Verbatim 1 Gig jump drive doesnt power up when plugged into the USB port anymore,thus preventing files from opening up.
    Champion:
  • 221 Answers
It may be a bad jump drive or your usb port is broken. Try pluggging it into a differnt USB port
Posted on Aug 06, 2008
It want come up on my computer
Step 1:
Problems with Verbatim portable hard drives vary depending on your model of hard drive, your operating system and your computer hardware. Some problems can include insufficient USB power output, the file system format, and potential overheating due to enclosure materials.
File System b> Verbatim portable hard drives come formatted for use with Mac computers. If you're using it with a Windows or Linux computer, you will need to format it to a file system that your operating system will recognize; Windows computers typically work with NTFS, while modern Linux distributions use ext4. If you have computers with mutliple operating systems, FAT32 is usually considered easier for all operating systems to recognize. Verbatim does not recommend switching a portable drive between PC and Mac computers once you've formatted the drive one way or the other. Adequate Power While most computers supply adequate power with one USB port, older computers can have insufficient power output. If your computer doesn't seem to be powering the drive, use of a Y-shaped USB cable, designed to be plugged into two USB ports, can get more power to run the drive. Additionally, consider trying different USB ports on the same computer; some USB ports get more power than others. Drivers b> Make sure that you have any relevant drivers related to the hard drive that you have purchased. If your drive didn't come with a setup disc, you can check the Verbatim website for product drivers. Overheating b> Of Verbatim's seven portable hard drives, four are enclosed in plastic; of the other three, one is enclosed in aluminum, one in leather, and one in rubber. While all the drives are tested to run well with their enclosure, metal enclosures conduct heat away from the hard drive and help to prevent overheating. Plastic, on the other hand, is an insulator, so plastic enclosures may contribute to heat buildup. Check plastic-enclosed drives for overheating and avoid leaving them plugged in when not in use.
Apr 05, 2013 | Verbatim SmartDisk Firelite Portable USB...
I have a 16 GB verbatim brand jump drive that I cannot open up. I have tried other usb ports on different computers. Is it common for jump drives to go bad? Do you have any suggestions? Thank you!
If not "safely removed" USB drives can go bad. If your system recognizes the drive when plugged in you can try doing a scan disk on it and check for any errors that may be preventing you from accessing the file system.
Plug in the USB drive, check my computer and see if the drive is there, if it is, right click the drive, click properties, and tools and select the option to scan the disk.
If you do not see the drive in My Computer, click start, Run, type DISKMGMT.MSC and click OK. Check and see if your drive is being recognized in Disk Management.
If you still do not see it in Disk Management, they you may just have a faulty jump drive, at which point you should contact Verbatim to see if they have any other recommendations or if it is still under warranty.
Jul 06, 2011 | Computers & Internet
I am operating with windows vista home premium. I want to know how to save items in certain folders onto the Verbatim stick, can u give me a Step by Step, derekjkeough@yahoo.ca
Plug it into the usb port and go to 'my computer' there you will se the drive most likely named verbatim, double click to open it.
Then open a new window and find the file you would like to transfer, simply click on it and drag and drop it into the usb drives window and wait for the file transfer to finish.
Feb 15, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
How to download pictures from computer to verbatim
1) PLUG THE USB INTO USB PORT
2) THE USB DRIVE WILL APPEAR IN MY COMPUTER
3) SELECT THE FILES THAT YOU WANT TO TRANSFER TO THE USB
4) RIGHT CLICK ON THE SELECTED FILES
5) SELECT "SEND TO" FROM THE LIST
6) SELECT "USB" FROM THE LIST
Jan 25, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
How do I use this product? How do I select and copy file to the USB flash drive?
Jan 18, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
Mmmmm
Jan 14, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
My pc doesnt recognitze my portable verbatim hard drive anymore, model 47512, and their support page sucks. what can i do?
First, try to connect it to a different computer, to see if it can be read on _any_ computer at all.
Second, check the warranty-status of the unit; if the warranty still is valid, Verbatim will replace the hardware (but will NOT make any attempts to 'recover' your files).
Third, an external drive has two major components -- the disk-drive and the USB-to-disk-drive adapter. Open the enclosure, and remove the disk-drive, and connect it as a 'slave' disk-drive in a desktop computer, to see if that interface hardware is the problem.
Aug 20, 2010 | Verbatim External, USB 2.0, 750GB...
2gb jump drive not working
There are two major possibilities:
1: There is hardware or software problem with your computer's USB ports. To test this, plug the drive into a different computer if you can, and try having it plugged into your current one while you turn the computer on.
2: The issue is with the Jump Drive itself. If the drive fails to show up when plugged into a different computer this is the likely problem. The data CAN be recovered, but if it won't show up on any computer, the only real way to do so would be to pay a Hard Drive recovery shop.
Sep 21, 2009 | Verbatim VER95327 USB Hard Drive
External hard drive doesn't respond
Shut your computer down. Disconnect you external hardrive. Power up your computer again. Power up the Verbatim and then connect to a USB port. You should hear a very quiet 'ping'.
Go to My Computer, and the Verbatim should be showing as one of your drives (probably Drive D). You should be able to open it from there.
Make sure that you have a Desk Top Icon for opening the hardrive, it makes it so much easier. Hope this helps
Jan 25, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
