Question about Weiser Lock POWERBOLT ELEC DEADBOLT
This lock was installed by other some years ago. Now its stop locking. Please advise on procedures. Regards.
  • 963 Answers
Powerbolt 1000
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Here's a link to the Frequently Asked Questions page for the Powerbolt 1000:
The instructions for reprogramming the code can be found there. Good luck!!
Posted on Apr 08, 2011
Can not move the gear selecter the button will not go all the way in and the rear brake lights do not come as well
Hi Jeff,
This is an old warning issue or procedure, I had the same problem a few years ago with my Ford Taurus 1995, if rear stop lights not work, you wont be able to moved the shift out of Parking (P); this is to avoid driving without rear stop lights. If no lights, normally a fuse is blow out or all bulb lights are gone, please check.
There is an alternate procedure to be able to drive your car, but, avoid driving without Stop lights. Turn the ignition key to the point before starting the engine, this release the lock for the driving wheel and transmission shift, press the brake, put the shift in Neutral (N) and start the engine. Im not sure if your Ford Edge has the no key starting button or fob, there is a procedure to release the locks and be able to drive, should be in your drivers manual, but, again; the intention is to avoid moving the car without Stop Lights.
I hope this helps. Happy Holidays and take care.
Dec 08, 2013 | 2008 Ford Edge
I have a 2008 Hyundai Sonata 4 door, 4 cylinder. When I bought it a year ago, the lock on the door on drivers side would not open on the first try with the remote key. I had to press the remote several...
Yes, I would rule out a fuse or relay, because the other locks work. It would not have a separate fuse and relay for that one door. Probably is the motor, as the body shop advised.
Sep 07, 2013 | 2006 Hyundai Sonata
Wont shift
possable bad brake lite switch. also check fuses.
Nov 21, 2012 | 1995 Ford Taurus
Oven buttons stop working and it is in lock mode and says OFF?
Sounds like a control board failure ... should be under warranty, no?
Best Regards,
Bruce
www.fixyourboard.com
Jun 21, 2010 | Whirlpool Accubake RF362LXTS Electric...
406 wont lock/unlock please help!!!
Switch ignition ON.Press and hold lock button for 10 sec.Switch ign.Off.Remove key from ign. switch.Wait 5 sec.Sinchronization procedure complete.Confirm sinchronization has been successful by locking,double locking and unlocking vehicle. Repeat abuve procedure to sinchronize any remaining key.Good luck
Nov 30, 2009 | 2005 Peugeot 405
We bought the weisser lock several years ago and never did set the combination and use the keypad. We have lost the instructions how to even set it up for the first time.
Here's a free manual you can print out with complete installation and programming instructions you can keep for addressing any other concerns you might have in the future.
I thought this might be easier for you to work from, since you might have to reset the lock prior to entering in your codes, etc.
It is easy and straight forward to program and use.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Hope you find this Very Helpful - Best regards!
Aug 05, 2009 | Weiser Lock POWERBOLT ELEC DEADBOLT
Teac x1000r tension arms drop take up reel stops
terrysrubberrollers.com might be able to help
Jan 23, 2009 | Audio Players & Recorders
I HAVE A JVC XV-THP3 DVD PLAYER. MY LITTLE GIRL WAS PRESSING THE BUTTONS ON THE FRONT AND HAS LOCKED THE DVD TRAY. CAN YOU HELP ME PLEASE?
Hi there, I just had the same problem with my daughter, looked in the manual and it says to hold down the stop button and press the eject button on the unit. That should unlock it, its the same procedure to lock it, in case you want to prevent you daughter from attempting to play biscuits!!
Regards, darren
Jan 08, 2009 | Panasonic DVD-A110 DVD Player
Replace ignition tumbler
STEP BY STEP Please Remember to Rate Me Thank You RejakWilson
WARNING: On vehicles equipped with Airbags, disable airbag system prior to performing service procedures.
  1. Disconnect battery ground cable.
  2. Remove steering wheel as outlined under STEERING WHEEL procedure.
  3. Using a screwdriver, pry cover from housing.
  4. Using lock plate compressing No. J-23653 or equivalent, compress lock plate, and pry snap ring from groove on shaft, Fig. 5. Slowly release lock plate compressing tool, then remove tool and lock plate from shaft end.
  5. Slide canceling cam and upper bearing preload spring from end of shaft.
  6. Remove turn signal (multi-function) lever.
  7. Remove hazard warning knob retaining screw, button, spring and knob.
  8. Remove pivot arm.
  9. Wrap upper part of electrical connector with tape to prevent snagging of wires during switch removal.
  10. Remove switch retaining screws and pull switch up from column, guiding wire harness through column.
  11. Reverse procedure to install.
  1. Remove turn signal switch as outlined under TURN SIGNAL SWITCH.
  2. Remove buzzer switch and spring clip. On 1990-92 models, ignition key must be removed from lock to remove buzzer switch. On 1991-92 models, switch and spring clip are one assembly.
  3. Turn lock cylinder to Run position on 1989 models or Lock position on 1990-92 models, then remove lock cylinder retaining screw and the lock cylinder.
  4. To install, rotate lock cylinder to the stop while holding housing. Align cylinder key with keyway in housing, then push lock cylinder into housing until fully seated. Lock cylinder must be in Run position to install buzzer switch.
  5. Install lock cylinder retaining screw, then the buzzer switch, turn signal switch and steering wheel.
Aug 30, 2008 | 1989 Chevrolet Celebrity
Sound driver
Hi, I want to install sound driver on my laptptop model: Toshiba satellite L30. Please advise me.
Aug 10, 2008 | Toshiba Satellite L20-S310TD Notebook
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
204 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
