Up and down channel selector wont work on remote for Toshiba MD 13Q41.Remote is identified as CD-SB1
Remote failure in up and down channel selector mode
  • 51 Answers
This is usually caused by dirty contacts due to prolonged use, basically oils from your fingers caked up beneath buttons
Posted on Aug 06, 2008
How do I program toshiba vc-sb1 to operate a samsung pn43e450a1f tv?
Programming [set-up] procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
May 20, 2014 | Toshiba WC-SB1 Remote Control 72799183
Ive doesnt know to change the channel of toshiba regza for cable because its japanese
Program remote to code 061, then see if the channel selector is working.
Aug 13, 2013 | Televison & Video
I bought a Toshiba TV with remote CT90326 from a friend who had a different service (satellite) and I have cable and the remote works to turn on the TV , punch in specific channels, and to change volume,...
Any television remote will give full access to the television functions. The remote must be specific to that television. Google
make model replacement remote
There are original ones on ebay, plus companies that sell remotes that are an exact copy. The CT90326 may be for another Toshiba model, or of course it may be faulty.
Then we have the remote on the cable or satellite unit. That gives full command of the unit functions, but BASIC control of the television, normally On, Off, Channel Up and down to allow access to DVD or similar and Volume Up and Down. Everything else is done from the TV Remote.
To get the cable remote to make that happen, you Google
Toshiba Remote Codes
and run through them all until a selected code allows you to switch the television on and off.
Sep 25, 2017 | Toshiba Televison & Video
I just bought a new remote and cannot find the user guide for the TV. Do you need to program the remote for it to work?
You have to programme it. do the following:
[1] Make sure there are working batteries in the Toshiba remote control.
[2] Turn on your television set, DVD player or other device that you want to control with the Toshiba remote
[3] Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
[4] Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
[5] Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed.
Jul 19, 2011 | Toshiba DC-SB1 Remote Control
I can't move the channel selector on the remote up or down. I can depress the control but nothing happens. I can key in the channel number OK but to change channels I have to key in another number. The...
when I press any buttons on remote control cant move the channel and there is a message showing on tv screen "the operation with remote control is prohibited
Feb 23, 2011 | Sharp RRMCG1687PESA Remote Control
I have a Toshiba W528 VCR and am trying to hook up a Wii in the front panel Line 2 jacks. How do you switch the connnection to the Line 2 jacks without a remote?
With the up and down channel selector buttons. You will have to keep pressing either button till it shows AV (something IE 1 or 2 etc). Depending what it says on the front panel for the socket.
Recommend a universal remote if you can't get a new one.
Feb 06, 2011 | Toshiba W522 VHS VCR
My remote control's input select button wont do i do it manually?
Not sure about this particular TV, but usually, you select inputs by channel selector. Go to Channel 1 on TV not Cable or dish, Use the channel selector button on the set itself, go down from 1. You should see somthing like Aux or Line, then aux 2 or Line 2 etc.. eventually (3 clicks or so) rolling around to ch 115. But usually between the highest ch on the set and ch 1 are the auxillary input selections.
Nov 11, 2010 | Emerson EWF2004 20" TV
Tevion universal remote md 80383 need instruction manual
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 25, 2009 | Panasonic Televison & Video
Remote control users manual needed
I had this problem just now for the Toshiba DC-SB1 remote control model, and I think the problem might be that you're pressing the wrong button. Try pressing the "skip track" button right below where it says close caption on the remote. It's deceiving because, based on where the words 'closed caption' are, it looks as if the stop button is associated with it, but it's not. That's what I was doing wrong, it may be a different problem for you though.
Dec 11, 2007 | Toshiba MD19N1 19 in. TV/DVD Combo
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
