Question about Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens
I have an EF 70 - 300mm USM IS canon lens that focuses extremely slow, what do I need to do, I checked it with another camera and the symptoms stay with the lens, all other lenses focus at normal speeds
jackboy
  • 2985 Answers
SOURCE: Canon Rebel XT Auto focus Error 1 Problem HELP
This is a camera body contacts problem Canon Customer support will advise what to do next
Posted on Jul 22, 2007
  • 7 Answers
SOURCE: Canon digital camera will not focus
Check your diopter adjustment. It should be a small wheel on the upper right of the viewfinder. It is designed so that people who normally wear eyeglasses can use the viewfinder without their glasses, but it can occasionally get bumped. If the diopter adjustment is way off, it is like looking through someone else's eyeglasses!
Posted on Mar 18, 2008
SOURCE: My camera lense will not focus automatically or manually.
There is no battery in the lens.  The lens receives power from the camera. Whether or not the lens is getting power, though, you should be able to focus manually.
When you say you can't focus manually, do you mean that you can't turn the focusing ring on the lens, or that when you turn the ring the image does not come into focus?
If you decide the lens needs to be repaired, I recommend sending it to Canon.  You can go to their website (canonusa.com if you're in the US), click on support, and follow the links.
Posted on Dec 26, 2008
  • 119 Answers
SOURCE: looking for a manual
I coulnd't find a manual. I did see a detailed specification page here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=150&modelid=9996#DownloadDetailAct
It shows no manual is available for the lens.
Posted on Jul 18, 2009
t00nz
  • 4738 Answers
SOURCE: My Canon PowerShot SD1000 won't focus. Most
Sounds like you may not be in "Auto" mode. Press the "Func/Set" button, then press Right or Left to select the "Auto" mode.
Posted on Nov 01, 2009
Canon EF 100-400 not auto focusing
It is probably a broken ribbon cable in the lens. It will need to be replaced.
Dec 18, 2012 | Canon EF 100-400mm f/4.5-5.6 IS USM Lens
Canon EF 70 -200mm F2.8L IS USM will not auto focus sometimes (using a 2x converter)
Check out the Canon guide for converters Some will not auto focus with a converter and you can only use manual focus
Nov 28, 2010 | Canon EF 70-200mm f/2.8L IS USM Autofocus...
Cannot auto focus
It sounds like the circuit board flex has gone bad, It folds back and forth when you zoom the lens, And needs to be replaced by a repair shop and readjusted. Tony
May 26, 2010 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
18-55 lens not doing auto-focus
I offer you to buy Canon EF 24-105mm f/4 L IS USM Lens. This gives very good performance for your studio work and specially for portre. It has Image Stabilization and Ultrasonic Motor. Other professional lens are very expensive. It has red ring.
Please check the link below.
http://www.the-digital-picture.com/Reviews/Canon-EF-24-105mm-f-4-L-IS-USM-Lens-Review.aspx
Regards
Apr 13, 2010 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
USM Motor Problem?
check the stablalizer setting on camera. could be on continous setting instead of on demand.
Mar 24, 2010 | Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens
Canon EF 75-300mm f/4-5.6 III USM Lens Auto focus motor keep working back and forth but lense is not able to stop on focus right. Had eror 01 also sometime with manual focus.
If your AF motor is hunting then the lens probably needs to be looked at. I wouldn't recommend this as something to do at home so you will need to either find a repair shop if it is out of warranty or return it to Canon if it is in warranty.
Jan 17, 2010 | Canon 75-300mm f/4-5.6 III USM EF Lens
Autofocus on my Canon 28-135mm f/3.5-5.6 EF IS fails
Hello. First, check the contacts on the lens mount--you're looking for bent pins, oxidized(odd-colored) metal, damaged contact points, etc. The camera must communicate reliably with the internal circuitry of the lens unit. If there is any dirt, moisture, intermittent contact going on, the sensitive focusing electronics will be effectively blinded. If all is fine with the contacts, then the problem lies with the circuits in the lens that provide critical focusing data to the camera. Movement of certain parts causes electrical changes to occur at a calibrated rate--if the camera loses connection, it can't tell if the lens is actually adjusting. You'll have to send the lens in for repair--http://www.usa.canon.com/consumer/controller?act=SupportIndexAct. This address should get you started.--Hope I helped!---Rick
Mar 19, 2009 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
Dec 20, 2008 | Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens
Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens Logo
21 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
