Samsung LN32A330J1DXZA will not turn on - Televison & Video
  • 760 Answers
That set had a big problem with capacitors. If you are experienced with electronics, then change out the group of caps on the top of the power supply. They should be marked as 2200MF at 10V. If you can not do this I would take it to a authorized service provider. It is a cheap enough repair.
Posted on Apr 05, 2011
My 2008 LCD flat screen TV
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 06, 2016 | Televison & Video
Samsung flatscreen color went bad
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 14, 2015 | Samsung Televison & Video
Samsung LN32A330J1DXZA will not power on. Problem occurred after moving TV from one house to another. Samsung Capacitor repair came out and pronounced it a dead main board and did not perform any...
reset the c.breaker or replace fuse in the main panel service from your home 2) test the power cord 3) test the switch 4) see if the fuse or c.breaker inside is tripper or replace fuse and try again.
God bless you
Nov 03, 2013 | Samsung BN41-00965A BN94-02070A...
I have a samsung LN32A330J1DXZA 32 inch flat screen tv. not quite 2 years old and it wont turn on. red light just flashes once?
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for different brand, but same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Mar 11, 2011 | Samsung LN32A330 32 in. LCD TV
TV will not turn on Model # LN32A330J1DXZA
Check your : - Power cord ( the presence of power) - Fuse Replace them as necessary. If booth of above working well, you need to check power circuit in your TV ( This will required advance TV knowledge).
Nov 27, 2010 | Samsung Televison & Video
I have Samsung forum: LN32A330J1DXZA and I have dish network satellite cable. I have plugged everything in the right component but it keep saying no signal. I have it on AV and I know I should change it...
Hello. i hope that you have gotten your tv on the right input, but I am here to help if not, or if you have any other troubles with it. In most cases, the color or look of the cable going from the receiver to the tv will tell you what input the tv needs to be on. If they are red/white/yellow, normally this is Video 1 or 2. If they are red/blue/green, normally this is component 1 or 2. If it is the flat HDMI cable, then the tv needs to on HDMI 1 or 2, etc. The tv itself needs to be on channel 3 or 4. Hope this helps.
Becki Barned
DISH Network Customer Service
Nov 15, 2010 | Samsung LN37A330J LCD TV
My samsung LN32A330J1DXZA won't power on. please advise. just get a red light on the power button.
You have open the back cover of the television to check for bulged capacitors if found replaced with the same value, but if otherwise
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this help.....
Jun 07, 2010 | Samsung LN32A330 32 in. LCD TV
How do i enter the nuc code on a samsung wave mobile phone
Samsung SGH-a300
*2767*637#
Samsung SGH-a400
*2767*637#
Samsung SGH-a800
*2767*637#
Samsung SGH-e400
*2767*688#
In newer phones:
#*7337#
Samsung SGH-e500
*2767*688#
In newer phones:
#*7337#
Samsung SGH-e700
*2767*688#
In newer phones:
#*7337#
Samsung SGH-E715
Turn off the phone. Put a non-accepted SIM Card and turn it on. Type *#9998*3323#. Press Exit. Choose menu #7. After phone reboots type *0141# and hit the Call button. Turn off and insert another SIM Card. Turn on. The code is 00000000.
In newer phones:
#*7337#
Samsung SGH-m100
Type *#9998*627837793#. Then type *#9998*737#. Press >/[] (Play Stop) until phone shows NCK/SPCK number. Press Exit. Type #0111*CODE# (Code is the last 8 digits of the NCK/SPCK)
Samsung SGH-P400
*2767*3855# or *2767*688# or *2767*927#
In newer Samsung models:
#*7337#
Samsung SGH-s100
*2767*7822573738#
Samsung SGH-s105
Remove SIM Card. Enter *2767*7822573738# and after phone reboots, enter #0111*00000000#
Samsung SGH-s300
*2767*7822573738#
Samsung SGH-s307
In newer phones:
#*7337#
Samsung SGH-S500
In newer phones[/color]:
#*7337#
Samsung SGH-600
*2767*3855# or *2767*2878#
Samsung SGH-2100
Samsung SGH-V200
*2767*7822573738#
Samsung SGH-X100
In newer phones:
#*7337#
Samsung SGH-X600
In newer phones:
#*7337#
Samsung SGH-R210
*2767*3855#
*2767*2878#
Samsung SGH-D500
#*7337#
Samsung Universal Type
TEMPORARY UNLOCK:
Put a non-accepted SIM Card and turn it on. Type *#9998*3323#. Press Exit. You will get a new menu. Select Malloc Fail.
In newer phones:
#*7337#
May 30, 2010 | Samsung Lands Phones
Televison & Video Logo
565 people viewed this question
Top Televison & Video Experts
Electro Med Services...
