Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Installed dispensing pumps and put feeder tubes in five gallon pails of solution and when we activate dishwasher it leaks. Orginally the unit didn't have pumps installed and solution was added by hand. Dispensing pumps were recently installed but they did not come with instructions of installation, local distributer no help, dishwasher is unuseable at this point because of leaks.
  • 12,061 Answers
Ok you say, "and when we activate dishwasher it leaks" (sic) I presume you mean the dispenser leaks? or the pump? or the actual dishwasher?
if you mean the actual dishwasher is leaking, then maybe the door seal, or seal around where tubes enter? if this from is where it is leaking? has been damaged?
Anyway to assist you please find manuals below these will show you what to do.
https://my.hobartcorp.com/resourcecenter/.../F-8193.pdf -
www.webstaurantstore.com/PDF/Hobart%20LXiH.pdf - United States -
above are manuals to download.-
Posted on Apr 07, 2011
Water capacity kawe860w
I don't have the number for you, but I can offer a method for measuring it. First, the next time you do laundry, set the water level switch to where you will use it for the dyeing task. With the lid open, but with no clothes inside, turn on the washing machine. Observe and note the level of the water when the machine stops filling. Measure the depth of the water. Add clothes and detergent and wash in the usual manner - you don't need to waste that water.
Next, pour four gallon jugs of water into a clean five-gallon pail, and mark the level in the pail (four gallons in the pail is much easier to handle than a brim-full five gallons). Pour that into the machine, and measure the depth. Put in another four gallons of water, and measure the depth again. If the bottom part of the agitator is covered by the first four gallons, you can can calculate from the increase in depth made by the second four gallons how many more gallons you need to get to the fill depth. (The bottom of the agitator takes up more volume per inch of depth than the center and top,) If the bottom of the agitator is not covered by the first four gallons, but is covered by the second four, then add a third four-gallon pour and measure the depth once more.
Here is an example measurement: water depth on chosen load size setting: 16 inches.
Depth on first four gallons: 2 1/2 inches (some of the water is under the bottom of the inner tub). The agitator bottom taper is almost covered, but not quite.
Depth on second four gallons: 7 inches. The water level is above the bottom section of the agitator, so from this point the water depth will increase by the same amount per gallon added.
Depth on the third four gallons: 11 inches. We can now see that from this point, adding four gallons makes the water level go up four inches, so to reach the 16 inch mark,we need five more gallons. The total will be 4+4+4+5 = 17 gallons.
For what it's worth, there's about 7.48 gallons per cubic foot. If your machine's outer tub holds an additional cubic foot of water, my example numbers may be roughly what you will get.
Apr 24, 2014 | KitchenAid KAWS850L Top Load Washer
I have had water leaking from underneath my dishwasher and have found that on filling, water overflows top of the water inlet unit
My Miele 828 dishwasher started to leak at the front left corner. The leak became worse. I tipped the machine on its side and removed the rubber moulding connecting the base of the drum to the pump. I cleaned it out and refitted it finding two small coins inside. The leak persisted. I took off the top of the machine by unscrewing the two screws on either side and pushing the lid backwards. I switched the machine on and, with a torch could see that the detergent dispenser had detached from the delivery pipe under it. Using advice elsewhere on Fixya I undid the three bolts around the door and the three screws around the detergent dispenser; one is deeply recessed and easily missed. Than I unclipped the drain pipe behind the little door at the bottom left hand corner at the front. The front then hinges out from the left with hinges at the right side making the leaking connection easily accessible. Make sure you get the rubber flange well up the plastic tube as there is no flange on the tube to secure it. A possible design fault but the unit has functioned for ten years before the connection failed.
Sep 24, 2013 | Dishwashers
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Lxi hobart not pulling rinse aid i used a screwdriver across prongs on board to make it run manually but still not coming out
try replacing the "squeeze tube" inside the dispensing unit. Over time the tube flattens out. If the tube is flattened no chemical will be drawn from your jug.
Disconnect inlet and outlet hoses on rinse aid dispensing unit.
Remove 4 screws and pull off outer face of dispensing unit. You can watch the dispenser operate with the face off if you wish, as long as the hose doesn't fall out (which it won't).
Remove squeeze tube and install new tube.
Reassemble inlet and outlet hoses (be sure to not mix up which tube/hose goes on top and which on bottom).
Also possible that the hose from the chemical jug to the dispensing unit has a hole/crack or otherwise. If the hose has a leak it'll lose suction and draw air in from the leak and not pull chemical.
Nov 19, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Tub leaks, with a partially filled tub (2.5 inches measured from the lowest point over the pump assembly.) Promblem occured after the washer was idle for 3 weeks. Have just replaced the main water inlet...
