Question about Noritz Water Heaters
Recently had a water leak on pipeing. fixed pipeing now water heater keeps tripping breaker.
Problems may be unrelated.
Open following link for electric water heater troubleshoot checklist and resources.
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 06, 2011
My suburban dsi rv hot water keeps throwing breakers
Appears to be a short in tank circuit probably cause by a water leak in tank. These usually wear a rusty hole in the tank inside the cover and are not seen unless the thermostat covers are taken off. I would remove them and do a visual thoroughly. Anytime a fuse blows or a breaker trips is always a dead short unless you have a bad breaker. I would check those as well for vibrating, chattering noises, and/or smoking. If any of this persist, replace breaker. A melted heat element could trip them, but not usually for it leaves an open circuit instead of a shorted one.
Feb 19, 2013 | Suburban SW10DEM Gas Electric Water Heater...
Electric shower just installed cuts out at fusebox after being on for about a minute
10-20-12
Circuit breaker is tripping on electric shower?
This could be absolute danger until more information is known.
1) Breakers trip because they sense heat, because the wire size is too small, or breaker size is mismatched with wire. Or breaker is loose on busbar.
Copy following links to determine correct wiring and breaker:
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
GFCI circuit breaker will trip because of same heat condition described above, and also trip if ground fault is detected.
Water leaking into element will trip GFCI.
Absolutely you need to get this problem fixed before shower is put back into service.
Call electrician, or the installer, or the manufacturer, or all.
http://waterheatertimer.org/How-to-wire-GFCI.html#spa
Oct 18, 2012 | Rheem EcoSense by 7.4 GPM Tankless Water...
I have a reliant 606 electric water heater and I noticed that i wasn't getting any hot water. I shut the water off and look to see if i could see any problems. I cut the water on and notice that wate...
Problem is not clear:
Sounds like you have two different problems, but overheated water heater can cause both problems:
Before calling service technician, open following links for full do-it-yourself troubleshoot.
ADD A COMMENT for more details after looking at information below.
1) No hot water could be bad thermostat, or bad element, or circuit breaker is tripped.
Open following link to troubleshoot electrical problem with electric water heater:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
2) Leaking water heater.
Open following link to identify problem with illustrations and troubleshoot leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
Look carefully at illustrations on page:
If drain valve is leaking, then put a garden hose cap on it.
If TP overflow pipe is leaking, do NOT cap that pipe
Jun 27, 2011 | RELIANCE ELECTRIC WATER HEATER
I have a Rheem warrior glass water heater model number 71-30 s in my mobile home. Recently had frozen water pipes and had to take the entire water pipe from the water heater to the main water box off to...
Before I spent the money on a new heater I would check reset to make sure it did not trip. I would also check element and make sure you are getting flow thru outlet and that it did not plug up with rust and mineral .
Depending on the water quality where you live I would expect to get at least ten years use out of a electric heater. Thank you.
Feb 10, 2011 | Rheem Water Heaters
Keeps tripping the breaker. i have replaced the e...
It may be a weak breaker. If you have replaced all the components on the water heater. I would suggest calling an electrician to check out the breaker.
May 17, 2010 | Water Heaters
THE INSTA HOT HEATER KEEPS TRIPPING THE BREAKER?
Hire an electrician.  The breaker needs to be replaced or the wiring in your house is not able to handle it.  I believe most need 2-30amp breakers.
Mar 03, 2009 | Emerson Insinkerator 2.5 Gallon Water...
Water Heaters Logo
104 people viewed this question
Top Noritz Water Heaters Experts
gizmonix
Level 1 Expert
Mack Baxter
Tony Crow
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
