I have a dukane PA system for a detention center. The model number for the Audio/control Panel is PN 1A957. The problem is that I can't get the speakers to act as microphones like they are supposed to. I think there is a voltage issue. The system has a control panel and 4 switch/call banks (with 25 toggle switches per bank). I can receive an alert and talk back to the calling party but I can't hear them. Sometimes the receive audio will work but most of the time it doesn't. I measured the voltage going into the call banks and there is -12 VDC. I can't find any documentation or manuals on this product because of it's age. I think the problem is the wiring considering how much work has been done on the site. So I need to know how the system works and what is expected to happen when calls are made.
  • 6 Answers
SOURCE: speakers don't work
According to Dell, the power Adaptor is probable bad. Have the speakers replaced.
Posted on Sep 24, 2006
SOURCE: GMP33000S
Hi, I had the same problem, MiMusic wouldn`t even recognise there was a disk connected although I could see it in My Computer.Found the answer on internet.
Attach it to your p.c. Then go to My Computer and highlight it. Right Click it and a box will appear . Go to FORMAT and format it. Another box will appear and ask if you really want to do it as data will be lost. Answer YES. Then format it. Disconnect from your p.c. Turn it on and you will be able to access the menu facility. Follow the instructions and goto CREATE LIB, BEFORE you put any music on to the thing.
I found it created library as soon as I disconnected it. BACK UP anything you have on it first as it will be wiped. It is working perfectly now and MiMusic is too. Yippee. Pat.
Posted on Nov 28, 2007
ctf1800
  • 4402 Answers
SOURCE: creative zen stone plus w/ speaker microphone won't work
did someone poke a pin into the mic to disable it?
Posted on Feb 19, 2008
  • 230 Answers
SOURCE: Rio Riot
Have a try with this one:
http://www.digitalnetworksna.com/support/rio/downloads/rmm/Rio_Software_Ver260.exe
Although not officially available (or supported by DNNA) for the Riot, it happens to function with the Riot as well as newer players. Potentially later updates to RMM might break support with the older players.
Posted on Apr 20, 2008
SOURCE: mp player says file system error will not do anything
Try treating your MP3 player just like it was a flash drive (which it really is, sorta). Hook up the USB, "explore" it, and then "format" the drive ("k:/phillips" in my case).
Posted on Mar 12, 2009
Aai have the following AKAI Audio Stereo System and no Idea how to connect them. Please help Akai Model AP-D210 turntable Akai model CS-F14 Stereo cassette deck Akai model AT-K110 Fm Am Tuner Akai...
In general, outs to ins.
If nothing else, get the manuals for the preamp and the EQ. You'll probably have to pay for them.
Google it.
Akai PR-A04 preamplifier << This is the control center and where everything comes together.
Akai AP-D210 turntable (ONLY to jacks that say "PHONO"
Akai EA-G40 Stereo Graphic Equalizer (in the Tape 1 Out/In set)
Akai CS-F14 Stereo cassette deck (in the Tape Out/In set of the EQUALIZER) *
Akai AT-K110 Fm Am Tuner (to the Tuner inputs)
Akai DT-100 Audio Tuner (to the Aux inputs)
Akai PA-W04 Amplfier (to the amp outputs)
* This will allow you to Equalize the Tape on the Record or the Playback side.
Read some audio magazines or websites. Get to understand Tape Monitor Loops.
Don't use excessive EQ.
Mar 17, 2011 | Akai Audio Players & Recorders
How do you replace a battery in an Anchor Liberty 4500 PA system?
Here is the link to the manual if you don't have one:http://www.google.com/search?hl=en&q=Anchor+Liberty+4500+PA+system+battery+power+replacement&btnG=Search&aq=f&oq=&aqi= It appears as if you have to remove the entire control panel to replace the two batteries. You probably have to use exact replacements. THe link to the company is in the manual and they can probably give you more information. Hope this helps.
Nov 26, 2009 | Anchor Audio/PA Systems: Liberty Sound...
How can I connect my P.A. system to pur phone system? cheaply easy Phone is NEAX PBX P.A. system is basic pre-amp output (analog)
This is very tricky unless your phone system has an analog audio line input provision. It's almost impossible to introduce external audio ( from your P.A. system ) into the phone system when a phone is on hold unless the PBX system has an external audio line input. If it does, all you need is a standard 600 ohm to 600 ohm audio transformer where you connect your P.A. systems preamp signal out to one side of the transformer and the other side of the transformer to your PBX systems external audio ON-HOLD line input.
Aug 31, 2009 | Audio Players & Recorders
I'm looking for a wiring diagram for dukane speaker transformer
This is a 2-watt line-to-voice coil matching transformer used in 25- or 70-volt public address ampliier systems. (I only saw your question recently.) Take a look here:
http://www.epanorama.rackhost.net/schematicsforfree/Audio/Products/PA/Dukane_710-3085_Transformer_Hook-ups.pdf
May 15, 2009 | Alpine Car Audio & Video
Sears Kenmore Elite Oven 790.99123405 Caught Fire!!!
The PF indicates a power failure.
The range experienced a loss of electrical power.
This code is usually cleared by pressing the CLEAR/OFF button.
If you continue to get this code, you may need to unplug the range and check the wiring connections of the power cord on the back of the range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 12, 2009 | Kenmore 99123 Electric Kitchen Range
Aiwa Shelf system volume control doesn't work right
The part in question is called an encoder. I have had to replace this part on a number of Aiwa units. If you can post the model number off of the back, I''ll get you the part number.
Dan
Oct 01, 2008 | Audio Players & Recorders
Sound Quality
I also have a Samsung 46 inch HDTV and have the same problem. I reported it to Samsung. They sent out a repair man who replaced the entire audio system... I did not help at all. Sound quality still very bad. Hard to understand audio voice on most movies. Is there a solution short of installing an additional home theatre system?
Apr 06, 2008 | Televison & Video
Adapting a 4 channel pa system to plug into a marantz cd310 digital recorder
What is the new Pa System Brand and Model. I am almost certain that every PA System sold has a stereo or mono out put and yes there are adapters to go from mono to left and right (stereo ) on your CD310 recorder. So, the simple answer is to look at the manual or even the back of the mixer to fins out where the audio is coming out of the mixer. The mixer on the pa system will mix the sources together for you. So, you might not need much of anything but a cord to get the audio to your recorder. You can send me the model number and I can give you the exact cord you need or you can take it to a near by store that sells audio pa systems and show them what you have and what you are trying to do and they will sell you a cord that will solve your issue.
Oct 30, 2007 | Marantz PMD670 Desktop Digital Voice...
Toshiba ct-90157
What is the model# you own, for your TV along with yout satellite system box? MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Feb 27, 2007 | Toshiba CT-90157 Remote Control
176 people viewed this question
 Grubhead
Grubhead
