Question about Tools & Hardware - Others
It does not shoot the nail flush and skips every other nail
    Problem Solver:
  • 21 Answers
1. check your hose for leaks 2. check the spring in the nail slot 3. if those don't solve your problem then your bearings in the compression chamber are wearing out and you should consider getting a new nail gun
Posted on Apr 05, 2011
My dc616 dewalt nailer is not firing and constant flash not battery no jambed nails what else could it be
look at the end where the nail comes out . it should be flush across , if the plunger is sticking out then push it back in with a flat screw driver and try again.soft wood quite often lets the nail shoot to far
Aug 13, 2015 | Dewalt DC616 16g Cordless 18v Straight...
Wats wrong when my Ryobi battery powered 18v nail gun will not shoot out the nails?
broken firing pin , worn motor , microswitch contact pbc assembly (electronic)
A safety bar thats a little bit bent , or there was a nail beaten wrong shooting on metal
Feb 10, 2015 | Tools & Hardware - Others
Dewalt framing nail gun want shoot nail
Which model is it? What happens when you try and shoot it? Is it leaking air and if so from where? Is there a nail jammed in the tool?
Aug 19, 2012 | Dewalt Tools & Hardware - Others
How can I make a really cheap sofa table?
Cut ListCut List: A) 4 - 1x3 @ 29 1/4" (Fronts and Backs of the Legs) B) 4 - 1x2 @ 29 1/4" (Sides of the Legs) C) 2 - 1x3 @ 10" (Side Support) D) 1 - 1x2 @ 37" (Stretcher) E) 2 - 1x3 @ 37" (Side Trim for the stretcher) F) 2 - 1x4 @ 10" (Side Apron) G) 2 - 1x4 @ 37" (Front and Back Apron) H) 1 - 1x12 @ 48" (Base for the top) I) 2 - 1x4 @ 11 1/2" J) 1 - 1x12 @ 41"
Step 1
Download Original]'>untitled-3%20(15).jpgConstruct your legs by nailing through the 1x3 legs into the edge of the 1x2 legs with 2" nails and glue. The legs will be positioned with the 1x3s to the front, 1x2s to the side, as shown in the diagram.
Step 2
Download Original]'>untitled-4%20(14).jpgStart by marking each of the legs 5" from the bottom of the board. This will be the bottom of the side support, C. Nail C to the legs, using 1 1/4" nails and glue, from the inside.
Step 3
Download Original]'>untitled-5%20(13).jpgNow add the stretcher, D, centering D on the support, C, but keeping the top edges flush. D will lay flat, with the wide side up. This is demonstrated above. Use glue and 2" nails, nailing through the support, C, into the end of D.
Step 4
Download Original]'>untitled-6%20(9).jpgAdd the side trim pieces, E. First, nail through the supports C into E, using 2" nails. Then nail down the length of the stretcher, taking care to keep the top edge of the stretcher (D) perfectly flush with the top edge of the stretcher support (E). Use glue and 2" nails.
Step 5
Download Original]'>untitled-7%20(8).jpgNow use the 1 1/4" nails to nail through the back of the side apron pieces, F, into the legs. Use glue. Keep top edges perfectly flush.
Step 6
Download Original]'>untitled-8%20(7).jpgDo the same for the front and back apron pieces, G, as shown above. Nail through G into the legs using 1 1/4" nails and glue. Keep top edges flush. Take a minute to check for square
Step 7
Download Original]'>untitled-9%20(7).jpgNow add the base top, piece H. Keep the front and back edges flush with the legs, but let the sides overhang 4" on either side. Nail into the legs and the apron using 2" nails and glue.
Step 8
Download Original]'>untitled-10%20(6).jpgUse glue and 1 1/4" nails to attach the breadboard ends to the base top. Keep all outside edges flush.
Step 9
Download Original]'>untitled-11%20(5).jpg I recommend not cutting the final piece, J, unitl you have taken an exact measurement. Add the final piece, using glue and 1 1/4" nails.
Finishing Instructions
May 29, 2012 | Furniture
I have got a second hand Duo-Fast CN350B Nail Gun. It is new to me, and I dont have a operating manual for it. I have heard they accept multipule guage nails, is this true? Also can the nail driving depth...
They use 20 degree, full round head, plastic coalated nails. You can shoot nails ranging in guage from .099 to .131 and I believe from 2 3/8" to 3 1/4" length. It is a heavy but well built and powerful tool. It's not made anymore because Duo-Fast has long been sold to ITW which also owns Paslode. The owner of Duo-Fast (third generation, family owned) got very ill with cancer and ended up passing away quite a few years back. I worked as a sales rep for Duo-Fast in the early 1990s. I can not find an owners manual link for you. They don't have an adjustable depth but they do have a flush adapter. Here is a link to a parts diagram. The flush adapter is part number CN-133 and is held on with a screw.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/duofast/CN-350B
Jul 17, 2011 | Tools & Hardware - Others
Nailer skips shooting nails three out ten times
check the collation and proper nails for this tool. Also when was the last time tool was cleaned and serviced, It sounds like either one
Sep 11, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Bostitch Nail Gun wont release and shoot nail
I had purchased a bostitch bt200 and am just now trying to use and after loading the nails 18ga 2" brads made by bostitch connecting to a small compresor that had 20 psi I pushed the nailer flush with the board and pulled the trigger and had no nails ejected. Is there something else I needed to do, manual was read.
Sep 04, 2010 | Stanley Air Tools & Compressors
Shoots 2 or more nails at a time
Happened to me awhile back...just load few nails..it tends to shoot to many when you load it full. break a section in half load it and it should shoot just fine.
May 27, 2010 | Porter Cable BN18200 2" 18 Gauge Brad...
My nail gun will shoot one nail and then stop shooting.
check with one of your friends that have a nowinly good 18v bat if that dont work check for little pieces of plastic or pieces of the nail that are jamed up by the plunger
Apr 22, 2010 | Dewalt DC618KA Angled Nailer Kit
Tools & Hardware - Others Logo
51 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
