Question about LG 50PG20 50 in. Plasma HDTV
Turning on tv and it turn off once you push power on
  • 822 Answers
Needs new caps on power supply board...
.cheap n easy fix if you can use a soldering iron........
normal lg fault......
cheers
Posted on Apr 05, 2011
How do i turn on the tv without a remote
look on the screen sides or under the tv there should be a power button. push that once to turn the tv on and off
Oct 11, 2015 | Element Electronics Televison & Video
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
I need the code for a philips tv
1. turn on your Phillps T.V. 2. Press and hold the setup button (underneath the power button) until the red light stays on. Release the button 3. Push the "TV" button on the remote once (red light sohuld go off) Press the on/off button slowly as long as it takes until your T.V. turns off. 5. Push Enter once to save the code.
Jun 24, 2011 | GE JASRM24912 Remote Control
Aquos model LC46D64U...approx 2 years old..Won't power up and get the power light flashing 3 times then the OPC light once..which is repeated...Any ideas...I believe this is quite common with Sharp TV's
I have a Sharp LCD 46 in.tv do this often.Yes,it is.This problems,the tv Tuner signal board have problem,but the tv is still useable.The POWER and OPC light indications flashes.Just push the power switch again,wait see tv turn,not POWER and OPC flashes again,push the power switch agian and wait.Have to do this like 3 or 4 times sometimes,than the tv backlight will come on,tv will work.Don't know but,if u require to pushing power button more 10 or 12 times,the tv Tuner signal board don't take an turn on the tv backlight get the tv to work.The Tuner signal board is dead,time to replaced the tv Tuner signal board.
Oct 18, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
TV will not start easily. Akai LCT2721AD
You only have to unplug it for 30 seconds. Also, make sure it does not have a DVD in it when you turn it off as the TV will try to default to the DVD all the time. Resetting the power (I use a surge protector) allows it to turn back on normally. Based on the comments I've seen this TV has terrible sound with DVD, doesn't want to turn on, and is hard to mount on a wall.
Nov 18, 2009 | Televison & Video
Power problems
You have bad capacitors in the power supply.
Sep 03, 2009 | RCA D52W135D 52 in. TV/DVD Combo
Insignia TV code for RCA Universial Remote Control (RCR450)
If its a four digit code remote. I may be able to help.. Try these...0171, 1204, 1326, 1517, 1963, 2002..
Good luck
Nov 11, 2008 | RCA 4-in-1 Universal Remote Control
Remote
do u kno the model # of the remote if so u can find the codes on the internet
Oct 28, 2007 | Durabrand DWT1905 TV
Hughes Remote works the satellite but not the TV
You have to push and hold down TV and Mute button (for 2 seconds at the same time), then release them at the same time, then push channel up until the TV turns off.  Be patient and continue channel up until the TV turns off.  When it turns off, then push TV again to lock the code.
You were doing fine, but missed to push channel up to fine the code.
Oct 25, 2007 | Hughes HRMC11 Remote Control
LG 50PG20 50 in. Plasma HDTV Logo
63 people viewed this question
Computer Repairing
Computer Repairing
