Question about Lexmark Wheelwriter 1500 Typewriter
I can't get the left margin to stay. I set it and start typing to the far right and after a few returns, it locks right in the middle. I then use the margin release key and it will but only the first time. It will lock again, and then the release key won't work. If I don't use the release key and continue to type to the far right, it will lock again about midway. I tried going to lexmark.com and clicked on the download and support tab, but there is no product for typwriters. I can't find a model number either that begins with a lettter, just 1364816; hope this helps. I need help; sorry can't pay.
  • Lexmark Master
  • 3,594 Answers
Put a shot of WD40 on both sides of the silver shaft that the carroer slides on. If that doesn't do it put some on the carier motor bearings. The front one can be reached from inside of the T/W the rear one yuo will have to remove the case of fish the straw thru it. The motor is located on the R. rear corner.
DickyO
Posted on Apr 05, 2011
How do I increase the margins on the typewriter
To set a margin beyond the left or right margin, move the carrier (or cursor) to that margin, press the Margin Release key, then proceed to move the carrier (or cursor) to the desired position. Then, press the Left or Right margin key to set the new margin. A beep will sound indicating the new margin has been set. When you set a new left or right margin, the previous margin is automatically cleared.
Alternatively, you can type beyond the right margin by pressing the Margin Release key and then continue typing when the carrier (or cursor) stops at the right margin. To type beyond the left margin, press the Margin Release key and then the Backspace key to move the carrier (or cursor) to the position where you want to start typing.
Remember to always use genuine Swintec ribbons and lift-off tapes for your Swintec 7040, which can be found at Swintec Typewriter Supplies .
Aug 19, 2014 | Swintec 7040 Typewriter
Brother ml 500 memory typriter how do i move margin to right
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Jul 30, 2014 | Brother ML-500 Typewriter
After typing first line, hit the return key. The carriage would not return to the far left margin...it only moved 12 or so spaces to the left.
The carrier slides on a silver shaft that is about 1/2" thick spray some WD40 on the shaft, if that doesn't do it you have to get some on the carrier motor bearings located under the case in the R. rear corner.
DickyO
Feb 22, 2014 | IBM Wheelwriter 3 Series Ii Typewriter...
The left margin is stuck and the release margin works only the first time after turning on the typwriter. I can set the margin at a point on the left side, but after a few times of hitting the return key,...
DickyO
Apr 05, 2011 | Lexmark Wheelwriter 1500 Typewriter
How do you clear a tab someone preset. when I get to the far right of page and hit return it will on return to a tab. How do I clear all the preset margins or tabs.?? thanks
To clear margins, you have to hit the return button to find the left margin, then hit margin release and back space to move the margin left or spacebar to move to the right, then hit left margin button to set the new position. Right margin now. Hold spacebar down and find right margin position, hit margin rease and either spacebar to the right or backspace to the left to the new margin position then hit right margin button to set the new position. Tabs now. hit the tab key, when it goes to the first set tab, hit the tab clear key, then hit the tab key again, then tab clear again etc.
Dec 29, 2009 | Swintec 7040 Typewriter
MARGINS
Try a little light oil on the silver shaft that the carrier slides on, if that doesn't do it then the carrier motor needs lubed, it is under the case on the R. rear corner.
DickyO
Apr 11, 2009 | IBM Wheelwriter 30 Typewriter
Wheelwrite 10 stuck in the middle
It sounds like the left margin is set in the middle of the page, return to the stopping place, press margin release then backspace to the place where you wany the left margin and press l. margin key.
If that dosen't do it remove the batteries and unplug the machine for a minute or two all settings will go to defalt. CAUTION ALL THE MEMORY WILL BE CLEARED!!!
DickyO
Mar 19, 2008 | IBM 3500 Typewriter
Cursor stays in middle
Try resetting the left margin to a place near the left side
Oct 19, 2007 | Nakajima AE-740 Typewriter
Help with Typewriter
hold down the code key and press the margin release, to set margin, just hold code release margin, space over to where you want it and then press Margin set, left or right.
Jun 05, 2007 | Brother GX-6750 Typewriter
Margin Release for Brother GX-6750 Typewriter
Typewriters have alimit to how far to the right or left that you can set margins. Once you use the alt & 6 key to bypass the current margin setting then move to the new setting then hold the alt key and touch the 7 key to keep it in the new position.
Mar 09, 2007 | Brother GX-6750 Typewriter
Lexmark Wheelwriter 1500 Typewriter Logo
42 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
