Question about Mipro Audio Players & Recorders
The problem of my mipro MA-707 is no power signal..
Mipro ma 707 has no voulme power
Posted on Aug 27, 2011
Just installed MDI ignition upgrade on kohler command 27. Followed instructions and have no spark.kit is 32 707 01-S.
Just making sure you have the correct part.
According to the Kohler bulletin, The 32 707 01 S is used with engine model number - SV735/740/840.
Jun 01, 2014 | Electrical Supplies
What is a D's 707? How do I operate it? How can
Don't know
http://www.vintagecassette.com/Hitachi/D-707
How about a little more detail?
Post back in a Comment
Regards,
joecoolvette
Apr 18, 2013 | Computers & Internet
Hi there, I have a MiproACT-707 TM, which i use while teaching aerobics classes. After working perfectly for about 10-15 minutes - it stops working completely. This happens with brand new fully charged...
Hi, I would first ask if you are using a Ni-cad rechargeable battery system, these are not optimum performers for such a high drain microphone as probably the one you're using. Especially if the mic. takes a single 9 volt battery ( the average ni-cad 9 volt is about 200 milliamp hours, not a lot. If so-try switching to nickel metal hydride ( Ni-Mh ) these are better for high drain devices and do not develope a " MEMORY " effect ( which will cause rather sudden power loss ) memory effect can happen to almost brand new batteries as well, all it take to incur this is to charge a Ni-cad before it is totally dead. good luck, and thanks for choosing FixYa-Prodzilla
Apr 20, 2011 | Mipro Audio Players & Recorders
Roadmate is stuck at a location that we have long left. Signal is strong . Tried turning off For a while, tried changing destination but gps is not reading our movement. Help We are in the middle of...
Try a hard reset which involves finding a small pinhole on the back a pressing it with a paper clip for approximately ten seconds. It may be labeled reset but only a very thin item can press this button. If that doesn't work then you may need to call the magellan help service 1 800 707 9971
Mar 07, 2011 | Magellan GPS
I need value for R 707 ( resistor on 14v power
You can order a service manual from the manufacturer.
Jun 03, 2010 | Technics SA-EX500 Receiver
I have a kenwood vr-707 it gets surround sound on dvd/vcr but I can't get surround sound on just tv.
Well you have a built in decoder/surround processor that will detect a signal with the surround sound info(dvd/sat.receiver/cable converter etc.) and will then process it to the different speakers on your system. In the absence of that signal it will process it as standard stereo sound(two front speakers). You may want to look in your receiver functions/menu for simulated surround.
Hope this will help.
Nov 24, 2009 | Kenwood VR-707 Receiver
Where is the on/off switch? It is plugged in but no power
I believe, through searching, that this is an Accton.com.tw (accton.com) product. Having trouble find this model, is it old?
Probably doesn't have a power switch. I found a manual for 3016A:
http://mars.accton.com.tw/ww/accton_manuals.nsf/0/a216d6504b9202f7482566d5003337ef/$FILE/eh3008a_16a.pdf
And it just says plug the power cord in.
* Anyway why would you need a power switch for a switch-hub? Once it gets plugged in it pretty much stays on all of the time.
Of course you have no power. You're unit is probably dead for some reason or the other. Maybe you could open it and look for a fuse or other power supply problem? Assuming you have no warranty on it. If you do have warranty then you should pursue the warranty path for help with it. They seem to have USA support information.
Internet: support@accton.com.tw
USA Headquarters
P.O. Box 51420
Irvine, CA 92619-1420
Phone Numbers -
Sales: 949-707-4800 or 888-398-2101
Support: 949-707-4847 or 888-398-4101
RMA: 949-707-4828 or 888-398-3101
FAX: 949-707-2460
"Why couldn't you just find a nice Japanese Girl like all of the other white guys here?" --- Quote from the movie Fast and Furious: Tokyo Drift.
Nov 22, 2009 | Accton CheetaHub Power 3016P (EH3016P)...
Receivers complain about squeeling noise from my midland 1001z when I transmit. Is this an RF Gain setting problem?
I had the same (squealing) problem on transmit with the Midland 1001Z when I used it indoors as a base unit. The problem was my power supply: it broke into oscillation when drawing more than 150 mA at 13.8V. The 1001Z draws about 150 mA on Receive, and much more (but only about 900 mA) on Transmit. If using the 1001Z as a base unit, I suggest you power it with a fully-charged car battery indoors, or test your power supply to check if it can't supply the required 1 Amp, approx., on Transmit. It's a GREAT radio, just give it a good power supply. My power supply was defective out of the box, but now I have a good one and get great reports on signal strength and audio quality. Remarkable, for the low price and 3 year warranty. Good luck!
--Sky Junkie / Tucson, AZ / USA
Sep 27, 2009 | Midland 1001Z 40-Channels Base CB Radio
CAN I ADD AN ECHO OR REVERB TO INPROVE THE SOUND
Well, I don't think you can add Reverb/Echo Internally but Externally.
External Echo/Reverb unit is available but most of them are AC Operated but Mipro MA-101 is Rechargeble Battery Operated.
You may be able to find Battery Operated Reverb/Echo units but they are usually Line Drive (not a Microphone Drive).
Go to a Music instrument store or a Guitar store.
Usually they have ton of these.
Though, You will not improve the sound much at all by using Reverb/Echo unit since you are very limited by quality of the amplifier itself too.
Jan 30, 2009 | Mipro Audio Players & Recorders
Replacement ad/dc power cord
you can get a replacement ac/dc power cord for durabrand portable dvd player model # PVD-707 here;
http://www.acdapter.com/DURABRAND_PVD_AC_ADAPTER.html
Dec 11, 2008 | Durabrand PDV-705 Portable DVD Player
216 people viewed this question
Top Mipro Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mipro Audio Player and Recorder Expert? Answer questions, earn points and help others
