Question about GE Spectra JBP78 Electric Kitchen Range
Need touch up paint for ge spectra stove, white
fridgetech
  • 473 Answers
SOURCE: ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Posted on Oct 22, 2007
  • 1314 Answers
SOURCE: GAS STOVE
yep replace the bottom ignightor take out the rackes remove the two bott screws in the oven remove the bottom plate and just keep going down
Posted on May 21, 2008
RescueTech
  • 145 Answers
SOURCE: Bake ignitor Location
Hi Kurt, welcome to FixYA!
In the diagram below, Part #28 is your ovwn ignitor. (See the red markings to highlight it)
It is located underneath the oven floor, and the floor should come out by removing the two screws located in the bottom rear of the oven cavity. Take out the racks, take out those two screws, and lift the oven bottom up from the rear, then disengage the front lip and lift it out. I hope this is helpful info and thanks for allowing us to be of service to you.
a16646a.jpg to you.
Posted on Dec 23, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE Spectra flat top stove electrical short
Go to your electric circuit panel. Locate the breaker for the stove. Turn it all the way OFF then back ON. This should correct your problem.
Posted on Aug 18, 2009
Testimonial: "Spot on advice. Thanks so much for the help!"
  • 61 Answers
SOURCE: How do I replace the ignitor for the stove top of
if you need a part check out www.appliancepartssolutions.com cheep parts ;)
good luck
Posted on Jan 21, 2010
Ge stove spectra
sounds like a bad infinite switch.
Mar 11, 2014 | GE Kitchen Ranges
Replacing outer glass of oven door
This is glass because glass does not burn, does not melt at oven temperatures, and is a pretty good insulator. Also allows the cook to watch the cake rise.
I would not replace with anything but factor glass. Too dangerous, even regular glass is not properly treated to be safe in this environment.
The cash for clunkers gets extended to appliances soon, perhaps this makes a new one more affordable?
Aug 24, 2009 | GE Profile Spectra JGBP85 Gas Kitchen...
Ge xl44
there is switch behind the knob it most be wet or it needs to be replace they are call,top burner valve switches. white in color plastic.
Nov 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE PROFILE RANGE TOP
psnowden this can happen. If I remember correctly GE is using a Hi Temp paint, not porclean, on this range. And if they are using porclean, it is a thin coating. With current ranges the cooking oil gets into the finish and runs the heat up causing the finish to lift. The is espically true with white. The gentlest clean will in time not stop this from happening. You can get some hi temp touch up paint to make it look better, however it will keep doing this, espically on the burners you use the most.
Feb 03, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Self cleaning cycle
Between 3 and 5 hours. Most likely 3 hours unless yours has the adjustable setting for cleaning, then you can clean longer.
Jan 01, 2008 | GE JBP25 Electric Kitchen Range
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
JGBP79 GE Spectra XL44
Yes I had the same problem on my JGBBP79. Change the lower igniter. About $75. Keep the range for a few more years and get rid of it. The next problem you'll mostly likely have is the touch pad F1 error. That stupid thing is +$300 and nothing more than a membrane touch pad attached to some glass. :-(
Nov 08, 2007 | GE Profile Spectra JGBP79 Gas Kitchen...
GE Spectra oven not lighting
you need a new oven ignitor for bake if its a gas stove..
May 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Funny Smell
ALL YOUR FLAMES SHOULD BE CLEAN BLUE FLAMES WITH NO WHITE OR YELLOW TIPS OR FLAMES !!!! YELLOW FLAME = DIRT OR PAINT? WHITE = LACK OF AIR SOUNDS LIKE YOUR STOVE IS NOT GETTING ENOUGH COMBUSTION AIR. INPROPER AIR ADJUSTMENTS OR LACK OF AIR WILL CAUSE A WHITE TIP ON THE FLAME ... THAT IS CARBON-MONIXIDE !!! A CLEAN BLUE FLAME EMITTS CARBON-DIOXIDE AND IS NORMAL. IF YOU USED AN AIR-GUN TO PAINT, CHANCES ARE YOUR BURNERS HAVE A SLIGHT COATING ON THEM AND HOPEFULLY WILL BURN OFF IN TIME. TRY OPENING ALL YOUR DOORS AND WINDOWS IN YOUR HOUSE ... AND TURN ALL BURNERS ON AND LET THEM BURN FOR AN HOUR. DO NOT LKEAVE SIGHT OF THE STOVE, BUT KEEP NEAR A OPEN WINDOW. NOTICE !!! MOST GAS COMPANIES WILL COME OUT AT NO CHARGE TO CHECK GAS, AND FOR CARBON-MONOXIDE.(C0) NOT (CO2).
Apr 28, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra JBP78 Electric Kitchen Range Logo
80 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
