Question about Pentax X90 Digital Camera
Only bought this camera for my daughter on Sunday and a message came up that said 'Battery depleted' so we charged battery up and then it came up with the message 'please confirm that lens cap is removed' which of course it is and then it proceeds to switch itself off!! it looks to me as if the lens is in the position it should be when camera is switched on. Help Please Thanks
    Brigadier General:
  • 11,967 Answers
This camera should not be giving you trouble. Things can only get worse....return it immediately.
Posted on Apr 05, 2011
Camera will not come on. I bought new battery for it and still nothing
As long as the battery is fully charged, if it doesn't work, the only solution is to return it to the maker for repair.
With items like this, the battery depletes over time itself even if it isn't used. I have some very good rechargeable batteries that will deplete in my camera if left for 3 months.
Sep 23, 2016 | Video Cameras
Battery depletes after 60 seconds
I'm afraid that the battery you bought as new, in fact is a battery that was in the shop for years, and can't hold enough power.
If you camera works normal for one minute and does not run hot or even gets warm, I think the battery is not as good as you think.
Can't find since when the camera is around, but my guess is the camera is not that new anymore.
Please recharge the battery and use it, and than recharge it again It could take a few charge cycles, before the battery gets its full capacity, but don't expect wonders.
Nov 17, 2013 | Kyocera Finecam S5R Digital Camera
I am having a Nikon D60 DSLR Camera. I am using it for more than 3 year now when I am loading the battery in the body. The message says "This battery cannot be used. Choose battery designated for used...
Your battery may be worn out and is unable to get re-charged. Buy a new battery for your camera, or try your battery in a matching camera to verify that it is depleted, if so try a new/other battery in your camera to verify that you need a new battery.
Jul 27, 2011 | Nikon D60 Digital Camera
I put a new battery in my camera charged it. Used the camera till the battery ran down. Now it won't charge . This is the second battery I've bought every time I try to charge it won't charge.
It takes over 7 hours to charge, so did you leave it charge overnight?
But while the original battery is chargable, disposable replacements are not. Here is what the manual says:
The supplied battery is a Li-ion battery. It charges while in the camera using the supplied charger. The camera can also use a Duracell CP1 disposable Li battery, which has the same form factor as the supplied Li-ion cell. HP claim the Li-ion cell will provide power for approximately 200 shots under "average" use and 100 shots with "extensive use of the LCD and flash".
Charge time for the battery using the supplied charger and in-camera charging is 5-7 hrs for a fully depleted battery. In the optional docking station, charging takes 2.5-3.5 hrs and using the optional rapid charger, charging takes 1-2 hrs. ... }
http://www.bobatkins.com/photography/digital/hp707.html
Aug 08, 2010 | HP Photosmart R707 Digital Camera
When I press the power button for my Olympus FE-190 to turn the camera on nothing happens. I haven't used it for a while so I initially thought that the battery might not have any charge. When I put the...
Most likely the battery has been depleted. When you are not using you camera you should always recharge the batteries every now and then. This ensures that they will last longer. Try buying a new battery for your camera.
Feb 28, 2010 | Olympus FE-190 Digital Camera
I have had my pentax potio 60 for over ayear but hardly used it. Now i want to use it. i had tried many times to charge using the recommended 2 AA batteries but does not charge. or after taking a single...
Hello.
The Pentax Optio 60 does not charge batteries. You must purchase a battery charger and rechargable batteries and charge them yourself.
The AC Power Adapter cable just powers the camera, it does not charge the batteries.
Hope this helps.
Feb 15, 2010 | Pentax Optio 60 Digital Camera
I keep getting a battery depleted message
I don't know but that would be wierd if this was Paula Meadows from McAlester
Sep 08, 2009 | Pentax K100D Digital Camera
My pentax m20 optio wont turn on.. it says battery deplete..
Hi there - these are older posts, but I just experienced this problem (it appears to be pretty common). The fix I discovered (that works), is to insert your batteries (make sure they're fresh), and then press and hold the "on" button plus "Menu" button, together at the same time. Hold until the firmware resets (a message will pop up on screen and the camera will reset). Voila! It works again for as long as the batteries are in and operational. Also note that in my case, if the batteries are taken out, I have to go thru the reset process again, but at least I have the camera back up and running. Hope this helps others!!
Apr 21, 2009 | Pentax Optio M20 Digital Camera
Battery charging problems
Ther may also be a fault with the camera body. Seek advise for a Nikon repair centre.
Mar 10, 2009 | Nikon D40x Digital Camera
Pentax X90 Digital Camera Logo
70 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
