Question about Mitsubishi WD-82838 DLP TV
There is a deep hum that started coming from my 20 year old huge Mitsubishi floor model TV. Any ideas? I know, buy a new one, but I love this old hunk of a TV. Thanks !!
  • 1,476 Answers
Sculin,
Certainly a new one would solve the problem but from what you have said it would seem that yours should be reaparable. The only question would be whether it would be worth fixing if it costs alot to fix. Putting a large amount of money in a twenty year old set is usually asking for trouble. You said that the unit has a loud hum. Sounds like a low voltage power supply problem. I have a tip at
http://www.fixya.com/support/r6396176-projection_tv_troubleshooting
which will walk you through the troubleshooting process and should help solve your problem with the least amount of money.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Apr 05, 2011
My Mitsubishi television has vertical and horizontal 6 inch lines and ghosting when you turn it on. It slowly improves eventually but it's taking longer each time. What's the problem?
Do you know how old your Mistsubishi TV is?. I know my folks had a Mitsubishi TV for over 15-20 years and near the end of it's life it started doing what your TV is doing. So just want to clarify the age of your TV?If it is the same age as what I have described, than it's time for a new TV. As the pixels start to burn out and cause the issues your having.
Oct 17, 2012 | Televison & Video
20 year old Maytag jetclean model WU482 small hole in front bottom of tub leaks water
At 20 appliance years of age, your Maytag may start leaking like a sieve but you can try patching the hole you see and hoping for another 20 years.
Jun 19, 2017 | Dishwashers
57H81 57 in. Rear Projection Television: My Toshiba model 57h81 is 5+ years old. It just s...
I had the same issue with my 57 in. Mitsubishi. I fixed it by buying a new projection bulb. The Mitsubishi manual indicated this was the fix for my Mitsubishi TV. Be advised that new projection bulbs are not inexpensive. My TV works like new once the projection bulb was replaced.
May 03, 2010 | Televison & Video
Mitsubishi wd52725 wavy pic
If this is a rear projection set you needs the convergence IC replaced,
the model # wd52725 indicates it may be a DLP (probably not correct). If its a DLP the problem is within the power supply or video/formatter boards. The convergence ICs should cost between $250 and $400 to have a servicer install them depending on their labor rates.
If this is a DLP model the power supply repair (just capacitors) would cost the same, but if the boards are bad it would be over $500 to have repaired.
Is it worth the repair? Most servicers charge an estimate fee $60-$120
perhaps for can ask them for their labor rates for the IC install instead of having them drive out and tell in person what they could say over the phone.
Compare the repair prices with the replacement price and decide based on, your budget, how old the set is, what you paid for it originally.
You can buy a new 52" proj set for around $1000-1200 DLP or LCD
you will get a 1 year warranty on a new set, but only a 90 warranty on the ICs. If you buy a new set try to buy the 3 or 5 year extended warranty to protect your investment.
hope this helps
E
Aug 04, 2009 | Televison & Video
LG DLE5977W dryer has stopped and developed a motor hum. How can I fix it?
I am assuming that the hum indicates the motor is running but the drum is not turning.  Possibly a broken drum belt however the check filter warning is indicating low air flow so the blower wheel could be broken at the connection to the motor shaft.
Jun 01, 2009 | LG DLE5977 Electric Dryer
Rolling lines on screen
Sounds like the power supply has a bad capacitor. This problem can inject excessive 60 hz from the AC line into the vertical stabilizing picture system. The hum also my come from the same reason, bad or leaking filter capacitors. Cheaper just to buy a new TV or borrow another TV and connected to your system to see if the problem still occurs.
Mar 16, 2009 | RCA F36668 36" TV
Mitsubishi 62in tv
You can get the owners manual on-line at mitsubishi-tv.com.
That should give you all that is needed.
Good Luck,
-Bill
Nov 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Whirlpool gas dryer won't start
you most likely have a bad motor. Motors run around 100 dollars since the machine is 20 years old it would be a good idea to replace it with a new dryer. if i were you i would stick with a whirlpool product.
Oct 13, 2008 | Whirlpool GGQ8831L Gas Dryer
Mitsubishi 10 yr old rear projection
Well, there is no lamp or simple part you can unplug and plug in. I have seen a couple of those sets with that symptom recently and it is caused by a faulty 9 volt regulator on the small signal board. This is not an easy part to change and the repair should absolutely be handled by a tech experienced in Mitsubishi projection sets.
Aug 09, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Help-Love my 40307
I hate to tell you but if parts are not available is not a good sign,consider buying a new TV and get it over with.
Sep 12, 2006 | Mitsubishi CS-40307 40" TV
Mitsubishi WD-82838 DLP TV Logo
102 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
