Question about Dual Car Audio & Video
2000 Honda Civic ex have installed dual xdvd9131 after leaving for 1 day the battery is dead
    Problem Solver:
  • 5 Answers
Wire the red wire onto ignition switch so the power is disabled when the ignition is off
Posted on Apr 05, 2011
Why doesn't this 2000 Honda civic lx turn over when everything else works inside the car?
Honda Civic Coupe Questions - car will not start. battery ok ...
www.cargurus.com > Questions > Honda > Civic Coupe
CarGurusJul 9, 2008 - Get someone to turn it over and see if it is getting spark. ... i have the same issue with my 1993 civic lx it has a 1.5 sohc non-vtec i changed ... comes wen the 2nd click of the main relay it doesn't occurs until after few minutes, few .... My 2000 Honda Civic Ex Vtec will not start, has a new tps, new throttle body, ...
Part 1 -How to Troubleshoot a No Start (1.6L Honda Civic)
troubleshootmyvehicle.com > Honda > 1.6L
Dec 31, 2012 - Difference Between a No Start and a No Crank Condition. ... can cause your 1.6L Honda Civic (Civic del Sol) to Crank but Not Start. ... In other words, the engine doesn't turn over at all. ... 1995, 1996, 1997, 1998, 1999, 2000.
98 Honda civic won't crank (PushStart) - YouTube
? 4:11
https://www.youtube.com/watch?v=X5W7OqjKB8I
Oct 21, 2013 - Uploaded by SkzDaniel
Honda Civic won't start or crank with the clutch but goes on when you push start it. ... 2000 Honda Civic LX with new battery and starter. Still will ...
? 6:34
https://www.youtube.com/watch?v=p7KAO__nM1s
Aug 21, 2013 - Uploaded by Robert SnyperMD
2000 Honda Civic LX with new battery and starter. Still will not start. ... Crank, No Start Diagnosis Honda Coil test. - Duration: 11:17. by ...
Jan 05, 2016 | Honda Cars & Trucks
We own a 2000 honda civic LX won't
check timing, fuel filter,pump,injectors, resistor, distributor, plugs, wires.
Sep 26, 2009 | 2000 Honda Civic
My daughter owns a 2001 Honda Civic EX. After
The exact problem happened to me...
Opposed to a blown fuse, most likely the drained/dead battery caused the radio to "reset" itself. You should have a 5 digit (or 4) code that was provided by the dealer or owner. Most owners write it down somewhere on their owners manual. If not, the dealer can give you the code. Once the code is entered, you back in business!
Dennis W.
Jul 29, 2009 | 2001 Honda Civic
Liters of oil in 2000 honda civic ex
3.7 quarts, not liters. Good luck and thanks for rating my response!
Jul 01, 2009 | 2000 Honda Civic
2000 honda civic ex
look for the engine number it should say D16Y by looking down in the block near the fan shroud. Also check for the Vtech solenoid near the distributor 2 wire goes into this SOLENOID.
Apr 28, 2009 | 2000 Honda Civic
Have power and accessories until key is turned to start
U will need to replace the ignition switch, this is not the key cylinder but the actual electrical switch the key cylinder operated. see photo. I noted that on your model Honda the switch comes with a new key cylinder, you can just use the switch and use your old cylinder over or install the new parts together.
Apr 08, 2009 | 1997 Honda Civic
Honda Civic 2001 Radio Code
HAVE TO FIND OUT WHY MY 2003-2005 HONDA CIVIC RADIO DOES NOT WORK. REMOVE BATTERY LAST WEEK AND RECODED THE RADIO. WORK FOR A FEW DAYS AND IS DEAD TO THE WORLD. HOW CAN I TAKE THE RADIO/CD UNIT OUT OF THE DASHBOARD WITH EASE. HOW CAN I TAKE THE RADIO/CD OUT AND IN ?
Jan 08, 2009 | 2001 Honda Civic
Battery went dead in 2000 honda civic EX, radio now dead after battery replaced
you will probably need a activation code to get it to work again.
If you bought the car new then you should have a "credit card" size paper with the code on it, they don't put them in owners manuals so, don't look there, if you can't find it or you purchased this car second hand, the you will have to go to the local dealership and show proof that you own the car and they will get the code for you from their head quarters.
Aug 30, 2008 | Honda Civic Cars & Trucks
Car Audio & Video Logo
69 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
