Question about Cameras
I removed the memory card from my computer and re-inserted into my Canon Elf 800. when I turned the camera on the message "Memory Card Error" appeared on the screen with the tag line "Card Locked". I tried sliding the the small slide on the side of the chip, but nothing changed. The card looks like a Micro S C.
    Brigadier General:
  • 11,967 Answers
When you removed the card from the computer, did you remember to use the "safely remove hardware" function? If not, this could be the problem. The solution is to download the pics to your computer to save them, and then format the card in the camera to erase it and get it back to original condition.
Posted on Apr 05, 2011
No pictures on camera - yet getting "memory full" message
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.After copying your photos to the computer, then you can delete the photos from the memory card using your computer.
Sep 03, 2012 | Polaroid A530 Digital Camera
Tip
How to Recover Lost Photos and Video from Canon PowerShot SD780 IS
<span> <span><img src="maggiena_8.jpg" /><br /></b></span>Canon PowerShot SD780 IS</b> may be the slimmest Digital ELPH Canon has ever created with dimensions 2.10" h x .70" w x 3.40" l, .26 pounds and 2.5 display size. It captivates the senses with bold saturated colors and a daringly original design that matches the intensity of Canon's most innovative camera technology.</span> <span><br /></span> <span><span> <p>Owning to its wonderful picture quality as well as high resolution, it becomes the first choice for many photographer lovers. One more reason that it turns out to be so popular is it supports various standard storage media like SD/SDHC, Multimedia Card, MMC Plus and HC MMC Plus memory cards</b>. images, Video and other multimedia file like songs can be saved there. Usually, keeping a backup of data like pictures and other multimedia files is recommended at the very beginning in case the data was lost by mistake in the process of using the camera. However, if you forgot to backup, you have to use a third party program to <a href="http://www.card-data-recovery.com/">retrieve Canon PowerShot SD780 IS data</a>.<br /> <p><br />Cases about losing data</b><br /> <ul> <li>1. When connect Canon PowerShot SD780 IS to your computer and being transferring vocation photos from SD card to computer, accidently your camera shut down due to low battery. After change the battery and restart camera again, you may encounter the error message "memory card error" that means the memory card is inaccessible.</li> <li>2. While reading data or writing data to SDHC card, "I/O device error" occurs and all photos and video miss.</li> <li>3. On the process of shot, message "memory card is full" pops up to you. However, after deleting some pictures, it shows the same result.</li> <li>4. Connect your SD card reader to computer, the window pops up with message "you have to format SD card before using it". After formatting SD card, all your pictures and video lose.</li></ul> <p>Resolution</b><br />If the above phenomena happen, don't panic, lost photos and video in Canon PowerShot SD780 IS are recoverable. First thing to do is stop using camera to shot for fear that the data was overwritten. For the first two cases, make sure the SDHC memory card is properly inserted. If it still can't be recognized, try to use a card reader to connect it to PC. Or else you have to format memory card and use effective photo recovery software to get back lost photos. For the last two cases, you should rely on <a href="http://www.card-data-recovery.com/">Canon PowerShot SD780 IS picture recovery</a> program. There are many effective Canon digital camera photo recovery program available in the internet, just choose the perfect one for your camera. <br /></b><br /><br /></span></span>
on Jul 20, 2011 | Cameras
The camera doesn't download pics to the computer. It reads
TRANSFERRING PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and isinexpensive. You can copy photos from other cameras and you can also downloadphotos off your memory card to someone else's computer without the need ofinstalling any programs.
May 05, 2012 | Canon PowerShot SD1200 IS / Digital IXUS...
How can I fix the
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of a working computer. The computer will see this as an external storage device, you can the open the folder on the memory card and copy the photos to your computer.
Dec 27, 2011 | Canon PowerShot S5 IS Digital Camera
My cam says "memory card
If the camera displays Memory card error or No Memory Card when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. If this is the case, you may wish to Format the memory card in the camera using the Setup Menu option [Format] as shown below. Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data. This can also be caused when images shot with another camera are stored on the memory card.
If after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service. If the card appears to be defective you may wish to contact the memory card manufacturer.
Thank you!!
Sep 04, 2011 | Canon PowerShot SX210 IS Digital Camera
The camera power is ok, the lens is ok too, but it cannot detect or sense the presence of the memory card even if it is there properly inserted already. the memory has been scanned already with antivirus,...
You may need to contact Canon directly with this problem:
Canon Customer Support Center Phone: 1-800-OK-CANON
1-800-652-2666
From my experience, there is probably a problem with the memory card. Is it brand new? The correct type for that camera? You seem to know what you are doing so that is why I am referring you to Canon! Hope this helps!
Jul 26, 2011 | Canon PowerShot A495 Digital Camera
My camera is giving me a "no memory card" sign, but the card is inserted correctly. I have taken it out, cleaned it, and put it back, replaced the batteries, and everything. However, to no avail....
If the camera displays Memory card error, No Memory Card, or takes an abnormally long time to write an image to the memory card, when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. For SD card, make sure that the card lock switch is in the correct position and not stuck in-between.Try formating the memory card ,if after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Mar 19, 2011 | Canon PowerShot S51S Digital Camera
I have a Canon PowerShot G9 camera. When i plug it into usb cord to dowload pictures, i get the error message "Communication Error" across the viewing screen of the camera.
The problem I believe is the sequence or flow of the connection.
With the camera turned off. Connect the USB cable to a computer USB port and the other end to the camera digital port turn the camera on by using the "Playback" button here is a diagram
Place diagram here
You know there is an easier and better way of transferring picture files and that's by using a memory card reader. A memory card reader plugs into the USB port of a computer and the camera memory card is inserted into the reader slot. The computer then looks at this as an external Hard Drive. Both methods will need you to format the memory card after the images have been downloaded to the computer. Formatting the memory card in the camera in which it is to be used will clean the card and making it compatible with the camera both the camera and memory card can then communicate without errors.
Jan 16, 2011 | Canon PowerShot G9 Digital Camera
I have just installed a 4 GB Sandisk in my new Kodak Eash Share C195 camera and it keeps giving me an error message - "Memory card is protected, Reset switch on memory card" I saw only one switch...
Deb,
A couple of things you might want to try the little lock on the side of the memory card should be in the unlock position. If you are still getting the error message then shut off the camera and remove the battery and the memory card. Insert the battery after about ten seconds should and install the memory card then turn the camera back on. Format the card in the camera NEVER format the card in your computer, format the card over deleting single images. If this camera is new, new then you should have the instruction manual or may be called the owners manual look for formatting instructions, every digital camera has a format feature to clean the memory card. Now if all this still doesn't work you may need to update your camera software. My Canon Pro camera gave me a headache when I went from a 4 gig to an 8gig card it just wouldn't acknowledge I even had a card in the slot. However you may just need to hard boot it after switching the memory card to the unlock position. Don't forget to format the card. Robert
Dec 17, 2010 | Cameras
Memory card error
Check the slot and see if the pins inside are fine, no breakages, free from dust etc. Try turning the camera on and off (completely remove batteries etc).
Mar 03, 2008 | Canon PowerShot A530 Digital Camera
Cameras Logo
21 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
