Question about Canon Pixma MP500 All-In-One InkJet Printer
Black ink It looks like the black ink is leaking because ever time I print a page there is a long black strip on the back of the paper.  It is wasting my black ink. Please advice. Thanks
  • 5 more comments
  • itit07 Aug 07, 2008
    Thank you,
    I don't think I should have to pay for asking an assistance.
    Cheers
  • Anonymous Aug 14, 2008
    When I print I get a thick (3/8 inch or more) black line on the back side of the copy. After I run the cleaning processes, it fades, sometimes even disappears for a copy or two, but then returns.
  • Anonymous Aug 25, 2008
    a black line prints on back of printed pages when printed on the top 8x10 printout section...ont he bottom printing section the 4x6 pictures look like the ink is too wet and leaky.
  • Anonymous Aug 31, 2008
    Yeah, same problem.
    When I print I get a thick black line on the back side of the copy. I tried running the bottom plate cleaning mode and other cleaning modes with no success.
  • Anonymous Sep 01, 2008
    I have the same problem. What is the solution?
  • Twindaddy Sep 05, 2008
    I also have the same problem. It appeared for the first time after about two years of use. Is everyone using Canon ink or recycled ink cartridges?
  • Anonymous Dec 13, 2008
    I am having the same problem. Big black ink line on the back of the paper. I see I am not the only one. Come on where is the solution to problem!
I called the local Canon printer repair facility, and a serviceman said that the black line is caused by too much ink in the ink absorber device below the paper path. He said to fix it requires disassembling part of the printer, replacing the absorber foam, installing a longer tip for the excess ink, and reassembling and testing the printer. I asked if this would be a permanent fix. He said no, that the problem could reoccur as the absorber foam would eventually fill up again.
Posted on Jan 08, 2009
  • rolfrhjm Dec 16, 2010
    This of all is the only right answer and it make sense. So, lets take out the screw drivers, hammer, etc, and try to fix it. I will let you know if I was able to do it.
    RHM
How do you get rid of the black line that prints on the back of the page?
Posted on Sep 15, 2008
  • karen441 Sep 15, 2008
    This was to be a question, not a solution as I see no answers on this page
I also think you shouldnt pay for it
Posted on Aug 08, 2008
Canon Pixma MP800 Prints a 1/4" black stripe on back of page. Is emptying the large PGI-5 cartridge in record time. Have replaced cartridge, run cleaning and maintenance routines. Cleaned bottom...
I have seen this before but it has not caused the black to run out quickly. if you look into the machine you will see at one end of the platen roller it will be swimming in ink. As the paper passes over the roller it will deposit ink to the back of the paper. now why is the ink getting there? Well its just possible that air hole in the cartridge is blocked but you say you have replaced the cartridge. Ah but with what? are you using recycled cartridges? they may be filled with ink and not dye which is what originals use. Dye is much thicker than ink and ink maybe leaking from the cartridge. The seal in the carriage may not be making a clean contact with the base of the black cartridge causing it to leak when the carriage is moving. Check those out and repost if still having the problem.
Good luck
May 16, 2011 | Canon Office Equipment & Supplies
Leaking Ink Cartridge
You need a shop to clean the extra ink that's coming up on the rollers and install a mylar strip to prevent that in the future. It's the waste ink being forced up thru the exit rollers and getting on the prints.
Sep 10, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon S900 - No black ink (none!)
Clean the contacts on the back of the print head.
Aug 22, 2009 | Canon S900 InkJet Printer
My printer is printing a wet black streak on the back of every page...
It means ink is backing up on the rollers, it is waste ink and should be going to the absorber, but some models have the ink drying up and plugging the passages. You will need cleaning, new ink absorbers, and a mylar strip that will keep that from happening in the future.
Aug 17, 2009 | Canon i850 InkJet Photo Printer
Nozzle Clogging & Black Cartridge Leaking
Hi e-margaret. There's a bit of confusion here. Horizontal banding is due to LACK of ink flow to the paper. "Splodging" is due to too much. The former can be due to blocked/faulty print head nozzles or a faulty/empty-ish cartridge, or some less common problem like the waste ink pipe blocked. The latter is usually due to a leaking cartridge.
The first job is to mop up ink slopping around under the print head. Cut some strips of kitchen towel and fold them into 3 layers so you have a strip about 2 cm wide. Place them on the print head track. Turn on the printer, and as soon as the print head moves, pull out the power cord from the back of the printer. Now you should be able to move the print head carefully by hand too and fro over the towels. Repeat this with clean towel strips until most of the surplus ink is cleaned up. Remove the towel strips, replug in the power chord and switch the printer back on. Do a head clean cycle and nozzle check 3 or 4 times. If the nozzle check output looks OK, try a test print of a text document
If things are still not OK, report back on what happens in a new comment. If my instructions are not clear enough, please post a new comment asking for clarification.
Apr 22, 2009 | Epson Stylus C86 InkJet Printer
Printer prints a black streak down the reverse side
You have a build up of ink inside the printer. I had a Canon that did this. I had to take the ink & print head out, and tear a paper towel strip 1 " wide and 13" long or however long the paper towel is. I folded it in half down the length so it was 1/2x13. Then used a plastic strip to shove it under the part the print head sits in. Once I got the towel to the other side, I grabbed it with my hand. I removed the plastic strip used to shove the paper towel under. So now the paper towel sticks out both sides underneath the print head cradle. I gently pull the paper towel back and forth so the paper towel can clean off the ink build up. Hope this helps.
Mar 29, 2009 | Office Equipment & Supplies
MP830 prints a black stripe down the back of the paper
the waste ink pads are full ..when the black line appears it is an indicator that the waste ink pads are full it is usualy because the printer has reached its life expectancy the solution is either buy a new printer or pay a tech about 170 dollars to repair it
Jan 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Black smear of ink at end of lines
Please load the printer with at least 10 sheets of plain paper then press the start button. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains, streaks or smudges are still present, the printer may need service.
May 23, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Black ink line on back of paper
Hi , look some used injection cyrene to suck up the used ink , take cover suck up all ink by reversing injection put in clean jar .after all ink finished cover it try to print from first time some print some black mark after tthree or four times maybe no more.
Jan 08, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Black line on back of page
It sounds like you have a black ink leak and it is smearing onto the paper when you print. I don't know any reasons for this except if you topped the black ink up yourself, and didn't re-block the hole you made. Then I guess the ink would gravity drip onto the paper tray while you weren't printing. Otherwise I would suggest changing the print head, but this might be expensive.
Dec 28, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
410 people viewed this question
old marine
old marine
