Question about Philips Televison & Video
I have a Magnavox model 51MP3964H/17 and the power light is blinking.
  • Philips Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Apr 05, 2011
Magnavox 32me303vf7 HDTV blinks red 20 times on blink #17 magnavox appears on screen then TV shuts off and blink red light goes to solid red till power button is depressed. Thanks Heath
This set has nothing to do with "Philips" the old parent company of Magnavox, about 5 yrs ago they were bought out by "Funai" in China...Emerson, Magnavox, RCA, Sylvania, Sanyo to name a few are all owned now by Funai so any information from Philips won't help on this set...If your comfortable working around high DC voltage you can test the voltage on pin 20 of CN501, it should be around 21 VDC, if you see that there then go to pin 8 of CN501 and look for 3 volts after you push the on button, if its there replace the power board, if its not there replace the main board. This is a common issue with any 32" TV made by Fanui, Ive worked on I would say close to 200 of these over the last few yrs, for a lack of a better way of putting it...they aren't a very good TV, quite low end components and a major lack of engineering went into making it, but this is why they sell for $150 or less at Walmart
Feb 20, 2018 | Magnavox Televison & Video
No picture or sound magnavox 42MF231D/17 only 2 of the green blinking lights are working
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 10, 2015 | SNK Magnavox 42MF231D 42 in. Plasma TV
I have a big magnavox tv that all of a sudden the picture went out with only sound. I tried everything possible from changing cables and calling my cable company to see if the problem was there but no
Your flyback has failed most likely...bad new is they are nearly impossible to find, This is a known issue on most of the models below. The site Tv Repair Kits can sometimes get replacements - but its not often.
This repair kit is known to work on Magnavox TV sets with the following Chassis/Model Numbers.
DPTV305 , DPTV305F , DPTV310 , DPTV315 , DPTV330 , DPTV330F , DPTV335 , DPTV340 , DPTV345, MAG01
Model Numbers
( 43PP9202/17 43PP920217 43PP9202/17F 43PP9202/84 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920201 50PP920217 50PP920284 50PP920284F 50PP920217F 51MP392H/17 51MP3964H/17 51PP9303H/17 51PP9363H17 51PW9303/17F 51PW936317F 55PP9352/17 50PP920217F 51MP392H17 51MP3964H17 51PP9303H17 51PP9363H17 51PW930317F 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F 60PW938317F 43PP9202/17 43PP9202/17F 43PP9202/84 43PP920217 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920217F 51PP9303H/17 51PP9363H17 51PW9303/17F 50PP920201 50PP920217 50PP920284 50PP920284F 51PP9303H17 51PW930317F 51PW936317F 55PP9352/17 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F )
Mar 29, 2012 | Philips Televison & Video
I replaced the Convergence ICs (STK392-120) in my Magnavox 51MP3964H/17, but when we soldered the new ones in, there was a solder bridge. We fixed that problem but the red is still out of whack. (Still...
Check the resistors around the amps. Many times one or more resistors are blown, but they may visually look fine.
Check all of the pico fuses.
Also,
Sep 10, 2009 | Televison & Video
Black Bars and Power Issues
Sounds like a solder bridge bewtween the IC pins double check the solder for any pins accidentally bridged with solder.
Sep 06, 2009 | Televison & Video
Magnavox 51mp3964H/17
You need to replace Both of your STK convergence ICs they are big black ICs will have part number on them STK392-110 ,ect if you can solder you can fix it your self ,TV repair shop m/b 300.00 also you will need Service Code to be able to enter into TECH alinement mode .Call Mats Electronics for parts 1-800-628-1118
Aug 18, 2009 | Philips Televison & Video
Tv doesn't want to start
The power light blinks about 9 times and the tv wont turn on what does this mean? its a magnavox 51mp392h/17
Aug 05, 2009 | Sony Televison & Video
Magnavox 51mp3964h/17 has 3d effect
You can get the repair kit at the following link to reapair the convergence issue. The kit contains the two Convergence IC and the 12 resistors plus step by step instructions how to do the repair. Heres the link for the correct kit for your model which is the Mag 01 chassis.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Jun 01, 2009 | Televison & Video
Phillips projection tv will not converge
Replace Both convergence ICs STK392-120s use 180s better ICs they are big black ICs will have STK on them Mat Electronics for parts 1-800-628-1118.Also CK 6.8 ohm resistors around STKs.
Dec 30, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 20mf500t/17
ur backlight inverter is bad .just change it.
Oct 26, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Televison & Video Logo
49 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