I am assuming leaking when it is running, not sitting idle. Leaking from the door? Fill and run unit for 1 minute with no detergent. Open door. Are suds present? Suds turn into water when they drop to the floor. Suds can flow over the lip of the tub and drip to the floor. Oversudsing, Sometimes old detergent breakdown. Rinse aid dispenser leaking will cause oversudsing. Combination of all in one products will cause many problems. If suds are present after running unit a minute, pour a cup of cooking oil in unit. Run and fill it a few times until suds are gone. Possible most common cause is dispenser latch grommet.
Oct 15, 2010 | Maytag MDB7100AWB Dishwasher
Dishwasher leaks from bottom left corner
If its just that corner check that it is level (if not leak could be somewhere else)
Then check your hoses and valves for holes or leaks (try putting some food dye water when running to see easier
Most likely a loose hose connector or hole in the rubber hose
This hould help you
Dishwasher Basics The main parts of a dishwasher are: Control mechanism
The control mechanism is located inside the door behind the control panel. Many units use a simple electro-mechanical system: a timer determines how long each part of the cycle lasts and activates the proper function at the proper time (such as the detergent dispenser, wash spray and draining functions). Units that are more expensive might have a computerized control system. Modern units also have a door latch that must be closed for the unit to run. Some also have child safety locks. Intake valve
This is where water from the home's water supply enters the dishwasher. The unit's pump doesn't pump the water into the basin – when the intake valve opens, water pressure drives the water into the unit. Pump
An electric motor powers the pump. During the pump cycle, the pump forces water up into the spray arms. During the drain cycle, the pump directs the water into the drain hose. The motor-pump assembly is mounted beneath the basin, in the center of the dishwasher. There are two main types of pump:
  • Reversible
    These pumps switch between pumping water to the spray arms and pumping water to the drain by reversing the direction of the motor. Reversible pumps are usually vertically mounted. dishwasher-11.jpg
    -->Reversible pump
  • Direct-drive
    The motor runs in one direction, so the direction of flow is switched from spray arms to drain by a solenoid that opens and closes the appropriate valves or switches one hose connection to another. Non-reversible pumps are usually horizontally mounted. dishwasher-12.jpg
    -->Direct-drive pump
Dishwashers can be installed in either a portable or a permanent configuration. Portable units have finished sides and top that can be used as a countertop. When not in use, the machine sits in place next to the wall. When it's time to run a cycle, the unit can be rolled on casters over to the sink, where it connects to the faucet and plugs into a nearby outlet. In a permanent installation, the dishwasher goes underneath the existing countertop and bolts into place. Hoses underneath the kitchen sink connect directly to the hot water line and the drain line, and the unit usually plugs in under the sink as well. Both types of installation require a 120-volt grounded line.
Jun 07, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Pond pump trips circuit breaker
The circuit breaker trips because there is an electrical short in the pump itself or in the wire feeding the pump. A cause of this could be a bare wire, or a crack in a wire. Remove the pump and put it in a five gallon pail of water and test it. If it still trips the breaker you will know the problem is in the pump or the cord to the pump.
May 02, 2009 | Beckett Corporation Beckett Professional...
I have a Kenmore dishwasher that will not pump water through the spray arms. It fills ok and drains fine but wont go into the wash cycle? Any idea of possible problems
Look inside of the dishwasher to be sure that the tubes leading to the spray arms are not disconnected. If those tubes are in place, then the problem is with the main motor/pump in the base of the unit. That Kenmore part is about $150.00 plus labor. That being said, it may be time to consider a new dishwasher UNLESS your dishwasher is less than five years old because there is a five year warranty on the motor/pump. If it is under warranty, call sears repair and they should repair it at no cost to you.
Apr 18, 2009 | Kenmore 15762 Dishwasher
Calcium buildup in dishwasher-receiving low ampage
You at least seem to have a hard water symptom. But these two symptoms may not be related. Try putting an ice cream pail (1 gallon) that is half water and half vinegar -pour it into the bottom of your washer and run it through cycle. Do it 2 or three more times, if you notice improvement, then it was a calcium build-up. Stronger acid solutions or Lime-Away type cleaners should not be used as they can etch or destroy the internals. Vinegar will not harm you, your dishes, and will be a little gentler on your equipment. Try that first - see if your "white residue" subsides and maybe a chunk of something will pop out of your pump too. If you don't have a water softener, you may consider one. While this may not solve all your problems, it is something you can do that will not cause any real harm, and so it is a "safe" answer.
Dec 12, 2008 | Maytag 24 in. MDBH970AWS Built-in...
''GE tfx28ppcb fridge has water puddle usually on right side
I had the same problem, I found that the plastic tubing feeding the water despendor and icemaker was run right along the comperssor, over tiem the from exposure to the heat the tubing had become brittle and cracked.  the black tube shiled had to slid up to expose the cracked tube. A  new tub installed and splice to existing dispensor feed line fixed probelm.
Dec 08, 2008 | Refrigerators
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
133 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
