Question about Megxon X3 Digital Camera
Manual I need a instruction manual for megxon x3
    President:
  • 1,114 Answers
Hi - You can download the manual from the link underlined in blue below:
megxon x3
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Aug 06, 2008
I need a manual not just one sheet of paper
There are available manual for about two dozend of different model of Megxon Digital Cameras. As you hadn't indicated WHICH model are you using, I'll provide you the page and hope that there youl'l get the one you need or atr least, a very similar one
http://www.retrevo.com/samples/Megxon-Digital-Camera-manuals.html
Apr 26, 2015 | Megxon Cameras
Installation CD & Quick Guide
Follow this link for your manual, driver, and FAQ's http://www.megxon.com/techsupp/download/X3/X3_supp.htm Driver install 1. Download driver file "X3_Driver.exe" and save it to PC hard disk. 2. This driver file is a self-extracting archive, run it and it will extract automatic. 3. Run "X3 Driver.exe" and will show "WinRAR self-extracting archive" dialog. Press "Install" start extracting. 4. After, in hard disk will create a "X3 Driver" folder. 5. Enter "X3 Driver" folder and find "Install" folder. 6. Enter "Install" folder, find "SETUP.EXE" and run it. The installation wizard will guide you through the installation. -------------------------------------------------------------------------------- How to set the USB function to PC Camera or Storage mode (Regarding how to set the USB function to PC Camera or Storage mode, please reference user manual in page 42.) When connect DSC to PC, it will become a storage device or PC camera depend on the setting of USB in the setup mode. 1. Press the "Manu" button (in the back, left-up side of 5 ways switch) into Menu section. 2. Then press right key to "Setup". 3. Press down key to "USB" then press right key. 4. Press up or down key and change it to "PC camera" or "Storage". 5. Press "OK" key to confirm. -------------------------------------------------------------------------------- How to Format internal memory or memory card (Regarding how to format, please reference user manual page 27. ) > Formatting SD Card Prior to its initial usage, format the SD card. To format the SD card, please insert your compatible SD card into SD slot. Then proceed with the following steps: 1. In "Capture" mode, press "MENU" button into the setting mode. 2. You can see "Capture" and "Setup" in the screen. 3. Press right key to "Setup" then press down key to "Format". 4. Press right key to next step. 5. Press down key to "Confirm". 6. Press "OK" button to confirm. The SD card will be formatted. > Formatting the Internal Memory Take out SD card from the slot and format the Internal Memory by following the above mentioned steps . NOTICE 1. Prior to formatting the SD card, deactivate the ¡§Protect SD card¡¨ function. 2. The internal memory cannot be formatted when the SD card is in the camera.
Oct 03, 2007 | Megxon X33 Digital Camera
What type of sd card do i need to buy for the megxon x3 the sereal number is Y65E2M001058
The X3 can use any SD card up to 1GB in size. You don't need to worry about the speed or brand of the card, though I'd stick with the major brands.
Apr 26, 2011 | Megxon X3 Digital Camera
Need driver for megxom x38
Try this link:
http://www.megxon.com.tw/E/techsupp/download/X3/X3_supp.htm
Jun 25, 2009 | Megxon X38 Digital Camera
SADLY A RELATIVE DIED DURING THE YEAR AND HIS WIFE GAVE ME HIS DIGITAL CAMERA. THE CAMERA IS A "MEGXON S306". PURCHASED LATE 2007, AND IS IN 'AS NEW' CONDITION. NO BATTERIES, NO USB CABLE TO HOOK UP TO MY...
So sorry to hear about your relative.
Megxon is not a standard camera brand. It is apparently made by the same company that makes the Praktika Luxmedia cameras. Take a look at the Praktika Luxmedia camera line and see if you can find one that is the same as, or substantially similar to, the Megxon camera you have.
Have you tried to see if standard USB camera cables will work on this camera? There are several "standard" USB plugs often used on digital cameras. See this article on USB at Wikipedia. Take a look at the Micro and Mini plug illustrations and see if you can identify the plug on the camera. If you can identify it as a standard USB plug, then you should be able to purchase a USB cable with the correct end to fit into the camera.
Dec 27, 2008 | Megxon X33 Digital Camera
I need to download the manual for the megxon c630 any help
You can click on the link below then click on ENGLISH to download the manual for your camera that you need.
http://www.megxon.com.tw/E/techsupp/download/C630/C630_supp.htm
Oct 22, 2008 | Megxon Cameras
I need a driver download for a megxon x32 digital camera
Megxon says you don't need driver if you have Windows XP in PC. check it out at Megxon for further details.
Sep 05, 2008 | Megxon X32 Digital Camera
MEGXON S301 DRIVER DOWNLOAD
The manuals and drivers for Megxon S301 to S306 are the same =>
http://www.megxon.com.tw/E/techsupp/download/S301/S301_supp.htm
Here's the user manual =>
http://www.megxon.com.tw/E/techsupp/download/S301/S301_User_Manual_E.pdf
Here's the Quick Reference Guide =>
http://www.megxon.com.tw/E/techsupp/download/S301/S30X_Quick_Guide.pdf
Here's the driver to connect to your computer =>
http://www.megxon.com.tw/E/techsupp/download/S301/S301_Driver.exe
If you need anything else =>
http://www.megxon.com.tw/E/techsupp/TechSupp.htm
Jun 28, 2008 | Megxon X33 Digital Camera
MANUAL FOR MEGXON C580
Have you found a manual as yet??
Dec 30, 2007 | Cameras
Megxon X3 Digital Camera Logo
325 people viewed this question
Top Megxon Cameras Experts
Greg Cann
Greg Cann
Vladimir Frolov
Are you a Megxon Camera Expert? Answer questions, earn points and help others
