool and just follow from teh cord to the switch and continue, It is a process of elimination. Let me know if you need more assistance. If you do I need the brand and model number so I am better prepared.
Dec 23, 2011 | Hilti Drills
AFTER NOT USING MY HITACHI C10FSH FOR A YEAR OR SO. I TURNED IT ON YESTERDAY AND I HIT THE TRIGGER AND IT STARTED, I THEN SET UP MY CUTS AND IT WOULD NOT START. AFTER CHECKING THE POWER SOURCE, I PRESSED...
with the tool unplugged check that the two carbon brushes are free in the holders . remove the two caps locking them in and take them out , blow out and replace . be careful make sure when putting them back in that the caps do up nice an free. possibly dust stopping brushes from making contact to armature .
Aug 16, 2011 | Hitachi C10FSH 10" Dual Bevel Slide...
No power when i squeeze the trigger on the hd77
Troubleshoot the problem. It could only be a few things: 1) defective trigger/switch, in which case you can replace it by getting the part from a specialty tool store; 2) the cord itself, either where it plugs into the saw or at the plug end there may be a loose wire; 3) you've accidentally cut or nicked the cord--easily done--and there is a severed wire.
Jul 31, 2011 | Skil Circular Saw 7 14" HD77 Worm Drive
How do i start the saw
Hello. The steps are quite easy once you've done it a few times. When starting: pull the choke switch on, press the throttle lock as you squeeze the trigger (this locks the throttle into a half-on position), push in the decompression valve, and pull the cord. I recommend placing the unit on the ground and stepping in the trigger-guard area to stabilize it. Here's a link to the instruction manual for you reference - it shows the sequence with diagrams on pg 18 & 19. Hope this helps, if it does, please rate a four-thumbs up. Thank You.
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=476
Mar 03, 2011 | Makita DPC7311 73cc 14Inch Gas Powered...
Won't start. Pull chord will only come out quarter of the way.
There could be two possible problems here.
1) Usually you want to squeeze the gun trigger to release backpressure on the pump so the engine will turn over easily. So hold the gun in one hand with water coming out of the gun while pulling cord.
2) The pull cord mechanism is connected to top of power washer with 3-4 bolts.
Take off those bolts and see if you can unravel the problem. The mechanism is connected to a spring and the spring pulls the cord back in ... so it seems like the rope is in a bind or the pull mechanism is bad.
We had to buy a replacement pull cord mechanism at one time for our power washer, but I forget exactly why it stopped working. We used the power washer two days a week for years. It's aggravating when it doesn't work.
Oct 17, 2010 | Briggs & Stratton Prosumer 20324 Gas...
My milwaukee 3/8 drill was working fine when it just stopped, no burn smell, nothing. the tool is in great shape.
if it does nothing chcck battery voltage, power connections, trigger button
May 18, 2010 | Drills
Stopped working in mid drill. squeeze the trigger, nothing happens
It could be a dirty switch connection in the trigger assembly , it happens to me on my electric sanders all the time , just open it up and try blowing it out with an air compressor
May 23, 2009 | Milwaukee 5318-21 1-1/2" Spline Rotary...
Stapler works intermittantly
If not the power source or cord, the next activation point would be the trigger. Does the stapler make any sort of noise when the trigger is depressed? What type and model stapler is it?
Nov 02, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
Milwaukee Tool 10 Amp Sawzall Plus with Quick - Lok Cord Logo
191 people viewed this question
Top Milwaukee Tool Saws Experts
Jim Thurston
Dave
Level 1 Expert
JOHN LAPIER
Are you a Milwaukee Tool Saw Expert? Answer questions, earn points and help others
