Question about Whirlpool Kitchen Ranges
Whirlpool wfw 9500 flashes F25 code - Whirlpool Kitchen Ranges
  • Whirlpool Master
  • 1,902 Answers
Hello & Welcome to FixYa
F25 is a drive motor tachometer error and is displayed when the control is unable to properly detect the motor speed. First unplug the washer and check the wire harness between the motor and the Motor Control Unit (MCU) and also between the MCU AND Central control unit (CCU). If the motor is working then the MCU needs replacement, and if the connections are fine then also replacing the motor control board is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Apr 05, 2011
Code F25 on my whirlpool washer
F25 is a MOTOR CONTROL error . check for past posts in Search as there were some in 2007 shown on Fixya . or check throgh Google / Internet explorer by stating F25 Washing Machine error
Jan 09, 2018 | Whirlpool Washing Machines
Whirlpool Duet Washer error f25
have whirlpool duet washer showing f25 code checked all connectionshave bare wires showing on rpm sensor on end of motor separated them and still showing code what else can i do
Oct 28, 2017 | Whirlpool Washing Machines
My whirlpool front load washer will not spin out. its showinf error code F25
According to the tech sheet, F25 indicates a possible drive motor tachometer error. (NOTE: The tech sheet is located behind the front quarter panel- remove the three hex head screws at the very bottom to remove the panel. The tech sheets will be folded up in a little plastic pouch. Since there a various reasons for your problem, I just can suggest starting point since there is a code displayed.
Dec 23, 2016 | Whirlpool Washing Machines
What the F25 code
Please, head over to this link, it explains by a regular user on what F25 means and it have pictures.
http://neighboursappliance.com/f25-on-a-duet-washer/
Sep 22, 2015 | Whirlpool Dryers
Loud nonice during spin cycle
Front load washer usually sign the tub bearing is failing
Sep 03, 2014 | Whirlpool Washing Machines
F25 error code
The "F25" error code means the control board senses the inlet thermistor shorted. The inlet thermistor is a part of the hi-limit thermostat which is located on the heating element box.
- The hi-limit thermostat kit Part number: AP3094323
Read more: http://forum.appliancepartspros.com/dryer-repair/54078-whirpool-duet-dryer-error-code-f25.html#ixzz2n2Rmgm7a
Dec 10, 2013 | Whirlpool WED9400S Electric Dryer
I HAVE A WHIRLPOOL DUET STEAM MODEL WFW 9600 TW01. I GET A FLASHING 'SUD' AND THEN CODE E 51. DO YOU KNOW WHAT THE PROBLEM IS? WHAT PART NUMBER DO I NEED? ANY HELP WOULD BE GREATLY APPRECIATED
Pull out your washer and look on the back for a plastic sleeve with paper in it. Often these papers are materials for the repair person. If you are lucky they are what you need to solve the e51 mystery.
Nov 13, 2012 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
I need a user manual for my Whirlpool Duet Steam Washer, Model # WFW 9500 TW 01.
You can go to www.whirlpool.com and select Owners Center, then select Manuals and Literature. Put in the model no. and you should find one there. Click HERE for this manual.
Hope this is what you need, Please rate and comment Thank You Joe
Sep 07, 2011 | Whirlpool Washing Machines
Fault code F25
If you remove three screws along the bottom front the bottom panel comes off.
On the inside, on the right wall, is a plastic bag with a paper labeled "FOR SERVICE TECHNICIAN ONLY".
This has a section titled "FAILURE/ERROR DISPLAY CODES" with all the error codes along with an explanation and recommended procedure. For F25, this is:
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
I got this working for many on this site :)
Thanks
Fame !
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the door bellows seal ?
WFW 9400SW01
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=WFW+9400SW01
and click on your model number. In the new window click on a diagram in the left-hand side of the window to show the location of the bellows seals. I believe you want the Door and latch parts diagram.
Mar 23, 2009 | Whirlpool WFW9400S
Kitchen Ranges Logo
65 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
