Question about Cycling
Is there a diagram to show how the rear hub should be rebuild. I need the order of how the parts go into the rear hub. I took the rear hub apart due to a grinding noise and now the whell will not spin freely on the hub
  • 794 Answers
Hi jym9417,
Do you have the specific brand and model of your bycicle so we can check out the right diagram for you?
Thank you for using Fixya.
Posted on Apr 05, 2011
Exploded Diagrams
Take it apart piece by piece and lay them in order............ or dear god did you inherit this job from someone that quite?
(Some reason I can not post links or pictures)
May 01, 2013 | Transmission & Drivetrain for Ford Transit...
I'm trying to remove the "hub" from the front axle because the rotor was rusted to it and a new one won't fit "true". I need a picture or exploded diagram to understand why it...
Your hub is a complete unit including wheel flange and bearing. Thje axle passes through the assembly. You will find three twelve point 13mm bolts that go into the rear of the hub through the steering knuckle.
To remove the assembly, Loosen those three bolts, run them out part way and use a socket you don't want (you will destroy it) Put the socket on each bolt and use a heavy hammer to drive the assembly out of the knuckle. Alternate sides so it does not bind. use lots of solvent on the hub parting surface.
One tip: Disconnect the tie rod end so the assembly is easy to turn from side to side.
The hub assembly is only rebuildable in a factory. It is replaced as a unit. While you have it apart, always check the axle universal for binding or play. If you remove the axle for any reason, when putting it back in don't drag it on the bottom of the tube, The seal is inside the tube next to the gear set. Dragging the axle will knock the seal out.
Jul 18, 2011 | 1992 Jeep Cherokee Sport
The rear wheel hub assembly on my bike fell out while I was taking it apart. I didn't get a chance to look at it, now I can't get it back together.
There is a book put out by Park Tool that has a great wealth of maintenance and repair technique and information. i believe the information is also available on their website and if you visit it, the link you will want to follow is at the top right hand of the page "Repair Help". Roll your cursor over the hub of the part of the bike you need diagrams for (if you want hub info, it is the front hub you have to click because the rear deals with freehub repair).
Hope this helps,
matt
Sep 15, 2009 | Huffy 26in Mens Sante Fe Cruiser Bike -...
Can't get the damn rotor off 06 Hyundai Sonata
Depends somewhat if it's a front rotor or a rear rotor. The most common problem will be "corrosion" that's binding the two metal parts together. If you are not trying to reuse the rotor after turning (many are throwaways now adays) take a large hammer and bang the outer edge of the rotor. The vibration should cause the corrosion to break apart, and the rotor should pull away. If your planning on re-using the rotor after turning use a large rubber mallet.
The front rotors have about a 3/4 inch common surface between the rotor and the wheel hub. You may need to bang on the backside of the rotor as you slowly turn the rotor in order to cause the two parts to slide apart. It can be a slow process, but you should see some movement (but it must be even movement around the entire rotor. The back rotors have far less common surface and a few good waps should break the parts free.
Jul 13, 2009 | 2006 Hyundai Sonata
Does anyone have a diagram of 1994 F150 manual wheel hub
Are both sides apart? Don't have any diagram to give you, go to Ford and ask for the exploded parts diagram, it shows the parts in order, they will usually print the page for you no charge, it is good business. I am sorry can't be more help, call if you like 925-459-0571
Aug 02, 2008 | 1993 Ford F150 SuperCab
No power
I was having the same problem. I took the whole thing apart. It was the motor brushes and the handle switch. Check out www.ToolPartsDirect.com and type in your mower model number. You can see the diagram and order the parts you need. Mine were less than $20. It's really easy to take this mower apart.
Jul 17, 2008 | Black & Decker 19" Electric Lawnhog...
Cycling Logo
79 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
