Question about Karcher 2500 PSI Pressure Washer
I get no pressure
I have a craftman 4.0, 2150 psi/1.9 GPM pressure washer, THERES NO PRESSURE LOL none at all, everything works, its on and running, even water comes out of the wand, but its not comin out with pressure, please help....vicky
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 14 Answers
SOURCE: no pressure
Replace the bypass valve, this is the most common problem. Failing that remove high & low pressure valves and ensure they are not blocked or worn
Posted on Mar 11, 2009
The engine cuts off when i squeeze the handle on the sprayer, what is causing this to happen?
Sounds like a bad unloader valve. Do a search on "pressure washer unloader valve symptoms". When they are faulty there will either be little pressure or it will stop an engine abruptly. The engine will not just die down as it you were turning it off. It would stop cold.
May 28, 2015 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Pump builds pressure but not full pressure on same faucet iv always used
possibly have worn seals inspect them and also unloader valve which normally has a spring
Aug 13, 2014 | Craftsman 2700 Max Psi Pressure Washer 23...
Homelite Pressure Washer. 2700 psi 2.3 GPM Gas Pressure Washer won't start
I found a small long spring disconnected from my throttle which made the engine run rough It is easy to reconnect and makes a big difference in engine performance. also, if there is a very dirty air filter-oil/dirt it will not start-replace filter.
Jun 17, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Why won't the cleaning solution come out of the hose for Husqvarna 3100 PSI 2.8 GPM Gas Pressure Washer 020490?
Most people I run into with this problem are trying to get the cleaning solution to work with one of the high pressure tips, usually red, green, white or yellow. The only way to make the machine use the cleaning solution is with the low pressure, soap tip, usually black. With the high pressure tips there is too much back pressure for the solution to be picked up and mixed into the water stream.
Apr 28, 2014 | Husqvarna 3100 PSI 2.8 GPM Gas Pressure...
Pressure washer surges
This could be your unloader valve taking in account the engine isn't surging. Does the engine run smooth? Do you have at least 50 psi water pressure feeding the pump? Inlet screen clogged? ALL tips act same way or no change?
Sep 08, 2012 | Generac 2700 PSI 2.3 GPM Gas Pressure...
Troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Sep 04, 2009 | Karcher 2500 PSI Pressure Washer
No pressure
Aug 06, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
Top Karcher Garden Experts
Martin Grech
John Trevino
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
