Question about Garden
I have a makita JR3000VT recripricating saw, i dont know how to change the blade in it
    Novelist:
  • 157 Answers
Hello. Here is a link to the product manuals. pg 7 of the owner's manual shows a decent visual on changing out a blade. Hope this helps.
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=243
Posted on Apr 06, 2011
Change blade Makita LS1030 10-Inch Compound Miter saw
There is an 8mm bolt on the front of the guard. Loosen/remove this and the central guard mount will drop slightly. Behind the metal guard is a slide lock for the blade spindle. Push the lock bar and turn the blade untill it catches and is held solid. Then remove the blade fixing bolt and bobs your uncle. Alternativly, with all mitre saws, you can just pop an old bit of wood on the work base and then use the spannrer/allen key supplied to turn the blade so it bites into the wood as if you are trying to cut it. This will hold the blade steady and you will also be turning the bolt in the right direction.
Jul 23, 2012 | Makita 10" Miter Saw LS1030N
MAKITA DROPSAW MODEL 2400B HOW DO I CHANGE THE BLADE
There is a push-in lever located between the handle and saw blade.
Push in lever and rotate blade until blade locks.
Once blade is locked, loosen nut located in center of blade.'
Before removing blade, notice direction of teeth.
Install new blade with teeth going same direction.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 18, 2011 | Makita 10" Miter Saw LS1030N
How to replace saw blade and re assemble the blade guard
Hello. The guard does not have to be taken apart when changing the blade. Here is the link to the Parts Breakdown of your unit. It should show what you need to know to reassemble your saw. If not, use the contact information to speak to customer service and they should be able to assist. If this is helpful, please rate it a four-thumbs up, Thank You.
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=370
Oct 10, 2010 | Makita 10" Miter Saw LS1030N
How do I install the spring after changing the blade on the Makita 10 miter saw
what spring? do you mean the one in the guard? if so you don;t have to remove it to change the blade, give me the exact model number or you can go to makitatools.com and download a breakdown that shows the reassembly of the guard, it is not that hard, and also you can download an owners manual that shows the proper blade replacement procedure.
Jan 16, 2010 | Makita 10" Miter Saw LS1030N
I have an old Makita table saw and need to change the blade. It is a circular saw mounted under a table. I can't find the stop that allows me to unscrew the fixing nut on the blade. It is Makita Model...
This link will take you to Makita and display an owners manual where you will see that the saw should have came with the necessary wrenches to change the blade. If they are not available I have used two different methods. Take care with either, that blade is just waiting to getcha. 1. I have clamped a pair of vice grips directly on the blade and let them stop against the saw top to keep the blade from turning or 2. I have levered a peice of soft wood against the blade to keep it from turning. According to Makita the thread is righthand, so you can apply the righty tighty lefty loosey rule to determine which way to loosen the nut. Good luck I hope this helps.
Nov 22, 2009 | Dishwashers
Makita 10 inch slide miter saw problem
Is this it? If not, go to Makita site & download image of your saw. Hope this helps:http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_LS1214FL.pdf
Jul 06, 2009 | Makita 10" Dual Bevel Sliding Compound...
Garden Logo
153 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
