Hi, my hdtv is heard as static when it produces loud sounds, which can be?
    Scholar:
  • 126 Answers
With the limited info - id have to say av board or audio amp if it is separate...could be a busted cap.
thanks,
michael
Posted on Apr 05, 2011
Fridge water sound
This kind of noises produced gas in cooling system.
In the old coolers never heard sounds like streaming water because the compressors were very loud due to high pressures (12 bars or more), which were required for efficient cooling. Today we use more ecological gases which work (from 5 to 6 bars) at much lower pressures, thus compressors produce much less noises and now suddenly we hear sounds that never before heard. Generally speaking noises is lower, measured in decibels.
Dado
Feb 01, 2014 | AEG Freezers
Vizio 37" went dead while watching it.
hi sounds like the fuse inside could have blown or the psu has blown look for tech in your area hope it helps
regards
shaun
Jan 23, 2014 | Vizio VO370M 37 Class LCD HDTV
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
In my 42" HDTV Plasama TV I heard a loud pop.
You will find that the power supply has failed and is no longer supplying the VS voltage that the screen requires to produce a picture.
Call a specialised engineer that is authorised to work on your make ot TV.
Jan 23, 2011 | LG Televison & Video
Ringing sound when TV is off
Change the power supply board. What you are hearing is the switching power supply. They work at high frequency and sometimes produce lower ferquency harmonics that can be heard by people.
Apr 30, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
My 2005 Accord's radio / CD player will not produce sound to the speakers, the display panel works fine. Sometimes a loud static sound will come from the speakers with no volume control, powering off gets...
The sound chip may have gone in the stereo, especially if someone has had it on very loud they sometimes blow, otherwise you have 2 speaker wires touching each other, that way you only get static noise, insidee the door they sometimes come free and touch the body
Check all your speaker wires first.
Jan 17, 2010 | 2005 Honda Accord
How do I fix bad static? Dell W3706MC 37 in. HDTV LCD has been fine and suddenly the sound has loud static on all sources. Is this a sound circuit failure?
Yes,loud static usually comes from bad isolation of sound signal path so it's probably a frayed cable or a loose jack. Or if you're unlucky some parts inside have failed.
Oct 26, 2009 | Dell W3706MC 37 in. LCD HDTV
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
