Panasonic Viera TX-32LX70 32 in. LCD  TV Logo
Posted on Apr 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The picture images are fat and squatty, particularly people! Can the picture be adjusted?
Anonymous
Level 2:
Scholar:
  • Expert 125 Answers
  • Posted on Apr 05, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
125
Questions
0
Helped
26582
Points
379
Search the remote for a button that says "format" or "aspect ratio" or maybe "display." You're looking for 4:3 aspect ratio. This will probably give you bars on the sides of the pic and is usually only adjustable on analog.
1helpful
How do I adjust the 22 in. rectangular screen to prevent images from appearing wider than normal. For example, pictures of persons make them look fat and wide.
You can use any other image viewing software such as Picasa. It will open images at 100% size but you can change the size of images
2helpful
Pictures and icons look squatty How do I make them look normal?
change your resolution. depending on whether its a widescreen or not, this can make pictures look squatty. if its widescreen, generally 1400x900 is a good resolution. on regular ones 1280x1024 is generally good. but that also depends on what size ur screen is also
Display is huge and squatty
Try ajusting the resoloution to a higher number. That should work.
I have an Orion TVD 2710. Need to adjust resolution.
if you have a menu button on tv shoul be able to do it there after you push the menu button then use the up or down button for selection then the volume up or down to ajust then menu to exit. Now if no menu button sometimes you can push the up down chanel button at the same time and get into the menu. Hope one of these works.
1helpful
Picture looks stretched, people are squatty looking
You may only need to change the format for the picture. Check your owners manual for how to change the picture format, or aspect ratio. The tv may be in the zoom mode the way you describe it. There is likely an option in the menu to allow the unit to automatically set the format based opon the signal being received. Only some of the programming you see is actually HD. The Super Bowl was broadcast in HD and has a 16:9 aspect ratio (width to height). When this set is adjusted for a correct HD display I'm confident you will be impressed. So I believe this is a matter of a customer setup with the remote. If I had the unit in front of me I could offer more detail. I hope my general opinion helps.
1helpful
The picture on my LCD 52" 650 series TV makes everyone look short
There is an aspect ratio setting in your menu options. You will have to change the aspect ratio so you get a normal screen.
This will most likely fix your problem.
If by slight chance it doesn't, you will have to remove the back of the tv and find the manuyal adjustments for it.
All newer Tv's have the aspect ratio/picture change setting.
Images are too fat looking or spread out on my 22" monitor, how do i adjust so the images appear normal?
You need a video card that will adjust the resolution to the proper proportion. The closest I can get to a good aspect ratio is 1152 x 864.
Sony dp26648 tv
I would like to help you but I do not know what squatty is
Samsung TSL3099WHF
Check the B+ output voltage, if this is higher than rated, this problem could occur.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
