Question about Westinghouse L1975NW Monitor
I own a Westinghouse L1975NW, Power light Green, Image on screen just very dark, It fit the bill for the common backlight issues that this monitor seems to have. So I did the repairs, (Bought the kit- Two caps, Two Molfets, 4amp fuse) Ater everything worked beautifully! The Screen was funrtion for 2 days and on the 3rd day I turned on my computer and BAM Same Symptoms. I pulled it apart again everything I replaced seems fine, No damaged or swollen caps, None of the soldering is cross touching. I inspected the boards completely, Nothing blown, No caps swollen, No fuses burnt .... So Yeah, What's next?? Is there a backlight Lamp that may need to be replaced?? Again screen turns on, I can see images faintly and green light is steady (power) Any further info would be greatly appreciated!! Thanks :)
  • 11,361 Answers
Did you recheck the MOSFETs? You will need a set of test lamps to test the inverter to see if it is the inverter or the lamp assemblies. I am surprised that the kit only contains 2 caps, it should have at least 4 caps, 2 each for the 5v and the 18vdc power supply section. Take the DC reading on the caps to see what you have, take the reading WITHOUT turn on the monitor (the power supply is running al the time), then turn on the montior to see if it maintains the output voltages.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Apr 05, 2011
  • Anonymous Apr 08, 2011
    Thanks!! I will most definitely try this next chance I get! I will post back with my results hopefully I have some time within the next few days.
My screen symtoms are a little different on my L1975NW.
I am guessing the LED power indicator blinks green then becomes steady when the screen "turns on" (shows video). The problem is most likely a failing backlight power supply. That's why there is a 30 minute delay. Try to disable sleep mode and see whether that helps.
Aug 30, 2012 | Westinghouse L1975NW Monitor
I have the Westinghouse L1975NW
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Notes: When the caps went out, it may have raken out the fuse and the MOSFET in the inverter circuits with it also. http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/
May 23, 2010 | Westinghouse L1975NW Monitor
L1975NW Monitor: My monitor is very dark; too dark to even see how ...
More likely the backlight is not on, check the caps (leaking/bulging tops) in the power supply first, then check the fuse in the inverter circuits, when the caps went out it may have taken out the MOSFET for the inverter transformer with it. See failed WESTINGHOUSE and other monitors due to bad caps.
May 16, 2010 | Westinghouse L1975NW Monitor
Whats up with my monitor?
You have a failure in the backlight power supply. We have an article posted on our web site explaining how to repair this problem: http://www.ccl-la.com/blog/index.php/westinghouse-l1975nw-repair/ The Acer AL1916W uses the same power board as the Westinghouse L1975NW monitor. If you don't want to do the repair yourself we do offfer a repair service for $30 plus shipping.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | Acer AL1916W 19" LCD Monitor
Goes dark for 5 to 10 second for no apparent reason?
Look for bad caps in the power supply, it will get worst and can take out the inverter fuse and the MOSFET.
Feb 10, 2010 | Westinghouse L1975NW Monitor
I have a westinghouse L1975nw when i turn it the screen turns on for 1 second then goes black but green light stays on.
More likely to have bad caps and also failed MOSFET in the inverter circuits, look inside and report what you see so we can guide you further: http://s807.photobucket.com/home/budm/allalbums
Jan 24, 2010 | Westinghouse L1975NW Monitor
Monitor is blank but green lightis on L1975NW
LCD Display/ control board Defective, send to repair
Dec 28, 2009 | Westinghouse L1975NW Monitor
The screen is dark
If you have a dark screen but the power button is on the the backlight power supply driver board is damaged. Go to our web site at: www.ccl-la.com We have a step by step repair guide posted that will show you have to do the repair, it involves replacing 5 parts. If you can solder then you can do the repair. If you don't want to do the repair we do offer a repair service for $30 plus return shipping. If you have any questions please contact me at the address below.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 15, 2009 | Westinghouse L1975NW Monitor
Screen does not light up -
This is a very common problem with this model Westinghouse LCD monitor. It is caused by a dead backlight power supply. We have a step by step repair guide posted on our web site at: www.ccl-la.com/badcaps.htm If you can solder then you should be able to do the repair yourself. If you don't want to do the repair yourself then we do offer a repair service for $30 plus return shipping. If you have any questions you can contact me at the address below.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Oct 13, 2009 | Westinghouse L1975NW Monitor
Westinghouse L1975NW Monitor Logo
517 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
