Question about Car Audio & Video
How do you disable the alarm/imobisre on a peugeot 306 1.9tdi p reg nobody knows the number to type in the key pad
conniefisch
  • 58 Answers
SOURCE: enable wireless card and key number pad
To turn wireless on (or off) press the Fn and F2 keys together.
To enable (or disable) the number keypad, press the Fn and "scroll" keys together.
Here is the online manual for your laptop:
http://support.gateway.com/s/Manuals/Mobile/8511184.pdf
If this solution worked for you, please don't forget to rate me! :) Best of luck.
Posted on Dec 12, 2008
SOURCE: key pad wont let me type the same number or letter twice
my-space,up,down,enter,backspace-get-problem-please-hwo,help,me
Posted on Feb 27, 2009
SOURCE: disable alarm 1999 dodge intrepid
HOW DO I MANUALLY DISABLE THE ALARM FOR A 99 DODGE INTREPID
Posted on Jul 08, 2009
  • 250 Answers
SOURCE: I have lost my peugeot 306 radio code , Please help
ebay sells the unlock cd, less than a fiver and emailed in minutes, u can unlock any 1s radio for a fiver then.
Posted on Aug 16, 2009
  • 4793 Answers
SOURCE: peugeot 306 cabriolet R reg.
attach a wire to the poss side of the battery and touch the horn terminal,if it sounds then you have a fuse problem,if not replace the horn....
Posted on Sep 21, 2010
Disable alarm
plasma torch, it first.
no.
use back up keys,
nobody has just one key. or gets stranded, easy.
i keep a filed down key in my wallet for over 50 years.
boyscoutes rule. "be prepared" is motto.
if horn blasts do like crooks, cut the horn wire.
Jan 02, 2014 | Toyota Avalon Cars & Trucks
How to stop a panic alarm
There are thousands of alarm types out there, the only real way to know for a specific alarm is to look into the owners manual that came with the alarm system.
MOST ALARM SYSTEMS WILL STOP THE ALARM WHEN YOU PUSH EITHER THE LOCK, OR UNLOCK BUTTON.
Some also shut off when the key is put into the ignition and turned on.
On some really secure type model alarms, you may have to find & press the reset button for 5 seconds, or press the button and insert the key. (these switches are sometimes hidden since they can override the alarm)
If it's an aftermarket alarm only type system, you can always find the main power supply to the system, or the fuse and disable it.
If it's a factory system, or one installed to immobilize the ignition/fuel system, then pulling fuses isn't an option as it will disable your ignition on the vehicle.
Most do go off in about 1 minute if left undisturbed, then rearm.
Mar 26, 2012 | 2003 Mazda 6
Changed battery on Peugeot 306 Cabriolet R reg - now lights flash every time door is opened - alarm sensor ?
if you look on the steering column thete is a square button you need to get in the car with the door shut, press this button while switching the ignition on, this will turn the flashing lights off
let me know if this helps
cheers big mike
Apr 07, 2011 | 1991 Peugeot 405
Peugeot 306 cabriolet R reg. no sound from alarm, but lights flash when turning it on with remote key. horn also not working.
Sep 21, 2010 | Peugeot Liberte Cars & Trucks
I need the radio code for my peugeot 206, v reg
Hi
If you contact the peugeot dealer and give them the car reg number or chassis number, providing the radio is a standard peugeot radio they should have the code. its about £20 I think alternatively look copy and paste the URL or click http://shop.ebay.co.uk/?_from=R40&_trksid=p3907.m570.l1313&_nkw=peugeot+radio+code&_sacat=See-All-Categories
There are many people on ebay who can decode the radio if you know the number on the side of it.
Hope this helps
Regards
Dan
Jun 21, 2010 | 1991 Peugeot 405
Ive fitted a new battery in my peugeot 306 P reg diesel and a small interior light is flashing and Right headlight flashes for approx 30 seconds? i dont know how to re-config ? help wud be much appriciated
there should be a switch on the steering couling with a pic of siren symbol on it
you need to sit in the car with door shut
press the button while switching ignition on
this should reset alarm
Nov 12, 2009 | Peugeot Liberte Cars & Trucks
I have a M reg Peugeot405 Automatic saloon The
Hi Alan Yes you are right the alarm will go off unless the battery is that flat that it doesn't have enough power to sound the alarm. This is the old catch 22 situation. Have a pair of grips and a 10mm spanner ready to minimise noise time. If you have the radio code, you can unlock it with the key, pop the bonnet, and disconnect the Negative lead with the green thumbscrew and pull it off the terminal first to reduce the risk of shorting, also tends not to spark as much as the other way, then when you come to disconnect the Red Positive, theres no way you can short your spanner to the vehicle earth. Ahhh, Silence! then remove the Positive lead and charge your battery, remove the cell plugs to let the hydrogen gas escape, and make sure its well ventilated, otherwise, BANG could happen, unless its a sealed battery, then don't worry. Once its charged reconnect in the opposite order, but be ready with your keyfob, or better still have a mate ready as soon as you hear the alarm, lock then unlock. Then just re-enter the radio code by pressing the respective number buttons. If you don't have the code, you will need it reading, usually about £10 - £20
Oct 01, 2009 | 1991 Peugeot 405
Disable passenger airbag on 1998 Peugeot 406
hi there should be a lock barrel somewhere in the front of the carit will be eithe rin the glove box, on the side of the dashboard on the passanger side, in the center console near the handbrake or to the lower right of thr steering wheel on the dashboard
with this you can use your car key to turn off the passanger air bag off (note- this will put the airbag light on)
hope this helps
Jul 21, 2009 | 1991 Peugeot 405
Disable alarm 1999 dodge intrepid
Jun 14, 2009 | 1999 Dodge Intrepid
Alarm keep going off
Try putting the door key in the passenger door and turn it to the right. This should disable the factory alarm.
Hope it helps man, drove me crazy with my '86 Vette.
Nov 23, 2008 | 1986 Chevrolet Corvette
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
