What is the energy effeciency rating on the Lennox Whisper Heat, G20 series?
    Brigadier General:
  • 4,736 Answers
The A.F.U.E. rating on the G20 series is a paltry 77%. Compared to 94% A.F.U.E. on the high efficient models.
Hope this answered your question. If it did, I'd appreciate you rating my response.
Posted on Apr 05, 2011
Lennox elite heat pump throws cold air
The unit should give you an error code if something is wrong.
Here's the manual:
http://instalacionesindustriales.com.gt/pdf/Lennox_Minisplit_HE.pdf
Mar 25, 2014 | Lennox 7 Series MS7-HO-18P MS7-HI-18P Heat...
I installed a new thermostat on my hvac system and the heat is not working anymore.
On that thermostat there is an R and an RC wire connection, the R is the power wire for heat and RC is the power wire for cooling. If you connected the power wire (normally red in color) to the RC only the fan control and AC control will work, there has to be a jumper wire between the R and RC terminals (assuming there is only one control transformer) for both the heat and cool functions to work.
Jan 21, 2014 | Honeywell Programmable Thermostat Heater
Lennox codes
e5: open or short circut of outdoor yemp. sensor or outdoor unit.
see more Air Conditioning Fault Codes
May 11, 2013 | Lennox 7 Series MS7-HO-09P MS7-HI-09P Heat...
How to install the intake air supply and the exhaustvent on a high effeciancy lennox G26Q4/5-125-6 Furnace
hi i am a lennox dealer and can help you with this problem i also have an instulation manual for this unit its going to be scud. 40 pvc pipe both the intake and supply have to be vented out side email me at airforceac@live.com
Aug 11, 2010 | Heating & Cooling
Side by side divider is very hot
The divider you speak of needs to be warm in order to prevent condensation from forming there. Old refrigerators used an electric heater to do this, which of course uses energy. Newer refrigerators use a loop of tubing from the condensor to warm this area with waste heat (removed from the refrig during the cooling of the inside process), thus making them more energy effecient. The only draw back is they only heat when the compressor runs, so they can get quite warm during compressor run time. This is all normal and designed, so don't worry about it.
Jan 16, 2010 | Refrigerators
How do I clean a flame sensor on a 1993 Lennox Whisper Heat furnace. It heats,then the gas valve clicks and the flame briefly stops and starts again then the valve clicks again and the flame briefly stops...
You can sand the flame sensor but it sounds like another problem. Sounds like a limit switch or something in the control circuit, You need to have a service tech look at this. Ask for free estimate on repair. I have worked on hundreds of these units and they are sometimes tricky to work on. Lenox has come up with new controls for the whisper heat furnace to replace the old ones. If the flame sensor is bad the unit will try to light a few times and lock out and you ahve to kull power to the furnace to reset. If this is whats happening clean the sensor nd you should be ok If not you need help from a service tech.Rus
Nov 11, 2009 | Heating & Cooling
Lennox G40UH(x) series - Air not coming on
electrical connections @ the furnace may the thermostat .Tom
Jun 18, 2009 | Heating & Cooling
Heater no longer works on auto fan, only manual fan
When you call for fan in auto ensure your getting 24 volts at pin on control board, if it is not energizing then there is a problem with the relay.. Before you change out the expensive control board, try the therm..
Dec 09, 2008 | Heating & Cooling
Heating & Cooling Logo
198 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
