We have an HP Laserjet 2420 with tired rollers. How do we change the rollers?
  • cbalian18 Apr 05, 2011
    Ok great. Now where do we get the new rollers?
    cb
    Duh! Thanks will do.
    cb
    Genius:
  • 1,570 Answers
Hi
Here is the link http://www.precisionroller.com/all-supplies-and-parts-for-hp-laserjet-2420/products.html and you can order online and will delivery to you next to your door.
Regards
Posted on Apr 06, 2011
    Genius:
  • 1,196 Answers
Turn off power to the printer and unplug the unit. Allow it to cool at least 30 minutes before starting any work on the machine. Put on latex gloves before handling the roller. Open the door to the area housing the toner cartridge. Remove the cartridge and set it aside. Find the roller. There should be black bushing at the left side of the roller near the gears. Pinch the tabs on the black bushing and lift the roller out of the printer. Set it aside. Insert the new roller by pinching the black bushing tabs and sliding the roller into position until it snaps into place. Once in position, release the tabs and tug gently to be certain it is securely in place.
Posted on Apr 05, 2011
  • Ishola Olayemi Apr 05, 2011
    You can order for the roller online at either ebay.com or amazon.com
HP LJ 2420 wont pickup paper from tray 2
Replace try2 paper pick up roller..
Dec 01, 2011 | HP LaserJet 2420 Printer
Hp 2420 leaves vertical line across the page. we changed the fuser 7 months ago
It sounds like you may need to change it again. These printers use a Teflon coated heat roller in the fuser. If you print envelopes that will scar the heat rolller, this can also happen if there is a piece of paper jammed in the fuser assembly and it scraped the fuser roller. Open the back of the printer and look at the roller in the fuser. I would bet that you see the roller is damaged. Here is a link to a post about the Laserjet 2100 printer with the same issue. It has pictures of the roller and what to look for, the fuser is different but the principle is the same.
http://www.ccl-la.com/blog/index.php/how-to-fix-hp-laserjet-2100-vertical-lines-on-print/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 20, 2011 | HP LaserJet 2420dn Printer
How do I clean the roller in the HP LaserJet 2420 Printer?
hi
if you are referring to the pickup rollers.. depending on how old the printer is , you will have to replace the rollers (inexpensive, see second link for cost) . the first link will help you further (maintanance, rpelacement)
maint = http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=ca&taskId=125&prodSeriesId=416419&prodTypeId=18972&prodSeriesId=416419&objectID=c00310332
cost = http://h20141.www2.hp.com/Hpparts/Search_Results.aspx?mscssid=BDC5CC5C0FD64301A541DD13A136E7BA&SearchIn=Product
please rate my service
Nov 22, 2010 | HP LaserJet 2420 Printer
Need service manual to replace the pickup roller assembly for the optional 500 sheet feeder unit
http://www.google.co.in/url?sa=t&source=web&cd=5&ved=0CDMQFjAE&url=http%3A%2F%2Fait.tamu.edu%2FCostShareArchive%2Ffall06%2FLJ2420man.pdf&rct=j&q=hp+laserjet+2420+printer+manual&ei=KPwPTOOpCpO5rAf_kJ3kCQ&usg=AFQjCNHnpk_GgAMMIWfi5QFzB6cpJnIsTA
hope this link will help u
Jun 09, 2010 | HP LaserJet 2420 Printer
Hp laserjet 2420 paper jam 13.20.00
Hi, check throughout the printer for small pieces of paper stuck, broken sensors etc, clean the rollers in the paper tray 2, check for wear. clean the registration rollers (under a metal flap under the print cartridge) do not clean the transfer roller (the spongey roller sitting under the drum!)
Feb 09, 2010 | HP LaserJet 2420 Printer
The fuser roller is damaged
Go to the following link to HP parts surfer, to see a parts diagram, select your country, then you can find pricing and order directly if you want, or call a local dealer, which should be less expensive because they can provide factory refurbished units on an exchange basis.
http://partsurfer.hp.com/cgi-bin/spi/main?sel_flg=picture&model=LJ2400&HP_model=Q5956A&modname=LaserJet+2420+Printer+(Q5956A)&template=main&plist_sval=&plist_styp=&dealer_id=&callingsite=&strsrch=&keysel=%3F&catsel=%3F&pictype=I&picture=LJ2400%2F8-3&uniqpic=
*please rate me ;)
Mar 25, 2009 | HP Office Equipment & Supplies
HP Laserjet 2420 will not print from tray 2
Take out the toner cartridge and paper cassette , turn the printer upside down. The feed roller should not free wheel. Sometimes the roller ends break off,
Jan 28, 2009 | HP LaserJet 2420 Printer
HP Laserjet 2420- Late Paper Jam
1) Your paper tray may be too full, makes it heavy to lift and not enough pressure for the pick up roller.
2) Pick up roller is slippery, wipe it clean with alcohol to make it abbrasive.
Apr 15, 2008 | HP LaserJet 2420 Printer
Hp 2420 printing light on left side of page
take out cartridge and look at roller on bottom of printer, clean with clean cloth and try, also there is a slit ( or hole on the inside ( put your hand inside and try to touch the top of printer there is a hole there where the images go to the laser clean with clean lint free cloth.
Nov 01, 2007 | HP LaserJet 2420 Printer
23 people viewed this question
k24674
jasbo
jasbo
