Question about Maytag MDE2400AYW Neptune Electric Dryer
We have a Maytag MDE2400AYW dryer, brand new. We hear an intermittent squeaking, more like a soft whistling sound. For 20-30 seconds it will squeak about once a second (is this during a heating cycle?) and then for a few minutes it does not squeak. Have not tried any diagnostics yet. Thank you!
  • 7 Answers
SOURCE: Washer make a loud squeak when the spinning stops
its the brake, just as long as it stops, dont worry about it, made a web page that has pics on how to replace the spin bearing on the maytag atlantis washer, after searching the net on how to, finding the manual, not explanatory, i decided to make this a simple 1 page web site, with lots of pictures, i hope this can help someone else in doing this job. since it would cost too much money for a repairman to do the job, better to buy a new one instead, i tackled the job. since it basically takes apart the whole machine, it might help others even if they dont have the spin bearing problem but other parts to replace,
http://www.geocities.com/maytagrepairwasher/
Posted on Apr 07, 2008
  • 41 Answers
SOURCE: Intermittent heat on maytag ldg8606aae dryer
your coils are most likely bad. if you are up to tackling the job yourself, I can help. otherwise, you will need to call a repairman. Joe
Posted on Nov 18, 2008
SOURCE: Maytag dryer squeaks during cycle
How do you replace the glides/slides? I have a Maytag dryer that's squeaking, took off front and it's clear it's the glides. Found where to buy them just need directions for replacing. Anyone know how?
To change the glides you have someone lift the drum--after taking off the front panel--and pull out the glides. We bought the glides locally and just ordered on line the felt pads that go under the glides, as one was missing. So I haven't actually completed the project but should easily be able to once the felt pads arrive.
Posted on Mar 24, 2009
  • 423 Answers
SOURCE: Maytag gas dryer model SDG305DAWW. make a loud
Your problem is most common caused by a failing/loosening drive belt that turn the dryer bask by an electric motor.
If you are not familiar with how to replace belts (like the kind on your car engine compartment, I strongly recommend you hire a professional.
Posted on Aug 11, 2009
SOURCE: maytag atlantis eletric dryer squeaks
Your trouble would be either a bad Idler Pulley, or bad Drum Rollers.
Posted on Dec 30, 2009
Dryer squeaks on start up or whisles on start up
Good Morning Friend,
I understand that your Frigidaire dryer is squeaking or whistling on start-up, and you want to know if the pulleys need to be oiled. I t could be a possibility that the pulleys need to be oiled. There could also be numerous other possibilities, which are causing the squeaking sound. I suggest contacting your local authorized technician for further assistance. I hope this is helpful.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire Dryers
Squeaking sounds
slipping belt drive on drum , have it checked.
Mar 22, 2014 | LG DLE1101W 7.3 cu. ft. Ultra Large...
My dryer has developed a squeak while in operation. A whistle sound while it's drying clothes. What do I need to do?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 14, 2011 | Fisher and Paykel DEGX1 Electric Dryer
My Maytag Neptune is making a banging sound while it dries. The motor was just replaced last year. Could something be loose or is it more serious than that?
heatman101
Jan 12, 2011 | Maytag MDE2400AYW Neptune Electric Dryer
Drum making harsh squeaking sound when maytag dryer model MDE 9606 in use
heatman101
Asker
Jan 01, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Squeaking Noise coming from Dryer
Could be the roller next to the heating element. Heat tends to cause more wear in it. Use some HVAC oil to lube those noisy rollers. 6b5c930.jpg
Aug 02, 2010 | Maytag PYE2300AY Electric Dryer
My maytag alantis gas dryer is squeaking
The squeaking is often the guide rollers for the tub. The bearings get dry and squeak as they turn... a bit of oil my fix the problem till you can get new rollers. The other cause could be the belt tensioner pulley...that too can be fix temporarily by oil til a replacement can be found...
Heatman101
Mar 03, 2010 | Maytag Dryers
While drying for short time the dryer starts to squeak
Probably a dry bearing
.You would have to gain access into the dryer to establish which bearing/s it is.
You would then need to see if lubricating the bearing/s, would cure the squeak..
If it does not, then you may have to fit a new bearing/s.\
Hope this helps.
Dec 22, 2009 | Maytag Dryers
Dryer makes rumbling noise intermittently
It sounds like a faulty roller under the drum. Need to pop the top of the dryer, then remove the front -- you'll probably easily spot the faulty part.
May 06, 2009 | Maytag Dryers
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
Maytag MDE2400AYW Neptune Electric Dryer Logo
57 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
