Question about Samsung LA40A450 40 in. LCD TV
MY SAMSUNG LE37M87BDX HAS NO PICTURE TURN ON LIGHT FLICKERS BUT NO PICTURE STILL CAN HEAR THE SOUND ANY IDEAS
  • 11,361 Answers
It can be the 24vdc power supply is bad due to bad caps with domed tops, or bad backlights inverter board, check for 24vdc first, it can also be dead T-CON board, please read below to help you narrowing down the cause of the problem.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Apr 05, 2011
Please could you advise or help me obtain a full service manual for Samsung LCD 37" TV model no:LE37M87BDX/XEU
If you let us know what's wrong with the TV, we may have a solution, rather than have you taking stabs in the dark about what's wrong.
I mean if it's not turning on, whining, or turns off 3 seconds after being turned on, or just clicks if you try to turn it on, or there is sound but no picture...chances are we already have the solution.
Tell us what's wrong with it, and we'll see what we can do!
Jun 24, 2011 | Televison & Video
Lexsor 32" widescreen LCD TV
sounds like av panel needs replacing................
cheers
Mar 26, 2011 | Televison & Video
No picture, no sound, green light flicker ongoing
The power supply in the Tv has failed and should be looked at by a qualified technician.
Sep 09, 2009 | Samsung Televison & Video
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
No picture
IF YOU NEED MORE INFORMATION ABOUT THIS MODEL
VISIT
www.tv-solutions.redtienda.net
Aug 07, 2008 | Zenith R40W46 40" Rear Projection...
Samsung hl-s6186 screen flickers and sometimes goes green
The humming will usally come from the color wheel(one of the only moving parts), which is part of the light engine. If the tv is starting to get a green picture that is a sign that the light engine is on it's way out.
Aug 05, 2008 | Samsung HL-S6187W 61 in. HDTV
Lens is out, Camera won't turn on, power light flickers
Take battery out and clean contacts with an eraser on the end of a pencil.
Then try.
What stage is the lens - all the way out or partway?
OPut a finger on the lens barrel - do not puch it - this will ruin the drive- switch off the wieght of finger may be enough for the lens to get into gear..
Jul 13, 2008 | Samsung Digimax S500 Digital Camera
TV flickers when turned on
this sound like panel or inverters that drive the lamps ( fluorescent lamps that are not replacable they are part of the panel).
Jan 16, 2008 | Polaroid FLM-3201 Television
No Picture No Sound
I think you have a short somewhere inyour set most likely the horizontal output transistor which may have shorted by the high voltage transformer going bad. The faint ticking sound that you hear is the power supply trying to start but the shorted load won't let it. Stargazer
Apr 22, 2007 | Samsung TSL3099WHF 30" TV
Samsung LA40A450 40 in. LCD TV Logo
689 people viewed this question
Henry  Thomas
Henry Thomas
