My driver for usb modem venus vt-218 in my modem contain with virus Generic.dx!vqm type Trojan, and this just can remove in file lan_eng.dll, not clean. where i can download for this driver clean from virus? please help me and tanks for all.
    Problem Solver:
  • 5 Answers
Did you try to download it from their website?
Posted on Apr 05, 2011
Driver modem venus HSDPA VT 218
I think this is your drivers...
Feb 21, 2011 | Computers & Internet
Zlob virus
I found this on the net, i hope this helps you out. It also says that this nasty virus is a tough one...and you still run the risk of ruining your info on the hard drive. Back-up critical info (Docs,Music, Game info etc)
And keep me posted on the results..i hope this helps you out! GOOD LUCK! 8-)
Step 1 : Use Windows File Search Tool to Find Zlob Path
  1. Go to Start > Search > All Files or Folders.
  2. In the "All or part of the the file name" section, type in "Zlob" file name(s).
  3. To get better results, select "Look in: Local Hard Drives" or "Look in: My Computer" and then click "Search" button.
  4. When Windows finishes your search, hover over the "In Folder" of "Zlob", highlight the file and copy/paste the path into the address bar. Save the file's path on your clipboard because you'll need the file path to delete Zlob in the following manual removal steps.
Step 2 : Use Windows Task Manager to Remove Zlob Processes
  1. To open the Windows Task Manager, use the combination of CTRL+ALT+DEL or CTRL+SHIFT+ESC.
  2. Click on the "Image Name" button to search for "Zlob" process by name.
  3. Select the "Zlob" process and click on the "End Process" button to kill it.
  4. Remove the "Zlob" processes files:
  5. msmsgs.exe nvctrl.exe msmsgs.exe nvctrl.exe
    Read more about How to kill Zlob Processes
Step 3 : Use Registry Editor to Remove Zlob Registry Values
  1. To open the Registry Editor, go to Start > Run > type regedit and then press the "OK" button.
  2. Locate and delete the entry or entries whose data value (in the rightmost column) is the spyware file(s) detected earlier.
  3. To delete "Zlob" value, right-click on it and select the "Delete" option.
  4. Locate and delete "Zlob" registry entries:
  5. HKEY_LOCAL_MACHINESoftwareMicrosoftWindowsNTCurrentVersionWinlogonShell=explorer.exe HKEY_LOCAL_MACHINE SoftwareMicrosoftWindows NT CurrentVersionWinlogonShell=explorer.exe, msmsgs.exeHKEY_LOCAL_MACHINESoftwareMicrosoftWindowsCurrentVersionRunRegSvr32=%System%msmsgs.exe HKEY_LOCAL_MACHINE SoftwareMicrosoftWindows CurrentVersionRunRegSvr32=%System%msmsgs.exe
    Read more about How to Remove Zlob Registry Entries
Step 4 : Use Windows Command Prompt to Unregister Zlob DLL Files
  1. To open the Windows Command Prompt, go to Start > Run > type cmd and then click the "OK" button.
  2. Type "cd" in order to change the current directory, press the "space" button, enter the full path to where you believe the Zlob DLL file is located and press the "Enter" button on your keyboard. If you don't know where Zlob DLL file is located, use the "dir" command to display the directory's contents.
  3. To unregister "Zlob" DLL file, type in the exact directory path + "regsvr32 /u" + [DLL_NAME] (for example, :C\Spyware-folder\> regsvr32 /u Zlob.dll) and press the "Enter" button. A message will pop up that says you successfully unregistered the file.
  4. Search and unregister "Zlob" DLL files:
  5. uimcu.dll antzozc.dll dtjby.dll
Step 5 : Detect and Delete Other Zlob Files
  1. To open the Windows Command Prompt, go to Start > Run > type cmd and then press the "OK" button.
  2. Type in "dir /A name_of_the_folder" (for example, C:\Spyware-folder), which will display the folder's content even the hidden files.
  3. To change directory, type in "cd name_of_the_folder".
  4. Once you have the file you're looking for type in "del name_of_the_file".
  5. To delete a file in folder, type in "del name_of_the_file".
  6. To delete the entire folder, type in "rmdir /S name_of_the_folder".
  7. Select the "Zlob" process and click on the "End Process" button to kill it.
  8. Remove the "Zlob" processes files:
  9. uimcu.dll antzozc.dll dtjby.dll dumpserv.com zxserv0.com vnp7s.net Protect RSA ncompat.tlb msvol.tlb hp[X].tmp msmsgs.exe nvctrl.exe dumpserv.com zxserv0.com vnp7s.net %UserProfile%\Application Data\Microsoft\Protect %UserProfile%\Application Data\Microsoft\Crypto\RSA ncompat.tlb msvol.tlb hp[X].tmp
Jun 07, 2009 | Toshiba Satellite Pro L300 Notebook
I have an intex it-305wc webcam when i reinstall the drivers. After which whenever i start the camera the system restarts. My OS is XP.
