Question about Electric Cycling
Batteries fully charged ok,turn ignition on,no lights,no power to wheel,but pressing the horn it only sounds weak,will not light led lights on lamp.had control box tested and was ok,new ignition switch fitted,but didnt solve problem.at a loss as to why not enough power reaching motor, headlamp, and horn asides a little sound in horn when pressed.? help!!!!
  • 456 Answers
The faults you are describing do match flat or faulty batteries more than anything else.
check that the connections are good on the batteries and that the battery pack connects properly.
i think it would be worth you testing the charger and the batteries to make sure they are working properly. i would not change any other parts until these have been checked.
if the bike was stored in a garage or shed during the winter it is possible that the batteries inside the battery pack may have been damaged by the cold.
if you send make and model and age of the bike i can send you far more detailed testing proceedures, but i would need the details, as battery types and voltages vary from bike to bike.
Posted on Apr 05, 2011
Testimonial: "excellent help many thanks"
My horn stop working and when I lock the doors with remote key it wont sound when you lock the doors Forgot to add that it is a 2012 Ford Escape Horn does not work from the inside either. Is it a fuse
Does the horn sound when you press it on the steering wheel if not check for a blown fuse to horn and then if ok see if you have power to horn and then if that is ok run a wire from the battery to the horn and see if it honks.
Apr 15, 2017 | Cars & Trucks
Victory pride 2002 won't work?
hi Wendy it sounds like the batteries are so low that they can't even power the horn ?
check the batteries connection and the reset fuse situated at the rear .
regards
Rob
www.gewizrepairs.co.uk
Feb 18, 2017 | Pride Health & Beauty
I charging my electric wheelchair a DL 5.2i. when is changing completed?
On this controller there is a 6 light LED display above the battery icon which is below the horn button. Turn on the power chair with the 1/0 button and the LED display will light up. The lights are red on the left, yellow in the middle and green to the right. If all 6 lights are lit the chair is fully charged. Hope this helps.
Nov 18, 2016 | Electric Health & Beauty
B4000 problems 1999
The security system thinks that something is wrong and is sounding the horn and flashing the lights. This is because the system had no battery power. Unlock all the doors, put key in ignition turn all way except to start the engine. remove key from ignition and lock all doors, This may reset the security system.
Dec 15, 2013 | Cars & Trucks
Pride colt . fully charged batteries but no power to lights indicators or drive
hi, okay have you checked the fuses located on the tiller stem normally located under a black plastic cover ?
Your batteries may be fully charged but the voltage is not enough to power up the controller, sigh of a dodgy charger ? , bad batteries ? ? check the battery voltage , should be at least 24volts
The horn will work as it bypasses the controller logic.
Regards
Jan 20, 2013 | Pride Health & Beauty
Starter relay and back tail light not working?
first check out for blown fuses,if they are ok then check the four terminal wire coming out of alternator.it seems to be a problem of loose connection.horn sounds weak because battery is not being charged.
Dec 21, 2012 | 2007 Enfield Bullet Electra
Cant get 2008 cobalt to start. lights come on but engine wont turn over and steering wheel will not turn
If you hear the clikclik sound when you turn ON your key, that means your battery is weak even light can turn ON, but the engine it can't; The starter are the same, but you need to make sure that the battery is fully charge that can able to start the engine. ok
Mar 10, 2010 | 2008 Chevrolet Cobalt
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Led lights flash and Pride Go chair won't move.
Firstly disengage the drive levers and then "flick "them in fash.
Second pull out the large plug that is between them.
Check for damaged or bent or loose pins. press it home firmly .
I did this on my wifes chair and she zooms around.
All switched etc should be off during charge.
Lastly i fully discharged then recharged the battery to ensure no "battery charge memory".
To fully dicharge i shoved a small box between back wheels so to lift of ground and then a elastic band to hond controler on.
Jan 11, 2009 | Pride Go Chair Travel Power Chair
Battery not charging
Sounds like the cells in the battery have shorted. It's probably shot. Does the car run once its jump started? Does it continue to run after the cables are removed, if so your alternator is ok and its the battery. Hope that helps.
Jun 30, 2008 | 1999 Oldsmobile Alero
Cycling Logo
320 people viewed this question
Top Electric Cycling Experts
Eric Hidle
Level 1 Expert
Colin Stickland
Colin Stickland
Are you an Electric Cycling Expert? Answer questions, earn points and help others
