Question about Dell Inspiron 9200 Notebook
Inspiron 9200 cannot power up.
Plug in power cord (green light on) Push power button and A lock light blinks green about 10 times and shuts down.
  • heptane6war Aug 06, 2008
    Inspiron 9200. Cannot power up system. Plug adapter in and green light comes on. Push power button and A lock icon blinks green about 10 times and shuts down. Thanks [email protected].
    Of at least a dozen attempts to get help...you were the only one to the rescue without having your hand out!! Bravo and Thank you
    Genius:
  • 2,028 Answers
Start by checking the power supply with an ohm meter for the correct output, however, this is generally a problem with the battery or a memory chip. Start by removing the battery and starting up on the power supply only. Dell batteries are notorious for causing a no start. Then try removing the memory and try one chip at a time in both slots. If none of these work, then I'm afraid you have a failed system board component, and you will probably want to take it in for a professional diagnostics. Also, you can find a diagnostics light codes list for your machine at Dell's support site.
Posted on Aug 06, 2008
  • Ryan Rogers
    Ryan Rogers Aug 06, 2008
    You're welcome. If you have any other problems or questions feel free to ask.
SOURCE:
Dell inspiron mini 10 won't charge or boot up
Lesson 1: Never, ever buy a computer that does not have a cd drive on it because one day the thing is going to croak and you'll need that drive.
However, your problem sounds like either the power cord is bad or the DC Power Jack where you plug the power cord into the laptop is bad.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 09, 2012 | Dell Inspiron Mini 10 Notebook
Dell Inspiron 6000 powers up, caps lock flashes 9 times, then laptop shut down. Why???
Unplug power cord from laptop, remove battery from laptop. Open memory access panel on the bottom of the laptop. Remove memory module(s) (SO-DIMM). Plug power cord back into laptop. Turn laptop on (with the memory removed), the caps lock and scroll lock LEDs light, then the laptop shuts itself off. Unplug power cord from the laptop. Reinstall the memory modules. Make sure they are seated correctly. Put the battery back in, plug the laptop back in, and power on. Laptop should power on and boot up properly.
May need to hold the power button down to get it to power on properly.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Dec 03, 2011 | Dell Inspiron 6000 Notebook
My dell mini inspiron doesn't work when i turn it on; it starts but then nothing, it is obvious that it is on but it is only a black display on the monitor. What could be the problem?
You can switch it OFF and remove the battery.
Wait for 5mins, Connect the battery again, Also connect the Power Cable to the Laptop.
Try to switch it ON, It should work.
With regards
FIXYA team
**Please post your feedback and Vote if the problem resolved as per your satisfaction**
Oct 08, 2010 | Dell Inspiron Mini 10 Notebook
Dell Inspiron 9200 PC Notebook will not power up. Lights come on about 5 sec then turn off.
Try these simple steps:
- remove the battery
- disconnect the ac adapter
- press and hold power button for 10 seconds
- plug the ac adapter in
- power on your system
If it doesn't power on, press Fn+Power button to launch the Diagnostic Utility
If diagnostics doesn't come up, your motherboard needs replacement.
Jun 08, 2010 | Dell Inspiron 9200 Notebook
My computer turns on, the green light is on and the orange light is blinking but screen doesn't show anything
I may be in low-power mode. Try jiggling the mouse, pushing enter on the keyboard a couple times and just pushing the power button once.
If none of those work push and HOLD down the power button for about 10 seconds and the computer should shut off.
As an absolute last resort pull the power plug, leave it out a few seconds then plug it back in and power it on.
One of these methods should at least get the screen back up.
Jun 07, 2010 | Smart Modular SV3170A
Dell inspiron 5160 wont start
It sounds to me like your Laptop over heated... I cannot be for sure But I would get your Motherboard check because it sounds like its shot.
Mar 18, 2009 | Dell Inspiron 5160 Notebook
Power indicator light blinking
it looks like the battery is defective. try reseat the battery while the power cord plug in to see if that help. if you remove the battery and leave the power cord plug in, the battery symbol indicator light will turn off. Time to order a replacement battery.
Nov 24, 2008 | Dell Inspiron E1705 Notebook
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on).
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Oct 11, 2008 | Dell XPS 200 PC Desktop
Dell Inspiron 9200 Notebook Logo
144 people viewed this question
Ekse
Clive
Clive
