Question about Polar AXN 500 Watch
Where can I find a new watch strap for my Polar AXN 500
    Guru:
  • 347 Answers
You can get these directly from Polar. www.polarusa.com or www.polar.fi
Posted on Apr 06, 2011
How do i get a polar f7 watch band replaced the watch is just over 2 years old
You can get replacement band on amazon, click here and take a look Amazon com polar band replacement. I hope this was helpful, have a nice day
Feb 03, 2012 | Polar Electro POLAR FT40 Heartrate Monitor...
Can you change the battery in the chest strap for polar f6
There are two types of straps for Polar:
1) hard rubber/ solid - These can not have the battery changed.
2) soft strap with connector in middle - these you can change the battery.
If you have the soft strap, it will have a small hard around 3 inch long block that "snaps" onto the strap to connect it. These have a battery compartment. Turn it around and you will see the outline for the battery compartment. These are not always easy to open, and the batteries are a little harder to find. Take it into any watch repair and they should be able to pop a new battery in for you pretty easy.
There is a link on my tips and tricks page to get manuals for Polar products, the T-31 wearlink is the product we are talking about, it has the how to change the battery and battery type.
Jan 12, 2011 | Polar F6 Wrist Watch
I have no speed or trip distance showing, cadence is normally ok. also my watch strap has broken and because it is glued on i cant get it fixed!
Since your Cadence is working then there is a problem with the actual speed/ distance sensor. First make sure that in your settings you have speed turned on. If so then...
1) Your battery may be dead = Replace CS sensor
2) The distance of the sensor and magnet is not set correctly = make sure magnet on spokes and sensor are within 1-2mm of each other.
Polar can fix the strap, you need to send into an authorized service center. They replace the entire strap unit. If you send into Polar to get the strap fixed, then you can send in the sensor unit as well for diagnosis if you want. But if #2 doesn't fix, then it's #1 and they will just tell you to buy a new one anyway.
Nov 29, 2010 | Polar CS300 Cycling Computer and Heart...
The strap is brocken where is the best place to get a new strap.or get it repaired.?
mcdevito75 here, Best bet is to look for a small watch repair shop in your area for a new strap.
Oct 01, 2010 | Polar F4 Heart Rate Monitor Watch
How to use the heart rate monitor
Thank you for contacting FixYa.
You can contact Polar here:
http://www.polarusa.com/us-en/
Best regards. Jewel
Sep 19, 2010 | Polar AXN 500 Watch
How to replace battery in polar f4 watch
HOW TO REPLACE BATTERY IN MY POLAR TARGET WITH A TS1 TRANSMITTER
Nov 25, 2009 | Polar F4 Heart Rate Monitor Watch
New battery needed and fitted to a Polar heart rate monitor
This is really easy to do yourself. Get a CR1632 battery, unscrew the four screws on the back (dont tip the watch as there is a small spring in the watch), unclip the metal band holding in the old battery noting the way 'round the battery is in (minus side up), pop in new battery and push clip back down, when re-fitting the back make sure the spring mentioned earlier lines up with the white sticker with a hole in it on the inside of the watch back, screw down the back. After you have re done all your settings you may need to re-aquaint the watch with the strap, to do this put on the watch and strap, set the heart monitoring going, bring the watch up close to the 'Polar' logo on the chest strap until the time is displayed, should now be all set up.
Andy
Oct 28, 2009 | Polar F4 Heart Rate Monitor Watch
I cracked and chipped the glass of my axn500 watch. what do i have to do?
You can go to a watch repair shop and have the crystal replaced but since it is a sport watch and has a good water resistance rating I would make sure that wherever you go can pressure test it to be sure it is resealed properly. Your best bet is to go directly through Polar for the repair or replace the watch depending on cost.
Sep 16, 2009 | Polar AXN-500 Sports Watch - Heart Rate...
AXN 300 Watch
Here is the link to the user manual for your watch; http://www.polarusa.com/manuals/AXN300.pdf Check page 9 - you have to re-enter these basic settings after removing the battery, this may clear the error message although i was unable to confirm this from the manual. contact polar on; http://www.polarusa.com/default.asp and you can find a service centre who can check your watch, all the necessary link software downloads etc. Hope this helps :)
Oct 03, 2006 | Polar AXN 300 Watch
Watches Logo
578 people viewed this question
Top Polar Watches Experts
noel
noel
David Payne
David Payne
Are you a Polar Watch Expert? Answer questions, earn points and help others
