Question about Keurig Elite B40 Coffee Maker
Hot water wont come through it.. worked for a couple of months then quit. Right at the last it would come out but took forever.
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 08, 2011
I have SWT552SA Ezi Sensor. Why won't it run?
There are several online appliance parts stores. They are usually quite helpful in diagnosing problems and know the part giving the problem. Otherwise, a lightly used replacement may be the way to go. It may cost less than a service call and parts.
Jul 05, 2015 | Simpson Washing Machines
Car wont start. took a fuel injector out and put the same one right back in and it ran for 2 days fine now wont start again, what is the problem?
A possible fuel pump pressure issue. You will need to have a garage check the fuel line pressure. The engine requires more fuel on cold start and a failing pump may not be able to cope with supply. This may also be apparent at high revs, but not as apparent as cold start.
Oct 30, 2012 | 1996 Chrysler LHS
Kitchen Aid KSCS23FVMK less than a week old had the waterline installed two days ago. Everything was working well (except it seemed that the ice took forever to be made) until this morning when no water...
Slow water and ice, could mean that you haven't gotten all the air out of your system yet. I would suggest holding the lever down for water for quite some time to evacuate the air out. If I am right eventually water will start flowing.
Jul 01, 2011 | Refrigerators
I have a top load GE washer only about 18 months old, model WDRR2500K3WW. Problem is the water just trickles in and takes forever to feel and begin the wash cycle. I disconnected both hot and cold hoses...
The fine filters should not be removed from the inlet pipes; they are there to protect the workings and, providing they are checked/cleared occasionally, will not restrict water flow.
I think your problem is being caused by a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill and the cold rinses are OK, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
Sometimes washers take much longer for the wash cycle because the heating element is caked with limescale and is inefficient (with electricity). A good thing to do (anyway), with the machine empty and switched off, is to pour the contents of a couple of sachets of limescale remover into the tub together with a couple of kettles of hot water and leave overnight. In the morning run a spin cycle which will take the mix through the drain filter and motor, doing absolutely no harm whatsoever!
Good luck,
John C
Mar 23, 2011 | GE Washing Machines
No water comes out on ventilate. At first, the water was coming out very slowly, in drips. The doser or grind were not the problem, because even when I switched to Hot Water, it was still dripping. ...
Hi
It should take about 45 minutes to an hour to properly descale the machine. If it only took a couple of minutes you really didn't descale your machine. If you used the powder it has to disolve completly before descaling. The best way to descale is with the descaler in the tank. Turn on the machine and run about 8 ozs of water-descaler through the wand and then turn off the machine. Wait 10 minutes and repeatthe last procedure. Do this until the tank is empty. When done with the descaler, rinse out the tank and put fresh water in the tank and run the whole tank through the wand. Then fill the tank and your ready to go.
Nov 13, 2010 | Gaggia Syncrony Compact Coffee...
Water turns cold very quickly
I had the EXACT same problem (installed my tankless last winter and worked fine, now this summer it fluctuates, have to turn the shower completely off and then on again to get any hot water and then it only lasts for a couple of minutes!) Argh - it is frustrating!
Here's what I found: the demand for hot water is lower during the summer (hot) months because the "cold" water coming in is already quite warm. You don't need as much hot water to make the shower temp comfortable. SO, my tankless was shutting off due to low flow demand. I've removed the flow restrictor from my shower head and it helped alot but didn't completely solve the prob. Next step is what has been recommended to me by several people but is much more expensive - change the pressure valve on your shower to a temperature valve. Or just wait til winter and it should work ok again :)
Jul 06, 2010 | Bosch & Tankless LP Hot Water Heater
Hello, My Rheem hot water heaters pilot light
make sure that it is pushed into the flame of pilot light good because if not it can cool off and go out.and make sure that no drafts are getting in to heater to blow pilot.like when you close or open the front or back door have someone open them while you watch pilot light to see if it flickers .
Oct 26, 2009 | Water Heaters
Stopped up
I took a small tooth brush and brushed the screen from the inside of the pot. That cleaned it right up and I now have a full stream, dispensing.
May 12, 2009 | Hamilton Beach BrewStation 47224 Coffee...
06 buick lesabre a/c problem
sounds to me like blower motor bad not switch controls or blower resister need more info?
Aug 26, 2008 | 2006 Buick LeSabre
Keurig Elite B40 Coffee Maker Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
