Question about Shimano Cycling
I need to raise the handle bars but not sure how. Its a mongoose xr 200 , 21 speed mt. bike
    Brigadier General:
  • 8,546 Answers
Http://www.sheldonbrown.com/handsup.html
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
Posted on Apr 05, 2011
Testimonial: "Yes but i undid the two srews and still cant get the handle bars off , Is the another way"
  • 1 more comment
  • David Dunn
    David Dunn Apr 05, 2011
    You have to take the top cap and bolt off, too.
    http://bicycletutor.com/adjust-threadles...
  • kjcwoodman Apr 06, 2011
    Im sorry to keep bothering you but I did try to get the cap off but seemed like i was bending it , Is there a treck to getting it off ? Thank you for all your help
  • David Dunn
    David Dunn Apr 06, 2011
    The video seems pretty straighforward. If you loosen the cap bolt and the two side bolts, grip the front wheel between your knees and twist the handlebars sideways. That should free it up. If it seems welded to the steere tube it may have corroded stuck. No excessive force should be required. The top cap and its bolt must be removed to remove the stem.
    http://www.parktool.com/blog/repair-help...
    This style of stem can not be adjusted upward since the steerer tube is cut to the length that suits it. If you need to replace the stem to get a good height just take the whole biek to a Bike Shop and let them help you review your options.
Raise the handle bars on my new mongoose bike
in the middle of handlebars you will see a hexadon bolt,when you got your new bike the right angle wrench should have been with it if so place the wreanch onto the bolt and turn anticlockwise this will loosen the nut,then pull the handlebars up until the wright is achived make sure they are straight then turn the wrench clockwise until it tightens,.Adrian....
Jan 23, 2015 | Mongoose Cycling
How do I figure out the value of my my Mongoose 26in. dual suspension, 21 speed?
Sorry about the request for more info about the bike I did not see the small print right above the How do I.
Anyway this link should help...I hope
26 Women Mongoose XR 75 Dual Suspension Bike
Personally, here in AUS bikes brought from Wallmart type department stores are very general purpose, meaning not professional, so the price doesn't hold in fact depreciates quite quickly so if you want to know for selling purposes than ask google, eBay, Amazon with words like used whether or not it has been, like unwanted gifts.
If I had to guess I'de say anywhere between $60 and $90 at best, but please feel free to do your own investigation and good luck.
Nov 02, 2014 | Mongoose 26" Ladies XR-75 Mountain Bike
The handle bar stem on my sons mongoose is loose. I have tried to tighten the screw that connects to the stem but it doesnt seem to be stopping the bars from being shaky?
Your handle bars are most likely stripped or the mongoose head is stripped or a combination of both. Unscrew the bolt you just tightened and take the handle bars off to inspect the little splined area, if smooth than handle bars need to be replaced. The neck should also have those little lines horizontally this area should not be smooth. You can try to wirebrush the area and out it back together, see if that works or the cheapest thing to replace would be the handle bars. When I was a kid I would pin my handle bars so they would not move cause we did a lot of jumping of our bikes and had a lot of stripped handle bars. Mongoose is a good stem I would lean towards new bars. Good Luck...
Aug 16, 2011 | Cycling
How do I raise the handle bars on my mongoose xr 200 21 speed bike
Your handle bar stem has a metric screw in the the neck of the bicycle. But, a word of caution, do not raise your handle bars more than the safety mark on the stem, it has to be inserted that much or it and it can snap in two and result in serious injury. Take it to a bike shop and they can either show you how or advise you on replacing the stem with a longer one. This is a very important part on your bike, do not take chances.
Apr 05, 2011 | Cycling
How do you raise the handle bars on a mongoose scorch bike?
there should be an allen wrench bolt on top of the handle bar shaft. loosen that but not to much because you dont want the tightening nut to fall off. now put the front tire between your legs and try to wiggle the handle bars back and forth while pulling up if it does not move try loosening it a little more and take off the first bolt on the shaft and that should work. i hope this helped you
SabiousOne
Nov 07, 2010 | Mongoose Exile 26 Men's Full-Suspension...
I want to raise the handle bars on my Mongoose XR75 mountain bike, any ideas
Be careful, the stem must be inserted at least 3" or to the safety line, or it will snap off. You have to have a metric allen wrench. Like I say, and I cannot stress it more, do not raise beyond the safety line on stem, buy a longer stem, if you want it higher than that. If, the bike is too small, buy a bike that fits you from a shop who specializes in sizing.
Sep 16, 2010 | Cycling
Loose handlebars on a Mongoose XR-75 mountain bike. I tried to tighten them but they still are loose. Help!
Check the splines on the handle bar. Just loosen the "clamp" and slide the bar over to one side enough so you can tell if the are stripped or not. If they are then replace the bar, if not then reassemble and try to put a littlle extra torque on the bolt.
I have noticed with the 2 of these bikes that I have that the bars do not like to stay tight for long, they tend to work thier way loose about every other time we use them. I just keep tightening them untill the splines strip, then pick up a new bar.
Contact Mongoose for parts info at: www.Mongoose.com under "about" click ask mongoose.
Good luck.
Apr 04, 2010 | Mongoose MGX Maxim Dual Suspension...
Mongoose Handlebar adjustment
where the bars slide into forks there should be a allen nut on the top undo this slightly and adjust bar height then tighten up allen nut
Apr 03, 2010 | Mongoose Exile 26 Men's Full-Suspension...
Cycling Logo
468 people viewed this question
Top Shimano Cycling Experts
John Egan
John Egan
Eric Hidle
Level 1 Expert
Mike
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
