Question about Garden
Hose on cjc-1001 pressure washer is leaking. Need to buy new one but cant find a distributor
  • Amanda Drew
    Amanda Drew Oct 03, 2017
    The hose on my pressure washer is also leaking. It's at the spot where the hose connects to the pressure washer, so I'm hoping it's just a little loose or something. Have you tried talking to a professional who repairs them? You might not need to replace it at all: I'm probably going to go looking for a repair service.http://quickstoppressurewashingsupplies....
    Problem Solver:
  • 21 Answers
Http://www.watercannon.com/c-11-hoses-pressure-washer.aspx here a link to a site that sells high-pressure hoses. almost all hoses are similar when it comes to pressure washers, just by the right attachments and you'll be good to go.
Posted on Apr 05, 2011
Manual for pressure washer Neiko tools cjc-1001 3,000 psi where can i find it.
You will need to order this from the manufacturer, it is not available online as of this date.
Sep 07, 2016 | Psi Garden
How do i fit a new lance to Challenge MH02-1610GO pressure washer
Just the lance or trigger gun! Best of luck to ya!
Sep 23, 2014 | Garden
I have a simpson G3000 pressure washer. The small high pressure line from the pump has developed a leak, (it's about 18"s) Do you have a part number I could use to get a replacement, or point me...
You can use a universal hose for replacement. This hose should not be under high pressure (usually inlet water hose pressure). This is a bypass that is used when you release the trigger to wand. Look closely at the brass fittings of the hose, sometimes they can be reused by removing the clamp and cutting off the rubber part. Use automotive rubber hose (suitable for hot water system/radiator )or black pressure hose from Lowes (sold bulk) that will fit snugly on the barb and use simple clamps. You can make new hose by buying barbs and hose from Lowes or hardware/plumbing store. Good luck
Sep 13, 2011 | Simpson PS3200 Powershot 3200 Psi Direct...
Water leak where the gun hose connects to the washer causing very low pressure 2200 psi model 020245
Simple fix, just disconnect house end from washer, buy a new rubber washer o ring, like what is used for garden hoses. Put back on make sure it is tight. If still leaks, then need to replace connection end fitting on preside washer, can get those at almost any hardware store, use plumbers tape on threads when putting new fitting on machine, then connect house and back to those honey do list :)
Jun 08, 2011 | Garden
I have a Premium Pressure Washer CJC-1001 2.3 GPM. I do not have a hose and wonder how this is attached to the engine. Is there instructions I can obtain for this? Thanks
Hello sir, my pr. washer is runing but with high quantity of dark fumes from the exahaust and high temprature in the engine.
Apr 21, 2010 | Garden
Help!!! water leaks from hose of my new haier hwd1000!!!
If water is leaking from the pressure hose itself, go buy new hoses at the hardware store.
If it is the connection between the hose and the machine, you can add hose gaskets and wrap the threads twice in plumber's tape. This is a thin white slightly stretchy tape that you wrap around the threads before you screw on the connector.
Mar 06, 2010 | Haier HWD1000
High pressure hose. How do you get if off the karcher k 3.99
there is a small clip on the triger where the hose attaches to is, pull clip out pull hose off
Jun 16, 2009 | Karcher K 5.85 M Electric Pressure Washer
High pressure hose connection blew up. Fix? or buy new?
Yes take it to napa auto parts and they can cut and attach a new end which are for hydraulics. They are crimped on and meant to hold very very high pressure. I used to use a pressure washer everyday for a living and it was a tractor rental/repair shop and we used the hydraulic fitting machine on the power washer hose all the time so rest assured.
Mar 11, 2009 | Garden
Need new gun and connection to gun
The DuraBuilt and Coleman pressure washers have a gun that tends to leak through the plastic clyinder wall that holds the plunger that moves with the trigger. You won't see the holes, but if you remove the upper half of the housing, hold the plastic tubes in place with one hand and turn on the water, not the motor, you will see water shooting through the wall.
Amazon sells an exact replacement gun and hose. FAIP PowerWasher Replacement Gun and Hose #80012. Mine does not leak at all and was $29 shipped.
Dec 14, 2008 | Coleman Powermate DuraBuilt 1400 PSI...
Garden Logo
213 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