I've had this problem, and I had to clean out my registry for it to work properly again. I used Regpro to automatically clean out my registry, you can find similar programs online that will do the same.
May 06, 2009 | Intel CS331 Webcam
When it scans and finds a virus it won't let me delete
Then if you can quarantine that in a folder. Quarantine it. If pccillin have a reporting log with its path. Then copy in a piece of paper the name and path. Then delete that in DOS mode if you are familiar with that only be sure that it is a legit viral file.
Apr 12, 2009 | Trend Micro PC-cillin Internet Security...
Network connection prompt error 6: handle is invalid
Hi glamredhel, Norton has removed the virus or Trojan & if you have windows system restore turned on the virus or Trojan will return once the system has re-booted. Open windows device manager & shut off system restore. Re-boot your system & re-scan your system with Norton. In your case Norton did not give you instructions on how to remove the virus. (Norton did that for you).
Once completed check windows update service for a possible update for your LAN. Asus does not have a separate LAN driver listed on Asus web site. The LAN driver is part of the chipset drivers. Remove your modem from the system & any software you installed with it. (If any). Restart your system. (If the system seems fine-good. Shut down the system & re-install your modem & any software. When completed do another windows restart. See if the modem functions (If your modem is either a cable or DSL reset it.
Shut down the system.
Located on the back of the cable modem or DSL modem you will find a tiny re-set button. Unplug the power cord from the modem. Take a pen & press the reset button for 10 seconds. Re-connect the power cord & boot the system. Check for internet connection.
The above are just a few item you should try.
Good luck glamredhel!
Post your findings.
Mike
Mar 23, 2009 | ASUS M2N-MX Motherboard
Trojan virus from dvd bought at best buy
I also got this DVD combo package and got the virus warning. Did some serious digging. It is not the game, it is a loader that the developer has added to the combo version of it. The solution is easy. I did it for myself and a friend with the same issue.
1 Turn off your anti-virus (to avoid the warning).
2 Use explorer to navigate to the installed directory. I think it is c:\\program files\city-interactive\game name....
3 find the file listed as "game.exe" this is the loader. Delete it!
4 find the file listed as "game.bin" and rename it "game.exe". This is the real game program file.
5 repeat for the other game that is giving same problem.
6 Reboot and restart you'r anti-virus
7 enjoy your game!
Feb 11, 2009 | Navarre Games Just For Girls 3 for Windows
How to remove trojan horse agent.vzc?
Hi
To resolve this problem the easiest way are
1) User Trojan Remover
http://www.simplysup.com/
--> Update the definition at the time of installation
---> Scan whole system
----> After successfully removal of trojan uninstall the Trojan Remover
2) Manual Methods
Requirement :- Linux Live CD
-> boot system with Linux Live Cd
--> Mount all drives
---> Locate infected DLL files and Trash them.
----> Restart system into Windows
Jun 03, 2008 | Computers & Internet
Trojan horse generic
First, go in Control Panel, after System, then System Restore, and desactive all.
Restart the machine in Safe mode, and run a AntiVirus (like a Norton) restart again, check the file, if not missing, the solutions is search in web (or in Symantec.com) a Virus Remove Tool, OR, in DOS delete a infected file, for full asistance install a HiJack Free and send a email to me brunogamba@gmail.com
Dec 14, 2007 | Acer Aspire 5610-4648 Notebook
How to remove Trojan.Duntek Virus is found in my laptop
Hello...
First download this ANTI TROJAN ( TROJAN REMOVER FULL VERZION )
http://rapidshare.com/files/64484485/Trojan_Remover_6_1_.6.2.rar
Then go with safe mode and istall it and scan computer for viruses it will clean all viruses on ur pc!!!
If u lookin for best antivirus on the net u have here :
http://rapidshare.com/files/64234420/Sophos_Antivirus.rar
Oct 27, 2007 | Computers & Internet
124 people viewed this question
k24674
jasbo
jasbo
