SOURCE: removed splatter shield
If you can supply the brand and model, we can probably point you to the supplier for the splatter shield (waveguide cover).
The door shouldn't really fog up too much (not permanently anyway) as long as the internal cooling fan and seals are okay.
The door panels can usually be separate for cleaning if it's absolutely necessary, but it's a pain of a job.
Again, brand and model mean everything, so if you can give us those we can probably get more specific. Happy to help.
SOURCE: Cleaning inside of microwave door
THE DOOR ON MY MAYTAG MICROWAVE OVEN HAS A SCREEN OVER IT. I HAVE SOME FOOD SPATTERS THAT PENETRATED THE SCREEN AND I CAN'T CLEAN THE GLASS THAT THE SCREEN PROTECTS. HOW CAN I REMOVE THIS SCREEN TO CLEAN THE GLASS?
SOURCE: Microwave door has burn spots on the glass of the door...
The brown spots are usually grease / smoke deposits. Usually there are indeed two sheets of glass in the door. If the grease is not arcing or smoking, and the metal screen / mesh (that blocks microwave leakage) is not damaged, then it's likely better left alone. It might be useful to boil a few cups of water with a little vinegar inside the microwave to help dissolve the deposits. In case you want to take it apart, I have attached a photo from a similar model that illustrates disassembly of the door. It is not necessary or advisable to remove the door or hinges when disassembling the door.
SOURCE: Gold Star Microwave- model MV 1500MG
Normallyyou have to separate the door panels (as shown in the attached photo)and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
There are many good suggestions for cleaning and deodorizing microwaves here.
You have to separate the door panels (as shown in the attached photo)
You can usually find
helpful exploded view diagrams and order parts by entering your full
model number here.
We're
