System wont configure i p adress - Computers & Internet
    Champion:
  • 221 Answers
May be a problem with your router. Restart your router
Posted on Aug 06, 2008
System Error E007
Are you getting this problem while trying to scan , if it is the most probale case is you are using DHCP setting on your pc and the ip address of the pc varies, so the machine is not able to send the documents scanned to the particular IP , to which the machine is configured what you can do is make the IP adress static and reconfigure the scanner by using sharp desk software or you can configure the scanner by giving the host nameof the particular PC if you have a DNS server , better way if you are not so familier with IT you go to network places, then click on view network connections and click on the properties and from the next window scroll down to TCP/IP click on properties and give a static IP, sub net and gate way this nos you can get by going to start menu on the run you type cmd then youwill get the cammand prompt window there you have to type ipconfig /all and press enter then it will give you so much information in which you can find the ip adress, subnet and gateway and give this to your pc and apply, then you open the internet explorer and type the ip adress on the adress bar and press enter then you can go to the machine web page then select administrtor setting the admin username and pass word is admin and admin, and press enter then go to image send settings and configure the newly given ststic ip to the particular PC, rate this and come back withmore queries.
May 04, 2011 | Sharp AR-M350N Copier
How to configure zebra plt2844 on netware or do you know the default ip adress
go to the driver and print the configuration label, if you see the ip adress, just write the IP adress on the browser and you be abel to check the configuration from the printer, it is possible to change some setings from there.
Aug 25, 2010 | Zebra TLP 2844-Z Thermal Label Printer
I have the mc 70 how do i get started if i wanted to send my orders using wifi
i thank that you have to configure you acces point first, and configure also your unit to communicate with your acces point in setting( ip adress,subnet mask,ssid,keys...) and and connect your acces point to your system( switch,modem ,,,)
Feb 03, 2010 | Symbol MC70
D-Link 2100 AP is working in Wireless Client mode. It is connected to home network with cat5 cable. The remote ADSL modem is 192.168.1.1 and DHCP on. The first computer in the network obtains IP and...
Check in your router to see if your router is set up to be a DHCP Server. If your router and adsl are both set up to be DHCP servers, sometimes they will fight with each other and some computers seem to have problems getting adresses from this kind of setup. Make sure that only one is set up to give out adresses, then check on your second computer to make sure that it is set to obtain adress automaticaly. If someone has set a manual adress in that computer that is not on the same subnet as the router, they will not comunicate. If this does not solve your problem, try putting in manual adresses into both computers: IE 192.168.1.2, subnet mask 255.255.255.0, Default gateway 192.168.1.1 in the first, and 192.168.1.3 in the second with the same subnet and default gateway,
Nov 24, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
Cannot see server
check ipconfig if ur ip adress is correct configure Ip address statically but then be carefull that u dont duplicate another Ipadress already on network
make sure gateway ip adress is correct as well as dns server ip adress
try to add urself to the domain check if your pc name is correct
Sep 01, 2009 | Computers & Internet
I DONT KNOW HW TO CONFIGURE THE IP ADDRESS IN DOS MODE SO PLZ .HELP ME...AND GRAND ME THE CODE OF CONFIGURING SYSTEMS .. THANKING U IN ADVANCE SINCERELY FASMIN
You can use the netsh command to configure Ip adresses.
1. IP via DHCP:
netsh set address name="MyLocalAreaConnection" source=dhcp
2. static IP:
netsh set address name="MyLocal AreaConnection" source=static addr=192.168.1.61 mask=255.255.255.0 gateway=192.168.1.1
- no line breaks in the commands
- change names and numbers to your needs
- check on mistyping and spaces between the commands
Feb 23, 2009 | Microsoft Windows Server Standard 2003 for...
Trying to connect dvr to my laptop
did you enter proper ip or url in configuration . when cldvr v 101206 opens ther is config button u click that enter same ip adress of dvr. this dvr ip adress you will see in dvr system ip configuration. that ip you have to eneter in config button and than click connection button and eneter passowrd admin and there you go
Jan 22, 2009 | Clover Corporation CDR-4070 Video Recorder
Driver help...Anyone?????
For Router drivers is not required ,U can configure though the command prompt
I can tell some configuration try it,
the default ip adress of the router will the 192.168.1.1 OR 192.168.0.1
In your Lan card configure,
1. obtain Ip adress automitically
go to command prompt----type ---ipconfig---check the ip address which ip is getting---
go to internet explorer ----type the ip address in adress bar-----------login page will get---
login as, user name admin
password admin------configure your internetip adress & DNS ip address,save & check.............
Mar 21, 2008 | Actiontec GT704WG Wireless Router...
Linksys wrt54gs
open your webbrowser and type in your routers ip adress... by default it is 192.168.1.1.. default username and password is 'admin' configure your wi router and you should be ready to go...
Feb 14, 2008 | Linksys Wireless-G WRT54GS Router...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
