Question about Zebra Barcode Scanner Accessory for Symbol LS3408
My computer does not recognize the ls3408 - Zebra Barcode Scanner Accessory for Symbol LS3408
Need to be able to connect to my computer . plugged it in but computer does not recognize the mouse . red light is on
My computer doesn't recognize my mouse and its not listed in ...
www.tomshardware.com > ... > Windows 2000/NT
Tom's Hardware Guide
Mar 25, 2012 - 9 posts - ‎7 authors
please help.....I am using my keyboard to move my mouse keys and it really sucks. After a storm everything came out fine on my diagnostic ... My computer doesn\'t recognize my mouse and its not ...
Feb 28, 2013
Mylaptop doesnt recognize the usb for my mouse ...
Jan 27, 2013
Computer won't recognize keyboard or mouse - Mice ...
Aug 27, 2012
Computer won't recognize keyboard or mouse? [Solved ...
Aug 6, 2011
More results from www.tomshardware.com
Mouse doesn't work in any USB port - Tom's Hardware
Jan 21, 2016 | Onn Optical Mouse
Programming ls3408-fz
We recommend you contact Motorola Solutions
http://www.motorolasolutions.com/support
Mark
Motorola Support
Jan 29, 2014 | Symbol LS3408 Barcode Scanner
My computer will not recognize the external harddrive so I can't access it
Connect it to a different computer. If it is not recognized, then it has a problem.
If it is recognized, then your computer has a problem recognizing it.
Apr 10, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Are the USB drivers for any Motorola/Symbol scanners the same? or do I have to have a specific driver for each device that I want to support?
there are no special USB drivers for those scanners. The scanner get installed like an Standard USB HID device (as a USB Keyboard) on a host computer.
Therefore you dont need an special driver for them.
Oct 11, 2010 | Symbol LS3408 Barcode Scanner
HOW TO PROGRAM A SCANNER USING BAR CODES
Here is the manual. Sample barcodes inside to turn on different barcode types. http://www.fesem.com/download/doc/symbol/LS3408_APG.pdf
May 29, 2010 | Symbol LS3408 Barcode Scanner
Dvd-rom sd-616E driver no longer recognized by
Reboot the computer and go into the BIOS, see if its recognized in there, if its not recognized then you'll need to turn the computer off and unseat and reseat the cable and the power connector to the dvd drive. Then turn on the computer again and go into the BIOS, if the dvd drive is still not recognzied then you'll need to replace the drive.
If the dvd drive is recognized in the BIOS and not in windows then you'll need to go into the system restore in windows and choose a date the last time the computer was working, it will restore your computer back to this date and reboot. At that point it should recognize your dvd drive. If it doesn't then your OS is corrupt and you'll need to wipe out the drive and restore your computer back to factory defaults.
Feb 04, 2010 | Gateway 5200XL PC Desktop
My adaptor is not recognized in my USB ports I installed the router and it completes all of its connection checks. I am trying to install the adaptor on a remote computer (in the basement) and that...
Here's what you can do since this is a USB wireless adapter, first connect the USB adapter on a different USB port on the computer better if you connect it on the back USB port of the computer tower and check if the computer will recognize it and if its recognize you can already continue with the software installation , but if not you can restart first the computer and check if the adapter will be recognized if still not the next thing to do here just to know if the adapter is good or bad is to connect it on a different computer and just to check if it will be recognized once its connected to a USB port , because a device should be automatically will be recognized by a computer once you connect it so if its still not recognized by a different computer adapter is bad...
Dec 15, 2009 | Computers & Internet
USB device not recognized
This solution worked for me when I got the USB device not recognized message:
http://www.infobarrel.com/USB_Port_Repair
It can be quite frustrating. I've heard that older computers are more likely to have the USB device not recognized message.
May 31, 2009 | Dell Inspiron 6400 Notebook
My computer dont recognized my mp3 m-230 what can i do ???
mostly, mp3 devices comes with a software.
if u have the software, and the usb dont recognize your mp3 device. most probably the problem is in you usb drive or usb connector.
Feb 27, 2009 | SanDisk Sansa m230 MP3 Player
Computer is not recognizing my memory card
Does your computer recognize any other memory cards? If this is the only card that the computer is not recognizing, I would recommend a new memory card. If your computer is not recognizing any memory cards, I would recommend that you visit the pc manufacturer's web site and download the newest firmware/drivers for the card reader.
Dec 21, 2008 | E-Machines eMachines Refurbished EMA...
Zebra Barcode Scanner Accessory for Symbol LS3408 Logo
42 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
