Question about Vacuums
I need a new handle for my GB Musa 6 Cup coffee maker. I am from Quebec City, Canada. Where could I get one of these?
It's a Bialetti Musa. The GB stands for Guido Bergna, the designer.
I haven't seen handles on any parts site, just gaskets and strainers.
You might contact Bialetti Canada, or Bialetti USA and get a handle.
CANADA
Toll Free:
800.667.4978
Mail:
Bialetti c/o Stonehaven Group
1880 Ellice Avenue
Winnipeg, Manitoba R3H0B9
email:
info@stonehavengroup.ca
USA
Toll Free:
800.421.6290
Mail:
9409 Buffalo Avenue
Rancho Cucamonga, CA 91730
email:
sales@bialetti.com
bialetti.service@bialetti.com
Posted on Aug 22, 2012
4 Suggested Answers
frankgilbert
  • 613 Answers
SOURCE: It'll bring the water into
You have to use a lot of vinegar as it evaporates....this is a coffee maker right and not a vacuum?
Posted on Nov 02, 2010
  • 54 Answers
SOURCE: B77 Keurig coffee maker won't
I had the same problem with my Keurig coffee maker. The needle is clean, and no deposits. Above the needle is a check valve. This is a simple fix. Open the K-cup arm and look up, in front of the needle housing is two silverish screws. Remove them and lower the arm but don't lock. Slide the black top cover out to expose supply hose and check valve. Carefully cut the zip tie and remove hose from check valve. Remove the two scres holding the valve in place and drop it down and out. Blow into the end where hose attaches. You should be able to blow thru, with some resistance. If you can't, thats your problem. Take a paper clip and carefully bend and insert into end where hose attaches, pushing ball in valve down alittle. Blow into it again, you should be able to now. If not, keep trying, it will go. When done re-assemble and run a cup of water, with out cup to clean it. Hope this helps ya!
Posted on Feb 23, 2011
angry_giant
  • 62 Answers
SOURCE: when i make a cup
Your coffe may be ground too finely for your maker.
Is your coffee maker flat-bottom or cone shaped? Or is it a french press?
Your coffee needs to be ground according to the brewing method. Too coarse and it will be watery, too fine and it will be too dark, or you might get grounds.
Posted on May 06, 2011
Miele coffee
This machine needs an overhaul.
the boiler is leaking along with several o'rings.
Dec 21, 2013 | Miele Germany CVA 4062 Whole Bean 500g...
I have a one cup at a time Keurig. I measure the water and pour in then Kcup coffee. I shut the covers and press brew. The coffee maker starts to heat the water but then will not pump the water through...
I have one too. Had the same problem and needed a new clean Kcup. The oil residue build up wasn't allowing the coffee to pass through. Some models also have internal filters. Bed Bath Beyond has all the replacement parts and lists the units by Model on the part. Hope this helps.
Sep 05, 2011 | Vacuums
I need a downloadable manuel for a Keurig single cup coffee maker Model B40
just go to keurig.com - they have manuals you can download there
the "b40" is the "elite/b40"
morelater
the show doctor
Aug 16, 2011 | Vacuums
My Keurig coffee maker is not brewing. The word prime is on the screen. How do I prime the unit.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 14, 2011 | Vacuums
Need to clean cuisinart 12 cup coffee on demand coffe pot. How do I clean?
Do you have the DCC-2000?
To delime a multi-cup coffee maker, mix white vinegar with water (1/3 vinegar and 2/3 water) and fill the water reservoir completely. Then turn the coffee maker on. Wait until the unit completes the "brewing" cycle and beeps 5 times. Turn off the coffee maker. Discard the liquid after the cycle. Then fill the reservoir with clean water and turn on again. When this cycle completes, again discard the liquid. Repeat the water rinse if you notice an odd taste to the coffee afterwards. (If the coffee maker still has deposits, repeat the vinegar cleaning cycle and rinse cycles.) There are commercial deliming products, mix them with water following the package directions.
The manual for the DCC-2000 is available as a link here: http://www.cuisinart.com/products/coffee_bar/dcc-2000.html . The direct link to the manual is http://www.cuisinart.com/share/pdf/manuals/dcc-2000.pdf .
I hope this helps.
Jun 19, 2011 | Vacuums
When i make a cup of coffee with my kuerig coffee maker my coffee is coming out with coffee grinds though it. how can i fix this problem?
May 06, 2011 | Vacuums
B77 Keurig coffee maker won't dispense coffee if k cup is in holder. Help?
Dec 07, 2010 | Vacuums
Need parts diagram for euro-Pro ep601. I need to replace the power cord, but cannot get the motor gasket guard off.
FOR TECHNICAL SUPPORT
for Model EP601 HEPA
In U.S.: 800-798-7398 In Canada: 800-361-4639
514-842-8691
Monday to Friday 8:30 A.M. - 5:00 P.M. Eastern Standard Time
Oct 03, 2009 | Vacuums
Vacuums Logo
1,144 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
