Question about Admiral Washing Machines
Smells like belt is burning in 1st load of laundry. smells hot
  • Admiral Master
  • 3,289 Answers
The belt or belts transfers power from the motor to the transmission and pump. If the belt fails, the washer will be unable to pump out the water in the drum nor will it be able to spin the drum or operate the agitator. The washer will sound as if something is running (the motor) but everything under the lid will remain motionless.
The belt is a replaceable part. If you smelled the belt burning, chances are it has been stretched or is missing chunks and is damaged. It should be replaced after unplugging the washer and disconnecting the supply hoses. Next, determine that nothing is jammed and everything moves as it should. This would be the pump and the transmission. You'll probably have to turn the washer on its side to access the belts. Be prepared to mop up water that will spill once laid on its side. If pump or transmission is jammed, the motor will probably burn up the new belt, too. Make sure nothing is preventing the agitator from working - this could be clothing wrapped around / under the agitator. It is possible that something has become lodged in the pump housing. You won't be able to see it - but you should be able to turn the pump - if either of these won't turn, you'll need to get them turning freely before you can expect the motor to spin the belts.
I hope this helps and good luck! Please rat emy reply. Thank you.
Posted on Apr 05, 2011
My wife put a load in last night and a couple of hours later the laundry room smelled like something was hot and the washer had stopped on the spin cylce. The control panel didn't feel hot but I unplugged...
Something caught in pump & belt burning. Motor start capacitor (If fitted) is US & needs replacing. Timer faulty, motor has burning smell, replace timer & or motor. Motor switchgear failed motor sitting there & humming, adjust switchgear or replace motor.
Dec 19, 2013 | Maytag Atlantis MAV6000 Top Load Washer
The bearings have been replaced but now it is smoking (mostly seems from the inside) and smells like the belt is burning, but the belt isn't hot. HELP!! :)
i think this washer has a heater with doing the bearing probably wires crosed over or damaged [heater goes on and no water smokes then ] ceck your wiring on the element green is ground.
Jan 22, 2013 | Maytag Neptune MAH5500B Front Load Washer
Screeching sound; smell of burned rubber
What is the model number of the unit?
Oct 31, 2012 | Washing Machines
Washer does not spin, has a burning smell. took off front panel. motor pulley feels hot, so does belt. replaced belt 6/09. only wash one load per week. where is the burning smell coming from?
This sounds like a frigidaire washer. If it is, the belt must be the original equipment manufacturers belt. ANY other belt will just slip and burn. The fact that the pulley and the belt were both hot tells me that either the belt is the issue or your main tub bearing is starting to seize.
Mar 18, 2010 | Washing Machines
Burned rubber smell after replacing motor coupler, otherwise runs
The most common cause for the coupler failing is a bad gearcase. The machine should go through a neutral drain before the spin if it doesn't drain the water first it over works the motor trying to spin a full tub. No belt on this one, odor could be from the motor or the coupler starting to shred again.
Mar 01, 2010 | GE Spacemaker Washer and Dryer Electric...
Burning smell at end of wash
could be the belts but it could also be the motor depending on the smell
Jun 04, 2009 | Kenmore 22622 Top Load Washer
Washing machine + burning smell
The load of rugs may have been too much for the device and there may have been considerable belt slippage causing the burnt rubber smell. Try another regular load and cross your fingers. And stay away from those outrageous loads!
Sep 06, 2017 | Admiral AAV7000A
Dryer drum wont turn- burning rubber smell
could be a stuck gear box. burning rubber smell is coming from the belt sliding .
or the belt is just loose and can not turn the drum to spin it.
tnx 4 using fixya,
drcool
Oct 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
My maytag washer has a burning smell.
What model do you have.?It doesn't sound like it was spinning.A frozen pump would make the belt burn and it would leave some water in the tub .
Oct 18, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
80 people viewed this question
Top Admiral Washing Machines Experts
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
