Question about Refrigerators
I have a plastic part PS-HI 78221 or 61003888 or PS2059451 depending on which website I go to. Where does this part actually go? There are 2 of these plastic sleeves.
I can get to the farmville page but not on to the my actuall farm. ps not very good with computers.
Try to refresh the page when that happens next time and whats the error message you get?
Dec 20, 2010 | Facebook Social Network
MY MICROWAVE OVEN DOESN´T HEAT, HOW MUCH WOLD BE THE REPARATION?
Hi and welcome to FixYa. I am Kelly. The majority of the time when you have a working control panel and no heat there are 2 - 3 items that fail.
Service manual for this microwave is actually posted on the sears website:
http://www.searspartsdirect.com/partsdirect/part-model/Sansui-Parts/Microwave-Parts/Model-MW8554W/1763/0123245?pathTaken=
Cost will depend on what part has failed.
Kelly
Oct 05, 2010 | Samsung MW8554W Microwave Oven
How do I set up a d-link dub-h4 to my laptop I have a power connection, a connection on the rear of the hub-4 going to an adapter connecting to the ps/2 connector on the laptop. Do I need one of the...
The connection on the rear of the hub should go to a USB connection on the laptop, not a PS/2 connection. A PS/2 to USB adapter is used to connect a PS/2 keyboard or mouse to a USB connection.
Feb 23, 2010 | D-Link (DUB-H4) 4-Port USB Hub
How to intall PAC SWI-PS green and blue wires to pioneer AVH-P4100DVD
I don't think you install the green and blue wires to the actual deck itself you just plug the aux cord from the pac into the back of the deck the otherwires depend on your car
Nov 22, 2009 | AudioControl PAC SWI-PS - Pioneer and Sony...
Scrolling function does not work at all on my new lattitude e5500. driver is current from dell website
1 Check that the touchpad driver is actually installed and it's not using the Microsoft PS/2 driver
2 You may need to re-install the driver
3 If the above is correct check the Comtrol Panel>Mice and PPointing devices. On one of the tabs there will be Use Scroll Function (on the Inspiron it's in "gestures")
Jul 11, 2009 | Dell F3534 Touchpad
Is this a multi region dvd player disc?
not sure about multi regional player disc - if this is a standalone player then there are remote control hacks you can use as per videohelp.com website and if that does not help and this is another type of dvd player ie PS 2 or otherwise then it depends
Jun 28, 2009 | Panasonic SC-HT940 System
Need a new plastic pitcher for our villaware 5787 Smoothee
Got the number from your website and called direct to VillaWare...waiting to see if it arrives safe and sound, thanks so much!
PS...There are only a few left of this now discontinued model, so I'm glad I called (and I ordered 2 more instead)
Jun 01, 2009 | VillaWare 5787 Double Smoothee Work Top...
Changing ballast
Here is the link for wiring Lithonia Power Sentry Ballasts: http://www.acuitybrandslighting.com/Library/LL/documents/Installation%20Instruction%20Sheets/PS.pdf
Hope this helps Sparkylikes480
Mar 27, 2009 | Lithonia Lighting Psq500 Power Sentry...
Broken cardholder on IBM Selectric II
Actually it depends on when it was made, IBM used 2 Different versions of card holders on the Selectric II model, On early models the plastic piece is attached to a metal bracket that is screwed on to the print assembly, later models the plastic piece just snaps on, It is easier to get either style in and out if you remove the Platen first. The styles are not interchangeable, So you need to know which on it takes before getting a replacement.
Aug 12, 2008 | Office Equipment & Supplies
Install a new keybord
Unplug your current old keyboard, plug in your new keyboard. Two types of connectors: PS/2 or USB. Depending on your keyboard brand, go to that vendor website and download that keyboards software (optional).
Cheers,
May 14, 2008 | Computers & Internet
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
